Recommended oil level... - Honda Motorcycles - FireBlades.org
post #1 of 17 Old 07-26-2004, 8:26 PM Thread Starter
Send a message via AIM to BlaZin -=929=-
Just a quick question here,
what is the recommended amount of oil by Honda in the manual. I do not have a manual (Yes, Mike knows that he needs one bad) and the guy at the local shop just said for quarts. From my motocross experience I know sometimes its not an equal amount like "just 4 quarts." I do not want too much oil so any help would be great. Thanks
BlaZin -=929=- is offline
post #2 of 17 Old 07-26-2004, 8:42 PM
929_Nupe's Avatar
Images: 12
Send a message via AIM to 929_Nupe Send a message via MSN to 929_Nupe
Re: Recommended oil level...
3.7 at draining
3.9 at oil filter change
929_Nupe is offline
post #3 of 17 Old 07-26-2004, 8:49 PM
CBRBob's Avatar
Images: 4
Reputation Power: 15
Originally Posted by 929_Nupe
3.7 at draining
Yep........four quarts.........
CBR Bob
TeamPromotion Coach#29TPM
CBRBob is offline
post #4 of 17 Old 07-26-2004, 8:50 PM
ConqSoft's Avatar
Images: 143
Reputation Power: 36
Don't use the full 4 quarts... Keep an eye on the oil-level window on the side, and keep it between the lines. Once it gets there, run it for a while until it gets to full temperature, then check the level again when it cools down.
ConqSoft is offline
post #5 of 17 Old 09-08-2004, 9:39 PM
Images: 10
Send a message via AIM to Baba san Erion
I used 3.75 quarts in my 954 (with filter change) and it's too much,the oil covers the whole sight glass.How did honda figure 3.9?Guess i'm gonna have to drain some tomorrow.Ugh.
"Speeding doesn't kill ya,stopping suddenly does."
Baba san Erion is offline
post #6 of 17 Old 09-08-2004, 9:51 PM
Sponsor
SilverBullet's Avatar
Reputation Power: 19
3.87
SilverBullet is offline
post #7 of 17 Old 09-08-2004, 11:36 PM
Images: 5
I have the same problem. I thought I was nuts. Glad to see someone else who has seen this. I have an 03 954 as well. With oil filter change mine only takes like 3.5 quarts. I wonder if there is something taking up some volume in the motor that wasn't there when they wrote the manual.
jaim is offline
post #8 of 17 Old 09-09-2004, 6:58 PM
phobiaphobe's Avatar
Images: 169
Reputation Power: 40
I have made the same mistake before. In the manual it lists the oil CAPACITY at 3.9 litres. That isn't how much you add when you do a change though. Some oil will remain in the transmission so you'll add more like 3.1 litres. Also make sure the engine is warm before you drain that way more of the old oil will run out. It's a big pain in the ass to have to drain fresh oil after you've filled it, expecially if you're anxious to ride and you put all the bodywork back on. (not that I would ever do that ) Best thing to do is add oil slow and keep an eye on the level. LIke Conq said, fill it to between the lines then run it awhile and check the level again. Even better, put it on a stand and run it in gear. This fills the filter and transmission.
phobiaphobe is offline
post #9 of 17 Old 05-15-2011, 9:32 PM
my cbr900rr doesnt have a oil level window.when i lean it on kickstand, i cant hardly see oil in the bottom. when straight up i barely can see it . should it touch the gears?
akinca4 is offline
post #10 of 17 Old 05-15-2011, 9:34 PM
standn straight up should oil at least touch the gears? my bike doesnt have oil level window.
akinca4 is offline
post #11 of 17 Old 05-16-2011, 2:35 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Why don't you get yourself a dipstick?
Honda OEM Parts: DIPSTICK, OIL - Cheap Cycle Parts
post #12 of 17 Old 05-22-2012, 8:35 AM
Just a quick query on oil. I am just about to chage the oil again after less than a thousand miles in 7 months.
Read an article that says with frequent starts, the oil gets contaminated with water? I really am changing because it seems to have got so dirty as I view the oil through the sight glass. Is this normal?
aus45 is offline
post #13 of 17 Old 05-22-2012, 9:01 AM
Images: 2
Quoted: 2 Post(s)
Water is a byproduct of burning petrol but most of it is burned off by the heat of combustion.
I wouldn't say that was normal but it depends on lots of factors, one of which is how dirty was the previous oil?
post #14 of 17 Old 05-22-2012, 9:03 AM
Reputation Power: 110
Frequent starts without going for a decent ride will build up condensation in the oil. Fresh oil is never a bad thing
Further to post back in the 2004, those figures are in US. For litres, it's 3.5 without a new filter, 3.7 with a new filter.
Sky91 is offline
post #15 of 17 Old 05-22-2012, 9:05 AM
Many thanks for your reponse
Regards
aus45 is offline
Human Verification
Search tags for this page
03 cbr 954 oil capacity
2000 honda cbr 954 specs locations
2001 cbr900 oil type
2001 honda cbr 929 oil capacity
2003 cbr 954 oil capacity
98 cbr 900 oil capacity
cbr 900rr oil capacity
cbr900rr oil capacity
What is the best oil for my fireblade? G-Force Junkie General Discussion 5 06-28-2004 10:51 PM
Back Protectors oldgoat Riding Gear / Luggage 0 04-10-2004 7:45 AM
Oil window on 929RR JWHT Honda FireBlade 14 04-06-2004 3:45 PM
Oil change reality DevilDog Off-Topic 22 06-12-2003 10:35 AM
