| Honda FireBlade Discussion of the Honda CBR 900RR, Honda CBR 929RR, Honda CBR 954RR, and Honda CBR 1000RR Motorcycles. |
07-05-2006, 11:08 AM
200 rear tire
can I fit a 200 tire on my 2000 929,currently 190 will it change the ride much,I am a flatlander so twisties are rare,gotta look hard but can find a few,most of the riding I do is on our long straight highways.
07-05-2006, 11:12 AM
Reputation Power: 43
Re: 200 rear tire
The handling will definitely be affected. Your gas mileage might drop slightly as well since you're increasing contact patch. It's also possible that you might get some tire rubbing on the swingarm as well.
07-05-2006, 11:18 AM
Reputation Power: 12
Re: 200 rear tire
If the bike came equipped with a 190 then you have no problems going up 10mm. However, the handling will act as if you are riding on a tire flattened out by a million miles of highway - Sounds like you're used to that though.
Freedom of Speech
07-05-2006, 11:40 AM
Reputation Power: 36
Re: 200 rear tire
Saskatchewan?
07-05-2006, 12:08 PM
Reputation Power: 8
Re: 200 rear tire
Your handling will def. get heavier.
07-05-2006, 12:18 PM
Re: 200 rear tire
thanks for the advice ,I think I will stick with the 190,anyone tried a shinko tire this one is a 005 it looks a little more street than the 003?
07-05-2006, 1:22 PM
Re: 200 rear tire
Shinko is a Drag Radial.
I hate to say it, but Shinko is junk. The heat cycle is terrible. All the guys I've been racing with have switched to Michelin Pilot Powers.
Oh, and the Shinko won't shed water well if you get caught in a storm.
Freedom of Speech
07-05-2006, 3:24 PM
Reputation Power: 15
Re: 200 rear tire
 I sell both tires. The Shinko R005 is a street tire, not drag radial. The Shinko R003 is a street/drag radial. You can not beat the performance the Shinko R003 gives you on the track for the money, and I have never spun using the R003 Ultra Soft compound! I use them from fresh to no line in the middle.
You are correct about them not being good in the rain. I have riden mine (when getting stuck in the rain) and I didn't push it b/c I know it doesn't have the groove pattern for wet roads.
If you want something other than a Shinko for drag racing, go with the Mickey or Pirrelli. For the money and the way the Shinko R003 U-Soft hooks, you can not beat it!
The Pilot Powers are more rounded so less contact patch on the ground for drag racing.
07-05-2006, 4:23 PM
Re: 200 rear tire
Don't get me wrong, the Shinko hooks hard for about 1 full weekend of racing. After that they need to be tossed.
As for the Michelin having less contact patch, you're right. That tire is still a monster though. Just imagine what that tire would do if you could put about 3 inches of contact on the ground.
Freedom of Speech
07-05-2006, 9:56 PM
Re: 200 rear tire
I've used the regular R003 for 2 seasons and wore them completely out with a once in a blue moon spin off the line.....
The Ultra soft...I have never spun, and I do wear them completely out where there is no groove in the center.
You might could get that much contact on the ground with the powers if you took it down to 5 lbs of air, but you wouldn't have much mph.
07-06-2006, 12:07 AM
Re: 200 rear tire
What is your local track doing for prep?
Freedom of Speech
| Search tags for this page |
200 rear 900rr, 900rr 200 rear tire, 929rr 200 rear tire, can a 200 series motorcycle tire fit on a 900rr, can i fit a 200 tire in a honda cbr 954?, cbr 900rr 200 rear tire, cbr whif a 200 tire, forums bikes 200 rear tire, if a 200 tire would fit on the 929, will a 200 rear tire fit a 04 honda 1000rr, will a 200mm tire fit my cbr 1000rr, will a 200mm tire fit on a 2008 cbr1000rr
You may not post new threads
You may not post replies
