Honda Motorcycle Forum
Honda Motorcycles
Navigation » Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda FireBlade » True Benefits of a Ported Head
Old 07-08-2004, 6:29 AM   #1
Reputation Power: 10
victoRR is on a distinguished road
Send a message via AIM to victoRR
For the 929.
I landed a very good job with Dell Computers (who knows how long it'll last though) and I figured why not take up a project with my bike now.
I am quite confident that the bottom end is still very up to par and after having a valve/cct mishap in January the bike has since been fixed with new valves (2 intake valves) and a new CCT. I ported the exhaust ports while it was off for a not-so-noticable gain.
With a fully ported head, I am looking at *possibly* some aftermarket cams and hardware (valves,springs,shims), full race system (possibly Hindle if I can find a good one used) and a PC3.
What are the true benefits? Who from here has done it? Would I be better off with a 954 swap?
I wanted to, but never got around to track days. My main use for the bike is for enjoyment and the occasional straight line race at the track. *sorry guys, I said it, I drag race my bike*
input?
Would you do it? I'd do the work myself since i've already torn into it.
2002 GMC Yukon SLT - Bling Machine
2000 CBR 929RR - Sunny Days
1998 Plymouth Neon - Rainy Days
victoRR is offline   Reply With Quote
Remove Ads
Old 07-08-2004, 11:09 AM   #2
abtech's Avatar
Images: 4
Reputation Power: 32
abtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud of
Re: True Benefits of a Ported Head
Originally Posted by victoRR
For the 929.
input?
You are going to do the porting? Not a good idea unless you have a flow bench and a couple of decades of porting experience under your belt. I have seen nice bikes destroyed with a die grinder in the wrong hands . . .
and your girlfriend too.
abtech is offline   Reply With Quote
Old 07-08-2004, 12:26 PM   #3
figment will become famous soon enough
Send a message via MSN to figment
What about a drimel tool with a cratex (sp) tip just to smooth the edges off a bit?
figment is offline   Reply With Quote
Old 07-08-2004, 1:45 PM   #4
abtech's Avatar
Images: 4
Still not a good idea unless you have all of the pertinent info regarding flow rates before and after. There are several modeling programs available to predict the consequences of "smoothing the edges off a bit", but all require a full topographical run with a laser of the example port. Most "casual tweakers" would be better off going with a Serdi or full round valve job and leaving the internal port surfaces untouched.
I'm certainly not against porting cylinder heads, but advise having a pro with an outstanding track record do the work. If you are serious about having some head work done, I would recommend Superbike Mike Engineering in Ft Lauderdale, Florida.
Old 07-08-2004, 3:50 PM   #5
stegen's Avatar
stegen has a spectacular aura aboutstegen has a spectacular aura about
or how about a 1000rr with some mods?
stegen is offline   Reply With Quote
Old 07-08-2004, 5:46 PM   #6
Baketech's Avatar
Images: 20
Reputation Power: 36
Baketech has much to be proud ofBaketech has much to be proud ofBaketech has much to be proud ofBaketech has much to be proud ofBaketech has much to be proud ofBaketech has much to be proud ofBaketech has much to be proud ofBaketech has much to be proud ofBaketech has much to be proud ofBaketech has much to be proud of
I've seen MANY cylinder heads flow worse than stock after someone "smoothed" the edges....I've also flowed heads after welding (before being ground...ie smaller ports) that performed better than stock....go figure.....
Although many a backyard engineer with a Dumore can look at a head or a manifold and "see" areas for "improvement"...in my experience porting is not an intuitive process. Except for a few gifted wizards, it is at best an empirical game based almost entirely on iteration and documentation....
The key to porting is either have an expert do it.....or have about 20 cylinder heads laying around to experiment with....
I would never touch a head with anything more aggressive than a scotchbrite without flowing it first....
Sith Apprentice
CBR929 - VFR800 - VFR800
Baketech is offline   Reply With Quote
Old 07-08-2004, 6:18 PM   #7
abtech's Avatar
Images: 4
Well put
Old 07-08-2004, 11:50 PM   #8
Machinist is on a distinguished road
Porting and Polishing works well as long as the Job is done by a qualified person, I have done this job to my 954, and it has really made the engine perform well ( Allows it to revv up a lot Quicker)I work in the Aircraft Industry
in a Turbine Engine overhaul shop so I have acess to a flow bench etc, without the proper know how and equipment you can definitly do harm I also had a custom map made to get the best out of the porting job, So it does work But have it done by a qualified person.
