Bike not starting - need some troubleshooting advice...
Old 03-29-2006, 10:43 AM
Bike(s): 2000 929RR
Rep: Duster929 has a spectacular aura aboutDuster929 has a spectacular aura aboutDuster929 has a spectacular aura about (226)
Ok, this is a bit of a long story, but I think there are some details in the story which are important to figuring this out.
The bike is a 2000 CBR929, so it's got about 6 years on it. About 15,000 miles. Has run absolutely problem-free for the couple of years that I've owned it.
I put it away last winter, it was running absolutely perfectly. Never had a problem starting it, even when I took it out of storage in the spring of '05. When I put it away in the fall, I took the battery out, put it in my heated basement, and had it plugged into a battery tender for most of the winter. About a month ago I was moving stuff around in the basement, and unplugged the battery tender (the light on the battery tender was green, "fully charged"). When I wanted to take the bike out over the weekend, I plugged the battery tender in again, saw the red light on the battery tender, and thought "Well, maybe it's not fully charged, but it was fully charged just a month ago and it's heated here, it should still have enough juice to start the bike."
I took the battery to the garage, plugged it into the bike, and tried to start it. I got a rapid series of electrical clicks (is that the relay?), but no turning over, no starting. I then realized that I had connected the Power Commander to the positive instead of the negative terminal of the battery (is this a serious mistake?). I switched the Power Commander lead to the negative terminal, and tried again. More clicking. No turning. I figured, the battery must be dead.
I plugged the battery back in to the Battery Tender and left it until the light turned green. Put it back on the bike, and connected everything properly. This time, the engine started turning, but wouldn't fire, wouldn't "catch". I tried a few more times, until chug-chug-chug, it wouldn't even turn over any more. I figured the battery was dead again. Plugged it back into the Battery Tender for a while, until the light turned green again. Went to start the bike again, and this time it turned over, and started! The bike ran great. I let it run for a while, until it could get warmed up, and maybe charge the battery a bit more on its own. Let it run for about 10 minutes.
I turned the bike off, and had a few other things to do before taking it for a ride. After about 20 minutes, I tried to start it again. Chug-chug, the engine turned, but no start. I tried a few more times until the starter wouldn't turn any more, and figured the battery was dead again. Plugged it back into the battery tender. When the light turned green, I tried starting the bike again, it fired right up, and I went for a ride.
I was cautious about shutting it off, as I wanted the battery to charge. I rode around for probably about an hour, and figured that should do the trick. I was downtown, parked the bike, shut it off, and had some lunch. When I came back to the bike, lo and behold, it wouldn't start. The engine turned, but wouldn't fire. Now I'm convinced that the battery is just too old - maybe it's the original battery, so it's 6 years old. I figure it's had a good life, and I'll buy a new one. I called CAA to give me a boost - the bike started up with no problem at all once hooked up to the jumper cables. I probably could have bump-started it, but I've never done that before, and didn't want to try it for the first time in city traffic.
I rode home without any problem. The next day (yesterday), I went out and bought a new battery. I took it home, plugged it into the battery tender just to make sure it was fully juiced. It was showing a green light, but I left it on for an hour or so just for good measure. I hooked up the new battery to the bike, and when I turned the key, the fuel pump noise sounded strange - not it's usual "tone". I thumbed the starter, and got the rapid clicking again - not even the turning of the motor. I turned it off, then on again, and the fuel pump sounded normal this time. I hit the starter button, and it turned the engine, but didn't catch.
Now, whenever I try starting it, I get either clicking or some turning, but no starting.
What could be the source of this problem? I know it's not the battery, as it's new and charged. I also know it's not spark plugs, fuel, or anything mechanical, as the bike started up on the first try when hooked up to jumper cables. The problem is electrical in nature, I'm pretty sure, but I'm not good with electrics, so I could use a bit of help here.
Could it be battery? Connections? Starter? What other electrical components are there that I should think about? Could I have damaged something by hooking up the "ground" cable from the Power Commander to the positive battery terminal instead of the negative?
Any advice/help would be appreciated. Thanks.
--- D
Duster929 is offline
View Duster929's Profile View Duster929's Gallery Find More Posts by Duster929
Old 03-29-2006, 12:21 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud of (1091)
Re: Bike not starting - need some troubleshooting advice...
Try disconnecting the Power Commander completely and see if that solves the problem. If not, there is a slight chance that the battery you bought may have been an oldie sitting on the shelf for years. Good luck...let us know what you find out.
Red Rider is offline
Old 03-29-2006, 12:25 PM
Bike(s): 2000 929RR
K, I'll try that. I don't think the battery I bought is old, as it's from a dealership that moves a lot of volume, so I think they sell a lot of batteries. Also, when I plugged in the battery, straight from the shop, the battery tender read "green", indicating it was fully charged.
I'll try detaching the power commander.
