engine running hot
Old 08-29-2006, 6:23 PM
Bike(s): 2002 cbr 954
Rep: shonjuan is on a distinguished road (10)
engine running hot
I have a '02 954 and my fan motor went out and the engine ran hot.I replaced the fan motor and it still runs hot.Any idea what I might need to check?
shonjuan is offline
View shonjuan's Profile View shonjuan's Gallery Find More Posts by shonjuan
Old 08-29-2006, 6:42 PM
Das Ende ist hier
seamus's Avatar
Bike(s): One
Rep: seamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud of (1425)
Re: engine running hot
Did it dump coolant? If so, it may be low or have some air trapped in it somewhere.
Did you reconnect the fan? Not trying to make you sound stupid. When I swapped my exhaust, I forgot to reconnect the fan and got stuck in traffic on my next ride. Needless to say, it made for some fun roadside troubleshooting.
seamus is offline
View seamus's Profile View seamus's Gallery Find More Posts by seamus
Old 08-29-2006, 6:47 PM
Yea in dumped coolant through the overflow.I did did recheck the fan to see if it was coming on and it is.If I'm on the highway it does not get but as soon as I exit and stop at a red light, it goes up.
shonjuan is offline
Old 08-29-2006, 6:51 PM
Going into turn one
sheepofblue's Avatar
Sound like an air pocket or low coolant for the first try.
Send maple
sheepofblue is offline
Old 08-29-2006, 6:59 PM
I hope it is something as simple as a air pocket.Any1 have a idea on how to get the air out?Thanks!
shonjuan is offline
Old 08-29-2006, 7:00 PM
Das Ende ist hier
seamus's Avatar
Bike(s): One
Yep. If it dumped, it's low. Top it off, burp it to get rid of the air in the system and it all will be right with the world again.
The reason it's not running hot on the highway is due to the extra airflow over the radiator and engine. As soon as you slow down or stop, you lose the airflow and its cooling effects.
seamus is offline
Old 08-29-2006, 7:06 PM
Thanks for the info, I thought I topped it off but I guess I didnt.I'll try again.
shonjuan is offline
Das Ende ist hier
seamus's Avatar
Bike(s): One
Pull your panel off, pop the radiator cap off. Top off the fluid to the bottom of the neck, just below the hose to the overflow bottle.
Start the engine. Give it a couple of quick short twists of the throttle. If the level goes down, top it off and do it again. Put the radiator cap back on. Take if for a spin to get it up to operating temp. Shut it down [edit: let it cool down a bit] and pop the cap again to check the level. If it went down again, top it off to the bottom of the neck again.
Start it back up and give it a couple of quick twists. If the level goes down again, repeat all the above.
Last edited by seamus : 11-19-2006 at 9:34 PM. Reason: edited to correct procedure for future use.
seamus is offline
Old 08-29-2006, 7:08 PM
Going into turn one
Start the engine. Give it a couple of quick short twists of the throttle. If the level goes down, top it off and do it again. Put the radiator cap back on. Take if for a spin to get it up to operating temp. Shut it down, let it cool and pop the cap again to check the level. If it went down again, top it off to the bottom of the neck again.
Send maple
Old 08-29-2006, 7:15 PM
Das Ende ist hier
seamus's Avatar
Bike(s): One
That might actually be my first useful post.
seamus is offline
Old 08-29-2006, 7:43 PM
Bike(s): Working on it.
Rep: Gigolo Jason is on a distinguished road (32)
Propylene Glycol, all you need to know.
Gigolo Jason is online now
View Gigolo Jason's Profile View Gigolo Jason's Gallery Find More Posts by Gigolo Jason
Old 08-29-2006, 10:17 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to behold (814)
Take if for a spin to get it up to operating temp. Shut it down and pop the cap again to check the level.
Let it cool down some first before opening the cap...
Red Rider is offline
Old 08-30-2006, 2:42 AM
Yup that was excatly the problem.Whew I'm glad it wasent anything major.Thanks again for the info.
shonjuan is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:31 AM.
