Valve adjustment cost? - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 04-30-2004, 5:52 PM Thread Starter
Skully's Avatar
Images: 19
I was quoted 4 hours ($70 per), sound right?
Skully is offline
post #2 of 7 Old 04-30-2004, 6:00 PM
tigerblade's Avatar
Reputation Power: 29
Re: Valve adjustment cost?
Most of that time will probably be in disassembling/assembling. We checked the valves on my RC last year with the aid of the service manual (the official Honda paper one, abtech ) at it's not too difficult. Might want to try tackling it yourself.
Is a paradigm worth 20 cents?
tigerblade is offline
post #3 of 7 Old 04-30-2004, 6:30 PM
Do the manual thing!!!
JOKER-1000 is offline
post #4 of 7 Old 04-30-2004, 7:05 PM
Images: 29
Reputation Power: 15
I just did mine a couple of weeks ago and the hardest part was undoing the throttle cable. If you get the service manual it's easy. Don't bother with the cam chain tensioner holder (special tool). It can't be used while the engine is in the bike. If the cams need to be removed for adjustment you'll have to remove the tensioner.
Another great site to visit.
CBRjack is offline
post #5 of 7 Old 05-01-2004, 12:03 PM
TCD
What tool do you use to check the clearance?
I recently put in a set of hot cams myself, but I had to take it to the shop to get the clearances checked. I would like to do it myself and save $300 next time.
TCD is offline
post #6 of 7 Old 05-01-2004, 3:29 PM
Hmmm... I used the special tool when I adjusted my valves. Seemed to work well.
I've got a little article I put together on how to inspect the clearances, but you really should have the service manual any time you attempt something like this. My valve inspection procedure . I think it's in the kb.
Ride well.
Iron Butt Association #313244
Joel is offline
post #7 of 7 Old 05-01-2004, 7:07 PM
EatnAsphalt's Avatar
Removing the throttle cables isn't really necessary. If you remove the front brake perch and loosen the throttle on the clipon you can get enough slack in the cables to pull the far enough out of the way.
I had a heck of time getting that bottom cable back on the throttle body the one time I chose to remove them.
EatnAsphalt is offline
Human Verification
Search tags for this page
cbr 250 valve adjustment cost
cbr valve adjustment cost
cost on valve job motocycle
honda shadow valve adjustment cost
how much does a motorcycle valve adjustment cost
how much does a valve job cost on a motorcycle
how much is a valve adjustment on a motorcycle
how.much does a valve job on a crf150 cost.
what is the average cost of valve cheak on a motorcycle
Removal of exhaust valve.... 954spider Honda FireBlade 19 05-22-2009 12:28 PM
Flapper and Pair Valve mods? Hellfire666 Honda FireBlade 3 04-23-2004 11:05 PM
First valve service, not happy with what I found.. CBRjack Honda FireBlade 18 04-16-2004 8:55 AM
Is this the PAIR valve? Bdonkadonk74 Honda FireBlade 21 04-07-2004 12:15 PM
