06-17-2003, 1:52 AM
| Re: High Speed Wooble I recently took by bike (954) out for a long distance run. As I hit about 190kph the front tire woobled. I was at a bike meet last week and a friend of mine told me that she sold her bike because it tank slapped at 200kph.
I would like to gather comments from other fireblade owners, if they have had similar experiences. Is this high speed wooble inherent to all bikes? What causes this to happen? |
06-17-2003, 5:02 AM
Bike(s): 2003 954 (fireblade) 149.3 Hp Age: 45 Posts: 5,183
Rep:  (28) Rep Power: 12
If you had a tank slapper you would know about it, what you may have experienced was just a headshake, may have been brought on by a slight bump on the road or an uneven surface, while under throttle, lots of different variables can cause these.
if you are concerned, i recommend you buy a steering damper |
06-17-2003, 9:03 AM
Bike(s): 05 VTX 1800F1, 05 SS750, 07 CBR1000RR(2) Age: 36 Posts: 543
Rep:  (13) Rep Power: 7
| Re: High Speed Wooble Quote:
ratter1 :
| and Welcome to the .org
I BLEED RED
06-17-2003, 9:10 AM
#4 | | ...no tour for you!
Bike(s): '03 954, '01 929, '99 1100XX (SOLD :( ) Age: 47 Posts: 2,431
Rep:   (109) Rep Power: 9
| Re: High Speed Wooble Quote: |
ratter1 : if you are concerned, i recommend you buy a steering damper
| ......and welcome to the .org! * |
06-17-2003, 9:36 AM
Bike(s): none again...so far... Age: 31 Posts: 4,011
Rep:  (87) Rep Power: 12
| Re: High Speed Wooble sounds like it was not a slapper...sounds to me like the front wheel is out of balance. I would check that first. I have had tank slapers on fast take offs where your fighting the wheelie...and the front wheel skips causing a slapper...but wobbles I have seen from tire balance. Hope that helps. |
06-17-2003, 9:48 AM
showmethebombs : sounds like it was not a slapper...sounds to me like the front wheel is out of balance. *I would check that first. *I have had tank slapers on fast take offs where your fighting the wheelie...and the front wheel skips causing a slapper...but wobbles I have seen from tire balance. *Hope that helps.
| This just happened to me the other day coming out of second gear. *I found a nice road that I could see down for miles, no driveways, very few cars, etc. *The road had a couple bumps and I hit one as I was coming out of second gear. *The front end lightened up and my front wheel came down a little off so it started to shake. *I was on the throttle in 3 by this time to the shake only lasted once from left to right but it's still making me think of the damper again.
I did a 150mph (not sure what that is in kph) run that day and didn't have any problems with handling, etc.
Brad |
06-17-2003, 10:25 AM
Bike(s): V-Strom 650 Posts: 759
Rep:  (39) Rep Power: 7
cyan : This just happened to me the other day coming out of second gear. *I found a nice road that I could see down for miles, no driveways, very few cars, etc. *The road had a couple bumps and I hit one as I was coming out of second gear. *The front end lightened up and my front wheel came down a little off so it started to shake. *
Brad
| Definately time for a damper. I had the same experience twice before I got my Scotts and that was enough. |
06-17-2003, 1:26 PM
| Re: High Speed Wooble ditto. * get a damper ASAP. *I loved the arrow I had on the 929. *This vid ALONE will convince you I hope. *
LOOK AT THE VID BELOW!!!! wowowowowowowowow VID
that rider might have even had a damper, being a race....note, the rider died. |
06-17-2003, 2:02 PM
Bike(s): CBR929rr blue/white/red Age: 31 Posts: 2,463
Rep:  (10) Rep Power: 9
| Re: High Speed Wooble Buy a damper. Those head shakes happen all the time until.
A buddy of mine was killed after a tankslapper last summer... he was a riding instructor and wasn't riding aggressively at the time which goes to show it can happen to anyone at any time. Dampers are cheap insurance. |
06-17-2003, 3:32 PM
Bike(s): 2003 Black/Red CBR954RR Age: 44 Posts: 595
Rep:  (10) Rep Power: 8
showmethebombs : ditto. * get a damper ASAP. *I loved the arrow I had on the 929. *This vid ALONE will convince you I hope. *
LOOK AT THE VID BELOW!!!! * wowowowowowowowow VID
| HOLY SH1T!!!
