F1 and red light
Old 03-18-2007, 1:12 PM
Bike(s): cbr929rry
Rep: mrapriliafalco is on a distinguished road (10)
F1 and red light
Hi
Sorry if been on before but Im new to this.
got this red light on with an F1 displayed.It does not flash at all it stays on constantly while im riding any ideas as can only found comments on it flashing
mrapriliafalco is offline
View mrapriliafalco's Profile View mrapriliafalco's Gallery Find More Posts by mrapriliafalco
Old 03-18-2007, 1:29 PM
Bike(s): 03 954RR
Rep: ReSpEcT is on a distinguished road (12)
Re: F1 and red light
Since u didnt state what bike u have, LoL. This is the information from the 02-03 954rr shop manual......
- Short circuit in service check connector
- Faulty ECM
- Short circuit in service check wi
Also, u can try checking these. The manual indicates that there is NO BLINKS from the FI light on these, but it does NOT state if the FI light stays on......
- Open or short circuit in malfunction indicator wire.
- Faulty ECM
ReSpEcT is offline
View ReSpEcT's Profile View ReSpEcT's Gallery Find More Posts by ReSpEcT
Old 03-18-2007, 1:37 PM
Bike(s): cbr929rry
Thanks prob would help if I said what bike I have,Its a 929 rry.
Old 03-18-2007, 2:22 PM
Bike(s): 03 954RR
Ok on the 929 it says
No blinks:
- Open or short circuit in MIL wire
- Faulty ECM
Stays lit:
- Short service in service check connector wire
- Faulty ECM
ReSpEcT is offline
Old 03-19-2007, 11:11 AM
Bike(s): 2000 929rr
Rep: oakley is on a distinguished road (10)
You state that it stays on when your riding. It will not flash when your riding. try letting it sit running in neutral and see if it flashes then. If it does flash count the long and short flashes to get your error code,example- 3 long flashes, 5 short flashes = code 35
oakley is offline
View oakley's Profile View oakley's Gallery Find More Posts by oakley
Old 03-19-2007, 4:18 PM
Bike(s): 2001 CBR929RR
Rep: 2001 CBR929RR is on a distinguished road (10)
I have a factory service manual, so I can tell you what the error code means of you find one.
2001 CBR929RR is offline
View 2001 CBR929RR's Profile View 2001 CBR929RR's Gallery Find More Posts by 2001 CBR929RR
Old 03-20-2007, 9:54 AM
Bike(s): cbr929rry
thanks for looking this up for me the code is 35 (3 short 5 quick)
Old 03-20-2007, 10:10 AM
Bike(s): 2000 929rr
code 35 is faulty EGCV and air intake valve servo motor
oakley is offline
Old 03-20-2007, 1:29 PM
Bike(s): cbr929rry
Thanks
Hope you dont mind me throwing questions at you!
I have located the servo and have noticed that it trys to move when I rev the bike quite hard,it does not move when started up or reved slightly.DO I need to free it and how do you know if stuck open or shut??
Regards
Andy
Old 03-20-2007, 3:54 PM
Bike(s): 2000 929rr
The servo will not turn when the bike is started, it only moves at around 3M RPM and then again at around 7M RPM. Could be that the cables are bound up. There is two cables that go to the EGCV and one that goes to the air intake, there could also be some thing stuck in the EGCV that is not allowing the servo to turn, or the servo it self could be bad. I would check the EGCV first, on the left side of your blades EGCV there is a little chrome colored cover. Remove this cover and and look for some thing that may be stuck in there such as a pebble. Place a wrench on the nut and see if you can open and close the valve DON'T force it it should turn fairly easy. If nothing is there but it still won't turn then cables may be bound up. you'll need to remove the cables from the servo to see if they are binding. after you unhook the cables if the EGCV opens and closes then your servo could be bad. If I remember correct if you turn EGCV all the counter clockwise this is full open (i think).
oakley is offline
Old 03-20-2007, 4:18 PM
Bike(s): 2000 929rr
Maybe these will help ya.
oakley is offline
Old 03-20-2007, 4:41 PM
Bike(s): cbr929rry
Cheers your a top man
That also makes sense as to why the red & F1 light does not appear until you hit 3000 rpm
Thanks
Old 03-20-2007, 5:11 PM
Bike(s): 2000 929rr
Glad I was able to help.
oakley is offline
Old 03-20-2007, 7:58 PM
Bike(s): 03 954RR
Yeah i just changed my Air Intake Servo Motor about a week ago. Bike kept giving me 3 long and 5 short blinks, then it stayed on while riding. Servo Motor was the problem and now it works great. Its a little tricky getting the cables back on right, but i'm sure u can do it. Look on ebay for one, can usually buy it for about 30 bucks....=-)
ReSpEcT is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 7:28 AM.