--- D
Old 03-29-2006, 12:53 PM
Bike(s): CBR 980
Rep: Jake is on a distinguished road (30)
It sounds that the battery you bought was not properly conditioned (charged). I've heard of several ways of charging new batteries, one being a rapid charge. Also, when you let your bike idle, it idles below 4k, which means your stator is NOT charging your battery. Another thing I would recommend looking at is your spark plugs. After loading the cylinders with fuel from not starting, I'm guessing they are fouled, resulting in poor spark, and harder starting.
Bike Pics]My bike
Jake is offline
View Jake's Profile View Jake's Gallery Visit Jake's homepage! Find More Posts by Jake
Old 03-29-2006, 12:55 PM
Bike(s): CBR 980
Oh yeah, forgot to mention, I too have hooked the ground terminal of a PC up to the positive terminal, did not harm the unit. I'd hope that Dynojet installed a diode to prevent any damage to the circuitry in the event of this happening.
Bike Pics]My bike
Jake is offline
Old 03-29-2006, 1:54 PM
Mmmm, I wonder.....
allred's Avatar
Bike(s): 1984 650SC Nighthawk. 2002 954 (SOLD).
Rep: allred will become famous soon enough (78)
Originally Posted by Duster929
I got a rapid series of electrical clicks (is that the relay?), but no turning over, no starting. the engine started turning, but wouldn't fire, wouldn't "catch". I tried a few more times, until chug-chug-chug, it wouldn't even turn over any more.
Sure sounds like a simple case of a battery which is either too old, or simply won't hold a charge. We ask a lot of these little batteries, especially when the bike is stored each winter, and I have my suspicions about the "quality" of some new batteries (sometimes long shelf life, or incorrect initial preparartion/charging). My bet is that if you get a new battery your problems will go away.
allred is offline
View allred's Profile View allred's Gallery Find More Posts by allred
Old 03-29-2006, 2:28 PM
Bike(s): 2000 929RR
Yeah, that's the problem... this IS a new battery... Could it just be defective? How can I determine that or test that or prove it to get a new one under warranty?
--- D
Old 03-29-2006, 2:37 PM
Mmmm, I wonder.....
allred's Avatar
--- D
I have a similar problem with mine. The battery that came with the bike lasted 3 years.....about what you would expect. Then I replaced it a year ago, but the new one is starting to show signs of failure. Like you I keep it on a charger when the bike is not being used, and it charges 15 minutes each day. But I am finding that the bike will start straight from the charger, but sometimes it is reluctant to re-start during a ride. I have read on this forum of others who have had "dud" batteries, ones that last only 9-15 months, way less than they should. I can only put it down to batteries which have been sitting on the dealers shelf too long, or batteries which were not properly prepared/charged when new.....or both!
I think you should be able to take it back to where you bought it and do a voltage drop test on the battery to test its capability. I need to do the same as my year is up in 8 days. But looking at my receipt it says that the battery is only warrented for 6 months, and then pro-rater after that
allred is offline
Old 03-29-2006, 2:43 PM
Bike(s): 2000 929RR
Yeah, they told me I have a 6 months warranty on the battery, which is the standard across different makes/brands.
--- D
Old 03-31-2006, 11:09 AM
Bike(s): 2002 CBR954RR
Rep: Island Moose is on a distinguished road (24)
Take it into a shop as was suggested above and have it tested. I'll bet you just need a new one.
Island Moose is offline
View Island Moose's Profile View Island Moose's Gallery Find More Posts by Island Moose
Old 04-03-2006, 11:47 AM
Bike(s): 2000 929RR
Update for those reading the thread with a similar problem - took the battery back to the shop and they told me it hadn't been charged properly by them to begin with. They gave me a new one which had been charged properly, and it worked fine.
No problems with the bike.
Thanks for the advice guys.
--- D
Old 04-03-2006, 12:57 PM
nhfirefighter13's Avatar
Bike(s): 2001 929
Rep: nhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to beholdnhfirefighter13 is a splendid one to behold (864)
Send a message via AIM to nhfirefighter13 Send a message via Yahoo to nhfirefighter13
Correct me if I'm wrong, but aren't the Yuasa batteries for the 929 factory conditioned out of the box?
My guess on the problem here is that depending on the model Battery Tender charger you own, you may have damaged the battery. Unless you but the more expensive of the chargers, you're buying a trickle charger that will not stop charging the battery, despite whatever the packaging says. You need to make sure that the charger you have stops charging when the battery is full. Yuasa makes a nice one for about $50 that does a weekly test (I think it's weekly) and will only start charging the battery again if it drops to below 80%.
nhfirefighter13 is offline
View nhfirefighter13's Profile View nhfirefighter13's Gallery Visit nhfirefighter13's homepage! Find More Posts by nhfirefighter13
Old 04-03-2006, 1:13 PM
Bike(s): 2000 929RR
Nope, didn't damage it. The store had a bunch of problems with batteries not being charged. They weren't Yuasa batteries.
