full throttle in first and second gear...what to expect?
12-10-2006, 12:41 PM
Bike(s): 2006 CBR1000RR Posts: 7
| full throttle in first and second gear...what to expect? I've got 200 miles on my 2006 cbr1000rr during break in. I've accellerated 3/4 throttle up to about about 7500 rpm in second gear. What can I expect as far as wheel spin and wheelies when under full throttle accelleration in first, second, and third gears. I'm really curious to know. Thanks for the help! |
12-10-2006, 12:45 PM
Bike(s): Puch Posts: 14,391
| Re: full throttle in first and second gear...what to expect? Both depending on the conditions. Be careful.
Please remember, don't talk about illegal activity (such as wheelies) on this site. |
12-10-2006, 12:50 PM
#3 | | Going into turn one
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,845
| Re: full throttle in first and second gear...what to expect? The trick will be to roll on the throttle vs ham fisting it. Throttle control will minimize spin and wheelies while maximizing acceleration
Also since you asked I figure this is a new type of bike so as LTL says be careful. Wear great gear all the time and avoid riding with people that ride over their heads on public roads (everyone tends to follow stupid some  )
Enjoy
Send maple |
12-10-2006, 1:15 PM
Bike(s): 2001 929RR Knightrider Black Posts: 354
Rep:  (71) Rep Power: 3
| Re: full throttle in first and second gear...what to expect? Things start coming at you very very quick!!!  |
12-10-2006, 3:20 PM
Bike(s): 06 1000RR Posts: 88
Rep:  (10) Rep Power: 3
| Re: full throttle in first and second gear...what to expect? Wheel spin shouldn't be too much of a concern once the tires are warmed up and if the roads are dry. However, wheelies on the other hand will happen easily if you aren't careful, I found when I first got my bike the front end would lift at about 7k rpms and now that it's broken in it will lift the front end at 5k. But then again I'm 220lbs so if you are lighter it's gonna come up that much faster.
Be careful when you're banging the gears, I snapped 3rd after redlining 2nd and almost sh*t my pants cause the front tire was heading for the sky. On a closed course road....of course. |
12-10-2006, 3:35 PM
Bike(s): cbr1000rr in rattle can black Age: 40 Posts: 903
Rep:  (75) Rep Power: 4
| Re: full throttle in first and second gear...what to expect? Expect severe problems keeping the front wheel down the first 130mph.
The heavier you are, the more weight will be levered over the rear axle: meaning more wheelies. Your center of gravity will be MUCH higher. |
12-10-2006, 6:22 PM
Bike(s): 2006 CBR 1000RR in the only real color, black Posts: 210
Rep:  (11) Rep Power: 4
| Re: full throttle in first and second gear...what to expect? you definetly want to be tucked in as much as possible to keep as much weight as you can forward.
cover the clutch cover the brake
dont target fixated and enjoy the ride |
12-11-2006, 12:13 AM
Bike(s): 00' CBR 929RR (Yellow/Black) Posts: 299
Rep:  (17) Rep Power: 4
| Re: full throttle in first and second gear...what to expect? My 929 has a hard time keeping the front down in first and second.....the 1000rr is a total beast when it comes to lifting the front wheel.....Have fun  |
12-11-2006, 3:16 AM
Bike(s): 2004 1000RR 2003 954RR 1997 VFR750 Posts: 248
Rep:  (62) Rep Power: 6
| Re: full throttle in first and second gear...what to expect? Carefull on grabbing too much throttle out of corners also, the 1k is much more prone to breaking the back tire loose than my 954 is or 929 ever was. |
12-11-2006, 6:35 AM
Bike(s): 06 CBR 1000 Posts: 5
| Re: full throttle in first and second gear...what to expect? yeah be careful if your cruising along at about 5,000 rpm in first and crack open the throttle it is facing the sky  as with any 1000cc sportsbike you can clutch it up in almost any gear ... Be careful hate to see new blades go down ohh yeah it hurts too. |
12-11-2006, 8:43 AM
Bike(s): 03 cbr954rr, 06 F4i-Wife , 06 CRF150, 06 CRF50-Son Age: 37 Posts: 1,365
Rep:   (194) Rep Power: 5
| Re: full throttle in first and second gear...what to expect? Wheelieville if you hammer it too hard, My 954 tries it in first and second all the time. And so no ones gets their knickers in a wad that's at the track. If you keep the front down then **** start's passin by so fast it looks plaid  Now at this point in first gear you have probably exceeded the legal limit's for any surface road in the U.S. And are probably close to exceeding the highway speeds so get used to not whacking the throttle and short shifting. Otherwise you would again have done something illegal and could not talk about it here cause someone might get their panties in a wad. |
12-11-2006, 11:38 AM
#12 | | LOO-muh-nair-ee
Bike(s): CBR1000RR '05 Age: 33 Posts: 210
Rep:  (78) Rep Power: 3
| Re: full throttle in first and second gear...what to expect? I must be a gentle rider... i have never faced the sky... almost 7500K on my '05. I guess that's a good thing! |
12-11-2006, 11:43 AM
#13 | | Carolina Kracker
Bike(s): 06 CBR1000rr, 05 CBR1000RR Repsol Edition(stolen) Age: 25 Posts: 4,696
| Re: full throttle in first and second gear...what to expect? roll on the throttle like the others said or you will be looking at the birds flying around |
12-11-2006, 12:25 PM
#14 |
Bike(s): 2004 CBR 1000RR, 2008 CBR 1000RR Age: 34 Posts: 1,219
| Re: full throttle in first and second gear...what to expect? Quote:
Originally Posted by dattaway Expect severe problems keeping the front wheel down the first 130mph.
