06-30-2003, 8:16 AM
Bike(s): 2000 929RR *SOLD* Posts: 30
| Re: Key, ignition problem I just started to have a problem with my key. It seems that when I put it in the ignition, it doesn't want to turn to the ON position . I have to turn it to the lock position and then turn it over to ON. Also, the key doesn't come out like it used to. I need to pull and twist for awhile to get the damn thing out. Any opinions on what is going on?? |
06-30-2003, 8:35 AM
#2 | | Resigned to pursue other interests.
| Re: Key, ignition problem The key warps easily, especially if you have a tight trunk lock. Try your spare key and see if you have the same problem. (Assuming it hasn't been warped also. ) |
06-30-2003, 12:33 PM
| Re: Key, ignition problem Spare key, I wish I had one (bought used) Looks like I will need a new key. |
06-30-2003, 12:35 PM
#4 | | Team Visa Racing
Bike(s): 04 GL1800A,00 929RR,87 CR500R,81 CB900F,71 CB836K1 Age: 45 Posts: 3,951
| Re: Key, ignition problem Also try some graffite lube in the cylinder.
Ride Red
06-30-2003, 12:36 PM
Rep:  (10) Rep Power: 7
| Re: Key, ignition problem Try squirting some Silicone Spray into the key slot. |
06-30-2003, 2:33 PM
Bike(s): '97 Yamaha YZF600r, '00 Honda 929, '03 Honda 954 Age: 78 Posts: 655
Rep:  (75) Rep Power: 6
| Re: Key, ignition problem The keys are long & soft so they tend to bend a bit. If you get one that works properly then have a few more made up. I carry the original one the bike, a SPARE in my wallet, the 2nd original in my safety deposit box & another spare is hung up on the wall at home.
Remember all the others on the road are crazy & out to kill you.
06-30-2003, 2:39 PM
Bike(s): 2001 CBR 929 Age: 34 Posts: 252
Rep:  (17) Rep Power: 7
| Re: Key, ignition problem I have the exact same problem with my 01 929. Last time I was at the dealer getting new tires put on, the shop manager told me I was probably going to need to replace the ignition switch, because the key was probably going to break off in there one day and I would really be F&%#ed. Althought I have not heard to try the spare key fix, I will try that tonight and report back to you.
Redrocker |
06-30-2003, 3:14 PM
#8 | | So easy a ...
Bike(s): 01 929 Age: 39 Posts: 1,281
Rep:  (73) Rep Power: 9
| Re: Key, ignition problem I was having the same problem for a while and for some reason the problem has gone away
Looks like my laziness and procrastination has saved me some $ |
06-30-2003, 3:52 PM
Join Date: 11-21-2002 Location: North Richland Hills, TX
Bike(s): '01 929, '02 XR50 Death Machine Posts: 244
| Re: Key, ignition problem I had the same problem recently. Did a couple of sprays of WD40 into the ignition, put the key in and turned it a few times. Pulled it back out and did a few more squirts. Problem solved. |
