| Re: HELP High pressure fuel line... ...untill you had me running to the autoparts store at 4:30pm in BFE Michigan looking for metric crush washers But seriously, it is ALWAYS recommended to replace crush washers, when you tighten them down, they form to the sealing surfaces, if the happen to be a bit irregular, they can leak the next time you use them. At a minimum, surface the used on on a flat file untill they are totaly flat. $1.00 in washers is cheaper than a 50 psi fuel sprinkler on your motor.
Mike |
