What is max battery leakage current for 929?
Old 09-20-2004, 4:06 PM
Bike(s): Honda 929
Rep: sinbad is on a distinguished road (10)
After repairing some crash damage, I measured leakage current (between negative battery terminal and negative battery cable) and got 1.8 mA (milliamps). No electrical components were damaged or replaced.
Service manual specifies the maximum leakage current to be 0.2 mA.
After pulling all the fuses on by one, pulling the Clock fuse dropped the leakage current down to 0.6 mA.
Only electrical mod that I have is a Power Commander.
Do I have to keep looking for another short, or is 0.6 mA leakage as low as I can expect to go?
sinbad is offline
View sinbad's Profile View sinbad's Gallery Find More Posts by sinbad
Old 09-21-2004, 9:22 AM
Bike(s): Honda 929
Re: What is max battery leakage current for 929?
Will someone please test their leakage current and post the result?
With ignition off, just remove the seat, disconnect the negative battery cable and then connect your voltmeter (set up in amp-meter configuration) between the negative battery terminal and the negative battery cable. Wait about 30 seconds for the reading to stabilize. It will read about 3-6 mA, and then drop.
Thanks.
sinbad is offline
Old 09-21-2004, 9:37 AM
Bike(s): none
Rep: figment will become famous soon enough (64)
Send a message via MSN to figment
what you are seeing is probably the result of error in your meter based on the delta from the clock being removed. I'd say your system is fine.
figment is offline
View figment's Profile View figment's Gallery Visit figment's homepage! Find More Posts by figment
Old 09-21-2004, 3:25 PM
Bike(s): Honda 929
So 1.8 mA leakage is OK? I waited 2-3 minutes after removing the clock fuse.
sinbad is offline
Old 09-21-2004, 10:29 PM
dB
Bike(s): 929, EX250rrr
Rep: dB will become famous soon enoughdB will become famous soon enough (107)
My all stock '01 929 with no electrical mods measures 1.87mA with the clock fuse in, and 0.59mA with the clock fuse out. Almost identical to your numbers.
dB is offline
View dB's Profile View dB's Gallery Find More Posts by dB
Old 09-22-2004, 1:07 PM
Bike(s): Honda 929
Thanks very much for your efforts!
sinbad is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 7:43 PM.
