Smoke on Startup - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 03-20-2006, 4:18 PM Thread Starter
Reputation Power: 11
Smoke on Startup
After my bike sits for a few hours, It will smoke for about two minutes when I start it. I just bought it about two weeks ago, and I swear when I started it, there wasn't any smoke. Either way, I figure I'm hosed and need new piston rings. I've never tore into an engine other than to adjust valves, so I'm a little reluctant. Also, I noticed there is too much oil in the bike. Could this be the cause of the smoke? What do you guys think? Bad rings? How hard is it to get to them? Does the motor have to be pulled? Any help is appriciated(sp?)
Thanks
Flycal6 is offline
post #2 of 9 Old 03-20-2006, 4:29 PM
Custom900's Avatar
Images: 13
Reputation Power: 15
Send a message via AIM to Custom900
Re: Smoke on Startup
Try doing a tune-up and oil change.
What model and year bike is it and does it have fuel injection or carbs?
That will help with a solution.
I don't think you have a ring problem because the smoke stops after warm-up.
What color is the smoke?
Custom900 is offline
post #3 of 9 Old 03-20-2006, 4:36 PM
clutchslip's Avatar
Images: 1
Thanks
Well, yeah, duh.
Year, mileage, service record, abuse, whatever. Just a tad more info AFTER you get the oil level normal.
It's better to live and learn than to just learn. - My very own oxymoron.
clutchslip is offline
post #4 of 9 Old 03-20-2006, 4:42 PM
phobiaphobe's Avatar
Images: 169
Reputation Power: 40
Drain some oil out. If you have too much it will blow by the rings and create smoke. You'll probably need to change your spark plugs, but you might not have to rebuild the engine.
phobiaphobe is offline
post #5 of 9 Old 03-20-2006, 4:45 PM Thread Starter
It's a 2k cbr929rr with 29,000 miles, a salvage bike that I just got road worthy a few days ago. There is some engine noise during cold idle, but from what I read on this site, that seems to be pretty normal. I'm not sure of the smoke color, I'm color blind, but I can smell the oil, so it's probably blue (it's definitely not black or white smoke).
I've been told it was mainly a commuter bike with some 2up riding in the mountains, and never stunted, but I don't know if that is true or not.
Flycal6 is offline
post #6 of 9 Old 03-20-2006, 4:47 PM Thread Starter
I'll drain some oil today. I'm optimistic about the engine because it pulls REALLY strong and runs great, just a little worried because the bike is brand new to me.
Flycal6 is offline
post #7 of 9 Old 03-20-2006, 6:23 PM
Custom900's Avatar
Images: 13
It's a Honda, It'll prove to be a great bike for a long time. That really isn't a huge amount of miles.
If you can smell the oil then I would bet on it blowing into the filter. That's likely where the smoke is coming from.
The CBR's are good bikes. I ride an older 900 and wouldn't think twice about going anywhere on it.
post #8 of 9 Old 03-21-2006, 4:25 AM
Reputation Power: 12
if the smoke is white, it just condensated water in the exhaust. it comes from air when the exhaust cools down. if the smoke is blue it's engine oil.
if it's black it's too rich mixture.
if it's white like I assume it is. IT'S NORMAL.!
JakeT:
JakeT is offline
post #9 of 9 Old 03-21-2006, 4:42 AM
Repeater's Avatar
Images: 2
my f4i does this a bit on startup. no worries though as above it is normal
Repeater is offline
Human Verification
Search tags for this page
bike smokes when started
does a motorcycle smoke when starting
motorcycle smokes after warm up
motorcycle smokes on start up
motorcycle smokes on startup
motorcycle white smoke on startup
smoke when starting motorcycle
white smoke from exhaust for 954rr during idle
white smoke in bikes on startup
white smoke on startup motorcycle
Redline right after startup literbike General Discussion 29 05-28-2005 3:01 PM
954 rich at startup JakeT Honda FireBlade 10 05-13-2005 2:07 AM
black smoke ashkicker Honda FireBlade 10 01-18-2005 8:34 AM
Second hand smoke Schwaberts Off-Topic 8 11-17-2004 2:52 PM
Engine noise/very rough idle at startup Mavic Honda FireBlade 15 05-23-2004 8:22 AM