The heavier you are, the more weight will be levered over the rear axle: meaning more wheelies. Your center of gravity will be MUCH higher. | Actually I think most modern sportbikes have a front wheel weight bias. |
12-11-2006, 12:26 PM
#15 | | Carolina Kracker
| Re: full throttle in first and second gear...what to expect? if you can find the streetbike jump they did on nitro circus, it nose dived bad upon take off |
12-19-2006, 5:10 AM
#16 |
Bike(s): CBR1000 06 Age: 33 Posts: 199
| Re: full throttle in first and second gear...what to expect? Ive found my 06 cbr1000 to be very predictable,this is of course you are concentrating on what your doing,it will want to launch skyward if you take it 1st gear red line,then quick shift to 2nd,red line 3rd.......
If you dont concentrate and go red lining the thing every gear,i will predict your bike will be 70 ft in front of you (on its side and trashed  ) as you pick yourself up from the road,actually you wont get a chance to get 2nd gear,you would be gone by 5000rpm.
Ride it smooth and they are very good predictable machines.
Hope it helps.  |
12-21-2006, 4:27 AM
#17 |
Bike(s): 1050 S3 Posts: 381
Rep:  (10) Rep Power: 4
| Re: full throttle in first and second gear...what to expect? If wheelies are illegal, then show me a state where first gear to red line is allowed. It's well over any speed limit.
If you are in closed area, then it's ok, but so are wheelies then too.(of course most race tracks don't like them) |
05-14-2007, 5:30 PM
#18 |
Bike(s): 2000 Honda CBR 929RR Posts: 44
| Re: full throttle in first and second gear...what to expect? I would not recommend rolling the throttle on too hard in first gear on a 1000RR. NOT A GOOD IDEA. My buddy has a 1000RR he pulls 2nd and 3rd gear power wheelies all day long. Even on my 929 first and second gear are power wheelies. |
05-14-2007, 5:33 PM
#19 |
Originally Posted by luvtolean Both depending on the conditions. Be careful.
Please remember, don't talk about illegal activity (such as wheelies) on this site. | I don't understand why it is bad to talk about such things...but whatever. We are simply talking about what would happen if he did these things. I don't think anyone is promoting doing illegal or reckless motorcycle riding in this post. |
05-14-2007, 6:11 PM
#20 | | 2-Up SISSY
Bike(s): 2002 CBR 600F4i / 2003 XR650R 'Tard Age: 29 Posts: 2,596
| Re: full throttle in first and second gear...what to expect? You ressurrected a year old thread to whine about the rules?
See here... http://www.fireblades.org/forums/sit...tml#post598377
05-14-2007, 6:11 PM
#21 |
Bike(s): cbr 929 Posts: 90
| Re: full throttle in first and second gear...what to expect? its not like anyone listened to him anyways. I found the 1000 to be quite a bit faster then 54's 29's but did not want to launch to the sky as much as the old bikes but rather drive forward like no tommorow. |
05-14-2007, 6:37 PM
#22 |
Bike(s): 2006 CBR1000rr Black Posts: 14
| Re: full throttle in first and second gear...what to expect? Hey i have the same bike and from all the bikes i ever drive until now, 2006 fireblade is the best. Easy to handle, good driving position, just try to be gentle with throttle and as smooth as you can. I would also advice you to be alerted on first gear riding. Sometimes you may end up looking the sky really fast. |
05-15-2007, 1:36 PM
#23 |
Bike(s): 2007 CBR100RR Silver Age: 31 Posts: 25
| Re: full throttle in first and second gear...what to expect? I know mine becomes a bird watcher with ease. Only on slicker/dustier asphalt type surfaces does traction become an issue. As several before me stated, never grab a handful until you are have acclimated yourself to the power. As far as I can tell you never become "used" to the power. Be wise to the laws in your area. |
05-15-2007, 6:14 PM
#24 |
Bike(s): '06 1000RR Posts: 34
| Re: full throttle in first and second gear...what to expect? I'm in the same boat as you...390 miles on mine and haven't gone above 9K yet. I've had a 929 and 954 and they sure as hell wouldn't power wheelie 2nd. In fact I geared it to a 15T front and it was still hard to get it to power up 2nd. Maybe I had 2 weak bikes but I would just clutch it up. As for my 1K I've already found it will power 2nd at about 5500 rpms and that's with only 300 miles on it. I'm changing the oil tonight at the 400 mile mark and then I'm going to let it rip!!! |
05-15-2007, 6:28 PM
#25 |
| Re: full throttle in first and second gear...what to expect? Must have been a weak 954 2nd is np coming up out of turns at hallet but 3rd really requires a bit of hamfistedness and a litlle clutch slip. |
05-15-2007, 8:26 PM
#26 |
| Re: full throttle in first and second gear...what to expect? Well I just got back after changing my oil and I did a roll from about 50 in 1st up through 135 and I must admit that this bike has a very smooth power delivery. I didn't notice any power spikes on the way to redline in 1st, 2nd, and 3rd, just a smooth power delivery...it's deceptively fast! |
05-15-2007, 9:25 PM
#27 |
Bike(s): 2006 CBR1000RR Posts: 531
Rep:  (15) Rep Power: 3
| Re: full throttle in first and second gear...what to expect? Road rash on your ass. |
05-15-2007, 11:24 PM
#28 |
Bike(s): 95, CBR 900RR Posts: 1,719
Rep:  (51) Rep Power: 0
| Re: full throttle in first and second gear...what to expect? Only 200 miles and you ride it that hard?! This is a major reason why if i buy a newish/newer bike it WILL be new off the showroom floor. Can't trust people and how they "break in" an engine. Pretty soon Honda will quit honoring warranties on new bikes because of people like this.
Now your bike will never have it's full potential power because you didn't break it in correctly. |
05-15-2007, 11:29 PM
#29 | | 2-Up SISSY