Machinist is offline   Reply With Quote
Old 07-09-2004, 12:40 AM   #9
I will not be doing the porting myself. I will however be removing the head and doing the labor to assemble everything myself. I will be sending the head off to a qualified individual for porting and flow bench testing.
I needed to know first hand if this is actually worth it. I wouldn't mind tearing into the engine first and foremost. I don't really want to do a power adder (nitrous or turbo). Naturally aspirated works best for me.
I will be looking for spare heads so mess around with. (bare of course)
Just an idea that ive had for some time and wanted some first hand experience feedback.
Ported head, cams, tuning.
or
954 complete engine. (low mileage)
Old 07-09-2004, 3:43 AM   #10
Reputation Power: 11
Cowboy1600 is on a distinguished road
Send a message via MSN to Cowboy1600
or
I dont think you'll be able to slot a 954 motor into a 929 frame....i think you'll be looking at a whole new bike if you want 954 power. They are 2 different bikes, not an evolution.
Poking the Devil with a stick then running away
Cowboy1600 is offline   Reply With Quote
Old 07-09-2004, 7:06 AM   #11
abtech's Avatar
Images: 4
Not so. Your namesake (Cowboy on this forum) grafted a 954 motor into his 929 last year (as have a few others) without much drama.
Old 07-09-2004, 7:21 AM   #12
Jungleboy's Avatar
Reputation Power: 12
Jungleboy will become famous soon enoughJungleboy will become famous soon enough
Actually they "are" an evoulution and are very similar, the engines being almost identical from the outside, Both have the same stroke the 954 has 1mm bigger pistons, bigger throttle bodies etc etc
2004 1000RR Racebike
www.jungleboyracing.com
Jungleboy is offline   Reply With Quote
Old 07-09-2004, 8:42 AM   #13
Baketech's Avatar
Images: 20
FYI, you will still have to assemble the head to do any effective bench work.....
Sith Apprentice
Old 07-09-2004, 7:23 PM   #14
Understood. I've had experiences with head porting on my old cars (Fox Body Mustangs 79-93 models) as well as the 99 GT I had recently. I saw good gains from doing the work myself and having them put on a flow bench.
The bike is something I don't wanna take soo lightly though. (not that the cars were for that matter).
Old 07-09-2004, 7:39 PM   #15
CBR929RE's Avatar
Images: 24
Reputation Power: 33
CBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud of
I've read that the 54 engine was just a bored out 29 so it should be dimensionally the same on the outside. as for the porting I also recommend having a good pro due it and get a good multi angle valve job too. my friend had his heads and upper and lower intake ported and polished on his 347 stroker in his mustang (he has since put on another intake, the one he shoulda bought when he built the engine had he followed the buildup I had given him) he did that and the guy who did it always does a multi angle valve job when he does the port and polish. he also put in a bigger cam at the same time and when he first fired it up this winter after doing it we could just hear how much more power it was making. so in conclusion I say do the 54 swap and port and polish that head.
CBR929RE is offline   Reply With Quote
Search tags for this page
954 ported head
benefits of porting and polishing
cbr1000rr port and polish hp
hours of labor for cbr 929 motor
how to port a motorcycle head
how to port and polish motorcycle heads
motorcycle head porting
motorcycle head porting and polishing
porting and polishing a motorcycle head
porting and polishing cylinder heads motorcycle
porting and polishing heads motorcycle
porting motorcycle heads
You may not post new threads
You may not post replies
Can you find the man's head? ND4SPD Off-Topic 14 10-17-2003 1:22 AM
Head removal advice please BlueToy Honda FireBlade 14 07-18-2003 10:38 AM
alternative head gaskets? BlueToy Honda FireBlade 2 06-17-2003 2:42 AM
True Emergency Room visits RedTalon Off-Topic 27 06-11-2003 8:19 PM