That was nasty! |
06-17-2003, 4:57 PM
Bike(s): '97 Yamaha YZF600r, '00 Honda 929, '03 Honda 954 Age: 78 Posts: 655
Rep:  (75) Rep Power: 6
| Re: High Speed Wooble All British m/cs from 350cc & up had a simple knob at the top of the steering head & turns to the right snugged up the front end more. You will find it on vintage Brit road races of Norton Manx, AJS, Matchless, Velocette & others.
When I started breaking in my '00 929 I knew this bike would benifit from a steering head damper & so the Scotts in my case, yet my 600 does not need one.
Remember all the others on the road are crazy & out to kill you.
06-17-2003, 5:17 PM
Bike(s): CBR1100XX, CBR954, RC51 Posts: 427
Rep:  (24) Rep Power: 6
| Re: High Speed Wooble Sure . . . get a damper. Also check tire pressure and balance. |
06-17-2003, 5:19 PM
#13 |
| Re: High Speed Wooble Isn't that video from the 1997 or 98 Isle of Man TT. I think I have the video at home. In any case, that is a short changing experience. |
06-17-2003, 5:38 PM
#14 |
Rep:  (10) Rep Power: 6
| Re: High Speed Wooble all i can say is giddy up *it's like mounting your old lady and then making some pig noise . if you keep it up and or in you win a prize 'LIFE' pain free |
06-17-2003, 6:47 PM
#15 |
Bike(s): 2002 CBR954RR Silver/Black Age: 52 Posts: 364
Rep:  (10) Rep Power: 7
| Re: High Speed Wooble One instance of a wobble won't be enough to go on. It is possible one or both wheels need balancing. I ran my 954 up to an indicated 282 kph (175 mph) a couple of days ago, and the bike was absolutely stable. Your experience is not normal, so you may need to do some high-speed testing (cautiously) to see if you sense any instability at all. There shouldn't be any. If so, have a competent dealer look at it. |
06-17-2003, 9:34 PM
#16 |
RaggedEdge : One instance of a wobble won't be enough to go on. *It is possible one or both wheels need balancing. *I ran my 954 up to an indicated 282 kph (175 mph) a couple of days ago, and the bike was absolutely stable. *Your experience is not normal, so you may need to do some high-speed testing (cautiously) to see if you sense any instability at all. *There shouldn't be any. *If so, have a competent dealer look at it.
| His experience is a little different than yours though. He said he hit a couple of bumps in the road which is what started the headshake. |
06-18-2003, 12:23 AM
#17 |
| Re: High Speed Wooble At the high speeds that today's bikes are capable of...(and used a lot of the time), wheel balance is very important. I have my wheels balanced on a machine (with a competant operater) at least 3 times during the life of the tire. |
06-18-2003, 1:26 AM
#18 |
Bike(s): '02 CBR954 Age: 42 Posts: 548
| Re: High Speed Wooble Get the steering damper. It only took one nasty slapper to change my mind. I bought one the next day. |
06-18-2003, 4:29 AM
#19 |
Rigger : all i can say is giddy up *it's like mounting your old lady and then making some pig noise . if you keep it up and or in you win a prize 'LIFE' pain free
06-18-2003, 5:34 AM
#20 |
| Re: High Speed Wooble To Ratter1: Thanks for the advice. I most definitely will buy a damper. The roads here are not so smooth, so it was probably the bumps that caused the head shake. Thank for the advice.
For Everyone: Thank you for the warm welcome. Ride safe and enjoy life!!! |
06-18-2003, 5:40 AM
#21 |
Top Ace 65 : To Ratter1: *Thanks for the advice. *I most definitely will buy a damper. *The roads here are not so smooth, so it was probably the bumps that caused the head shake. *Thank for the advice.
For Everyone: *Thank you for the warm welcome. Ride safe and enjoy life!!!
| your welcome |
06-18-2003, 5:40 AM
#22 |
| Re: High Speed Wooble To Showmethebombs, That sure is scary. I guess when the bike acts like that all you can do is let go! Thanks for sharing that movie clip with us. Hope it never happens to any of us! |
06-18-2003, 5:50 AM
#23 |
| Re: High Speed Wooble To Everyone, Thanks for the inputs and advice. I'm sure the problem occured from a variety of factors..... ...Do I sound like the MSF..... |
