Clunky shifts from 1st to 2nd
07-14-2003, 12:24 AM
Rep:  (10) Rep Power: 6
| Re: Clunky shifts from 1st to 2nd Is it normal for the gears to clunk from 1st to 2nd. Depending on speed. Also when I pop it into 1st gear from neutral, it sometimes makes a loud clunk as well. |
07-14-2003, 12:26 AM
Bike(s): 2005 1000rr Repsol, 1984 Kawasaki 750 Turbo Age: 30 Posts: 799
Rep:  (28) Rep Power: 8
| Re: Clunky shifts from 1st to 2nd New to hondas?
VERY normal. When it stops doing that, start to worry.
Ed Helbling
05 1000RR (Repsol)
00 929RR (ylw/blk)
86 Yamaha FZ750 (Ugly/Nasty)
84 Kawasaki 750 Turbo (Black/Red/Oil)
77 Puch Newport
73 Kawasaki G5 (Orange/Dirt)
02 Mazda Protege5 www.cbr929rr.com 2000 CBR 929rr FOR SALE! |
07-14-2003, 12:51 AM
Bike(s): 2002 954, 1996 F3 Smokin Joe's Age: 35 Posts: 809
Rep:  (95) Rep Power: 6
| Re: Clunky shifts from 1st to 2nd Yup, totally normal |
07-14-2003, 1:18 AM
Bike(s): Bikeless - for now Age: 61 Posts: 10,812
Rep:   (188) Rep Power: 18
| Re: Clunky shifts from 1st to 2nd Honda signature - don't worry about it . Try shifting at higher rpm's also. |
07-14-2003, 1:48 AM
Bike(s): '05 R1 Shift Red Age: 46 Posts: 576
Rep:  (15) Rep Power: 7
| Re: Clunky shifts from 1st to 2nd One thing you can do that will reduce it a bit is to preload the shift lever prior to doing your shift. |
07-14-2003, 4:05 AM
Bike(s): 2003 954 (fireblade) 149.3 Hp Age: 45 Posts: 5,183
Rep:  (28) Rep Power: 12
| Re: Clunky shifts from 1st to 2nd I thought the same thing years ago, I have learnt it is normal |
07-14-2003, 4:07 AM
Bike(s): Black/Red 954, 136.3hp bone stock Age: 34 Posts: 3,523
Rep:   (155) Rep Power: 11
| Re: Clunky shifts from 1st to 2nd It's a special feature to make it easier for you to know when you have, in fact, changed gear
Z... |
07-14-2003, 4:12 AM
| Re: Clunky shifts from 1st to 2nd Quote:
Zeeman : It's a special feature to make it easier for you to know when you have, in fact, changed gear
Z...
It's good to see you did not change while away |
07-14-2003, 3:09 PM
| Re: Clunky shifts from 1st to 2nd This is one of the reasons why it clunks so much. In 1st gear when I am on the throttle. It takes a little then surges even when I release its still going for a bit. Does this go away over time, is there a fix. |
07-14-2003, 3:18 PM
#10 | | Just repeating what ever I hear...
Bike(s): 2004 GSXR 600 Age: 31 Posts: 6,319
| Re: Clunky shifts from 1st to 2nd Quote: |
just_john : This is one of the reasons why it clunks so much. *In 1st gear when I am on the throttle. *It takes a little then surges even when I release its still going for a bit. *Does this go away over time, is there a fix.
| Surges? You revin' to 11,000? |
07-14-2003, 3:19 PM
#11 | | Resigned to pursue other interests.
| Re: Clunky shifts from 1st to 2nd The FI on the blade is real touchy, so it takes good throttle control to not be 'jumpy'. A PCIII and a good map will help with that a little. |
07-14-2003, 5:59 PM
Bike(s): 00 RC51, 03 YZ450F Age: 40 Posts: 263
Rep:  (10) Rep Power: 8
| Re: Clunky shifts from 1st to 2nd shift @ 5K or above and it will change gears much smoother
Mitch |
07-14-2003, 11:47 PM
#13 |
Joel : One thing you can do that will reduce it a bit is to preload the shift lever prior to doing your shift.
| yup that works real good. half the noise smooth feeling shifts |
07-15-2003, 12:21 AM
#14 |
Rep:  (10) Rep Power: 7
just_john : Is it normal for the gears to clunk from 1st to 2nd. *Depending on speed. *Also when I pop it into 1st gear from neutral, it sometimes makes a loud clunk as well.
| Dude!!! *Sell the bike to some unsuspecting newbie. *Your bike is a time bomb. *Literally!!!! *That clunking sound is a count down. *tick-tock -- tick-tock -- tick-tock...
BTW -- I just wanted to give you a different view point. *FWIW, your mileage may vary, don't run with sissors near a swimming pool withing 1/2 hour of eating... |
07-15-2003, 11:22 AM
#15 |
Heavy-Dee : Quote (just_john @ July 14 2003, 2:09pm)This is one of the reasons why it clunks so much. *In 1st gear when I am on the throttle. *It takes a little then surges even when I release its still going for a bit. *Does this go away over time, is there a fix.
| Surges? *You revin' to 11,000?
No the surge of gas comes at about 3000 rpm. And when I let off the gas it still goes a little then drops. |
07-15-2003, 3:53 PM
#16 |
Bike(s): 2001 Y/B 929 Age: 35 Posts: 198
just_john : Quote (Heavy-Dee @ July 14 2003, 11:18am)Quote (just_john @ July 14 2003, 2:09pm)This is one of the reasons why it clunks so much. *In 1st gear when I am on the throttle. *It takes a little then surges even when I release its still going for a bit. *Does this go away over time, is there a fix.
No the surge of gas comes at about 3000 rpm. *And when I let off the gas it still goes a little then drops.
Sounds like the HTEV. |
07-15-2003, 4:01 PM
#17 |
Bike(s): CBR954, VFR800, ST1300 Posts: 377
Rep:  (19) Rep Power: 7
Totally normal and will continue that way. *Below 3000 you are lugging the engine. *As you pass 3000 on the way up the engine finally gets a breath and takes off like it is supposed to.
At least that is my understanding.
People - correct me if I am wrong - it has happened before. |
07-15-2003, 8:25 PM
#18 |
Bike(s): 2003 Black/Red CBR954RR Age: 44 Posts: 595
| Re: Clunky shifts from 1st to 2nd Like everyone said, the clunking is normal on Hondas. My 954 is a clone of my 99 F4 in the way it shifts.
When you shift gears, it helps if you are matching the rpm's with the throttle hand before you release the clutch. It smooths everything out.
I'm not sure about the surge you're talking about. Is your throttle sticking? When you twist the throttle, make sure that the throttle isn't sticking. Make sure it releases back to its' original position immediately. If your grips get pushed up against the guard, it will stop your throttle from spinning freely.
Good luck with the new bike. Enjoy the Honda experience! |