My battery tender stops charging when complete.
Old 04-03-2006, 1:17 PM
Bike(s): 2001 929
Ahh ok.
Just my opinion but the Yuasa batteries (at least for the 929), while slightly more expensive, are the way to go. Take em out of the box, pop em in the bike and go. I just had to replace the original one in my 929 after almost 6 years of use and abuse (I've never stored my battery off the bike or on a tender over the winter.)
Old 04-03-2006, 1:51 PM
  #15
Bike(s): 2000 929RR
My Yuasa lasted 6 years too. I was impressed. We'll see how long the no-name lasts. If it lasts half as long as the Yuasa, I'm still ahead of the game, as I can buy 2 of them for the price of one Yuasa.
--- D
Old 10-19-2009, 12:25 PM
  #16
Bike(s): 2003 Honda CBR 954 RR
Rep: honda954 is on a distinguished road (10)
I have a 2003 Honda 954 RR, it has been sitting up almost a yr so i tried to start it one day but nothing so i figured the battery was bad. I bought a new new one and put it on, no lights, blinkers will not work nor will it turn over or start. So i took the battery back and got another one that has a lifetime warranty on it and the same problem. I have an alarm on it so when i connect both positive and negative there is a quick siren then it stops so i know it has to be working as far as a battery but puzzled as to what could be the problem. Checked all my fuses and they are all good, can anyone tell me what could be the problem? I have not driven my bike for a minute and this is frustrating that it will not start just because it has been sitting up for almost a yr?
honda954 is offline
View honda954's Profile View honda954's Gallery Find More Posts by honda954
Old 10-19-2009, 1:09 PM
  #17
Bike(s): 2k 929rr & 99 R6 Fighter
Rep: BurtonF166 is a jewel in the roughBurtonF166 is a jewel in the roughBurtonF166 is a jewel in the rough (268)
Check your connections all around for corrosion.
Is the ignition connected?
BurtonF166 is offline
View BurtonF166's Profile View BurtonF166's Gallery Visit BurtonF166's homepage! Find More Posts by BurtonF166
Old 10-19-2009, 1:18 PM
  #18
As far as i know, i have not unconnected it? Where can i check, itz jus wierd how it will not do anything n all it has been doing is sitting up? Seems like the lights or blinkers should work, i knew something was wrong when i turned the ignition to on and no lights came on. I've had it in the rain before and never had a problem starting so I'm really confused on this one?
honda954 is offline
Old 10-19-2009, 1:21 PM
  #19
Yeah it is unlikely that the connections are poor enough for nothing to come on.
You said you've checked fuses, but that still seems like it must be the culprit.
Old 10-19-2009, 1:32 PM
  #20
There is one thing i have not checked, its like a black plug that fits in a groove with a rubber house. I could not figure out how to get it apart without breaking it plus the lighting was bad for me in the garage. I'm really trying to figure this out before taking it to the dealership, they have been the only one working on it since i bought it new. I was thinking maybe it would not start because the kickstand was down, on mine it will not start when it is down. Tried that and still no luck.....
honda954 is offline
Old 10-19-2009, 3:11 PM
  #21
the kickstand switch would not cause you lights to remain off.
The black plug, is it behind the battery?
Old 10-19-2009, 3:18 PM
  #22
Yes i know, i was checking to make sure from a past situation. I have basically tried simple stuff but really frustrated what it could be?
Yes, there is also a single fuse behind it which i've already checked. Not sure if a fuse is in it or not?
honda954 is offline
Old 10-19-2009, 4:32 PM
  #23
I think its a 30A fuse, not sure though. May be the main one?
Old 10-19-2009, 4:38 PM
  #24
Would that be the reason for my issue? I was trying to open it last night but was unsuccessful, didn't want to break it until I was able to get some better lighting in my garage.
honda954 is offline
Old 10-20-2009, 1:02 AM
  #25
Could be. If the battery is good, and NOTHING lights = fuse.
Old 11-03-2009, 3:49 PM
  #26
Hey BurtonF166, jus to let u know dat i found the problem with my bike. It was the black plug behind the battery we were talking about n once i had more light, i was able to open it up. There was a 30 amp fuse behind it n soon as i pulled it out i could see it was burned through and soon as i replaced it, the lights n blinkers worked and it fired right up. But i did take the advice and disconnected the alarm completely before i found the problem. After i got it started n everything n let it run for a min, i turned it off and reconnected everything n it is working fine. Funny how sumthin simple could be a big problem, again thx to everyone who gave their inputs to help me out. I really appreciated the help.........
honda954 is offline
Old 11-03-2009, 3:54 PM
  #27
Thats awesome!
Hope you got some nice weather so you can get some miles in.
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 2:06 PM.
