A question..
Old 06-24-2003, 11:00 AM
Bike(s): 1990 CBR600F1, 1997 F3, 2002 954
Rep: 515O is on a distinguished road (10)
Re: A question..
My blade had never fall on its sides and never had an accident. (thank god * )
Now if i stand directly behind the rear tire, the rear chainguard (which is above the rear sprocket) had MOVED to the outside (or away from the rear tire) a few cm. And the rear fender also moved a little bit.
The good ride of the machine is not affected (at least that's what i feel).
My paranoia is whether i am overlooking an early warning of a problem *
Few theories:
1. The vibration felt by the swingarm (which they're attached) from very rough roads.
2. Heat from the tire...?
3. Someone just pull it with their hand/hands....?
Thanks for any replies guys.
515O is offline
View 515O's Profile View 515O's Gallery Find More Posts by 515O
Old 06-24-2003, 9:26 PM
nhfirefighter13's Avatar
Bike(s): 2001 929
Rep: nhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to behold (835)
Send a message via AIM to nhfirefighter13 Send a message via Yahoo to nhfirefighter13
Re: A question..
Are the bolts loose?
nhfirefighter13 is offline
View nhfirefighter13's Profile View nhfirefighter13's Gallery Visit nhfirefighter13's homepage! Find More Posts by nhfirefighter13
Old 06-24-2003, 10:26 PM
HondaGal's Avatar
Bike(s): '99 VFR, '06 Warrior
Rep: HondaGal will become famous soon enough (75)
Send a message via AIM to HondaGal
Re: A question..
Is the rear wheel straight?
HondaGal is offline
View HondaGal's Profile View HondaGal's Gallery Find More Posts by HondaGal
Old 06-25-2003, 7:55 AM
Re: A question..
Bolts are ok, not loose.
Rear tire straight? Hmm, the marker on both sides of the swingarm are spot-on balanced (the ones which we used to tighten the chain). No prob in riding, the bike still seems well balance to me, the machine did not sway left n right when i let go both my hands, turning and cornering almost perfect....
One of the mysteries of the universe hehe...
TQ.
515O is offline
Old 06-25-2003, 12:04 PM
Pete's Avatar
Bike(s): '06 CBR1000RR, '06 CRF450X, '06 CRF100
Rep: Pete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to behold (815)
Re: A question..
Are you sure it actually moved, or could it be that you are just now noticing that it is not perfectly aligned? Loosen the mounting bolts, reposition the guard, and retighten.
Just for future reference, the markings on the swingarm for alignment are notoriously off. It's better to measure the distance between the axle nut and a fixed point on both sides when aligning the rear wheel.
Pete is offline
View Pete's Profile View Pete's Gallery Find More Posts by Pete
Old 06-25-2003, 12:08 PM
ER
Bike(s): '01 929 - SOLD
Rep: ER will become famous soon enough (57)
Send a message via AIM to ER
Re: A question..
Pete : Just for future reference, the markings on the swingarm for alignment are notoriously off. *It's better to measure the distance between the axle nut and a fixed point on both sides when aligning the rear wheel.
I'm curious about this. *I followed Abtech's advice the last time I adjusted my chain. * I used a ruler to align the bolts up with the end of the swingarm on each side. *After doing that, I measured the markings on the swingarm for chain-adjustment - they were spot on. *Are all 929s different in that regard? *
ER is offline
View ER's Profile View ER's Gallery Find More Posts by ER
Old 06-25-2003, 12:23 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to behold (814)
Re: A question..
ER : Quote (Pete @ June 25 2003, 11:04am)Just for future reference, the markings on the swingarm for alignment are notoriously off. *It's better to measure the distance between the axle nut and a fixed point on both sides when aligning the rear wheel.
I aligned my rear using the same method and the indicators are off by about half a mark.
Red Rider is offline
Old 06-25-2003, 3:52 PM
Pete's Avatar
Re: A question..
Red Rider : I aligned my rear using the same method and the indicators are off by about half a mark.
Same here. My first 929 was spot-on, and my Superhawk, second 929, and RC51 were all about a half-mark off, whether I measured to the end of the swingarm or to the swingarm pivot.
Pete is offline
Old 06-25-2003, 4:05 PM
ND4SPD's Avatar
Bike(s): '84 Magna V30
Re: A question..
My markings are off as well. Took me 45 min. to mount my rear tire 'cuz of this. I couldn't for the life of me figure out why it wouldn't mount right with the markings being in the same spot.
ND4SPD is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:21 AM.
