Type of Antifreeze Coolant you use? - Honda Motorcycles - FireBlades.org
post #1 of 18 Old 04-07-2006, 2:49 PM Thread Starter
Robert3RR's Avatar
Images: 4
Reputation Power: 12
Hey guys I just wanted to know what type of Antifreeze Coolant you use on your 954RR? Thanks
Robert3RR is offline
post #2 of 18 Old 04-07-2006, 3:37 PM
Administrator
Red Rider's Avatar
Images: 20
Reputation Power: 44
Re: Type of Antifreeze Coolant you use?
I used to use the Honda pre-mix coolant (switched to Water Wetter). Not as cheap as other brands, but it worked well and took out the guesswork.
Red Rider is offline
post #3 of 18 Old 04-07-2006, 3:54 PM Thread Starter
Robert3RR's Avatar
Images: 4
thats what I use Honda pre-mix coolant..Someone told me that he uses the regular antifreeze like for cars on his bike it was bout a year ago...anyways will that car antifreeze hurt your bike?
post #4 of 18 Old 04-07-2006, 3:57 PM
smoothrideronli's Avatar
Images: 1
Reputation Power: 15
Yes. I believe it damages the seals in the water pump.
smoothrideronli is offline
post #5 of 18 Old 04-07-2006, 4:18 PM
Administrator
Red Rider's Avatar
Images: 20
It depends on the brand. You have to use the silicate-free version otherwise it will do a number on the water pump seals. Not sure if it's the green or the orange colored stuff...
post #6 of 18 Old 04-07-2006, 4:25 PM
AMTFGH's Avatar
Images: 2
Reputation Power: 11
Coolanol
AMTFGH is offline
post #7 of 18 Old 04-07-2006, 4:26 PM Thread Starter
Robert3RR's Avatar
Images: 4
I kinda knew that its bad to use the car coolant stuff...I told that guy bout how bad it is but he kept talking like he knew everything...oh well
post #8 of 18 Old 04-08-2006, 10:29 AM
honda manual says high quality ethanol glygol. which is pretty much the basic green stuff, and when releasing the old fluid which was factory original, it was the same green stuff. it's suitable for aluminium engines.
Automotive parts dealer warned me to not to use the red stuff if that is not what the manual says.
JakeT.
JakeT is offline
post #9 of 18 Old 04-08-2006, 11:56 AM
Images: 8
Green stuff is primarily antifreeze-proper coolant is distilled water and water wetter-IMO. just remember to put the green stuff back for the winter-if it freezes where you are-then I use the Honda stuff
Linus is offline
post #10 of 18 Old 05-07-2006, 3:31 AM
phobiaphobe's Avatar
Images: 169
Reputation Power: 40
Just switched to distilled+wetter.
Does WW lose its effectiveness if you use too much? Cuz I used about half the bottle.
phobiaphobe is offline
post #11 of 18 Old 05-07-2006, 4:51 AM
Images: 3
Green
machinehead is offline
post #12 of 18 Old 05-07-2006, 8:24 AM
HondaGalToo's Avatar
Images: 16
Reputation Power: 29
You should mix it up as it states on the container. You don't use much. It's 1 ounce (3-4 capfuls) per quart of distilled water. You definitely shouldn't have poured in half a bottle. More isn't better. I'd dump it if I were you and replace it with the correct mixture as stated above.
HondaGalToo is offline
post #13 of 18 Old 05-07-2006, 1:00 PM
Images: 169
Ya the whole system is only about 4 quarts. Maybe I'll just drain a couple and add water.
post #14 of 18 Old 05-07-2006, 1:11 PM
jetbdude's Avatar
Images: 58
Reputation Power: 25
Send a message via AIM to jetbdude
¨If a little do a little good, a LOT must do a lot of good¨
Phobiaphobe
jetbdude is offline
post #15 of 18 Old 05-07-2006, 1:16 PM
Images: 169
Human Verification
Search tags for this page
can i use car coolanrt in my motorcycle
honda cbr1000rr coolant
honda cbr900rr coolant type
honda motorcycle antifreeze
honda motorcycle coolant color
honda motorcycle coolant type
quality of coolant for cbr 954 rr
what kind of antifreeze does a 2008 cbr600rr take
what type of antfreeze do you put in motorcycles
what type of coolant goes in to a 83 honda cx650c
What Type of Oil Do you use on your 929 fan22 Honda FireBlade 95 08-15-2013 11:28 PM
Type of oil you use for your 54? PATBAROK Honda FireBlade 47 04-11-2006 10:54 PM
What Type of Oil Do you use on your 954?? Robert3RR Honda FireBlade 35 08-24-2005 12:07 PM
Do you like the taste of antifreeze? Newfie TLR Off-Topic 6 07-22-2005 7:26 PM
