Grip removal LH clip on
Old 04-18-2007, 4:30 AM
Bike(s): Fireblade 954, VFR800
Rep: r15suk is on a distinguished road (25)
Hi can anyone help with this,
Has anyone removed the LH grip from the clip on without wrecking it and then reused it? If so how did you do it?
Cheers
Simon
r15suk is offline
View r15suk's Profile View r15suk's Gallery Find More Posts by r15suk
Old 04-18-2007, 10:28 AM
Bike(s): 2003 Honda Cbr 954 rr
Rep: Type Gendy is on a distinguished road (10)
Send a message via AIM to Type Gendy
Re: Grip removal LH clip on
Never tried it or seen it work, but i recently i read to use compressed air? :shrugs:
Type Gendy is offline
View Type Gendy's Profile View Type Gendy's Gallery Find More Posts by Type Gendy
Old 04-18-2007, 10:29 AM
Bike(s): 945cc '95 Formula Xtreme 'Frankenstein' Fireblade
Rep: Sime will become famous soon enough (86)
I actually cut mine off with a razor blade. The reason was because it was worn out. Wasn't worth replacing. They only cost about $7 to replace for OEM, or you could get the really nice Renthal ones. Don't bother trying to reuse the old one. Just replace it.
You can use Scott's Grip Stick to fit the new one. Clean the old adhesive off the bar, and then coat the clip on and the inside of the new grip with the Grip Stick (it's a contact cement). You then push the grip on the end and whack it hard with your palm to get it on..........you have to do this process fairly quickly (within 20-30 seconds).
Cheers,
Sime
Sime is offline
View Sime's Profile View Sime's Gallery Find More Posts by Sime
Old 04-18-2007, 10:58 AM
2 up @ Grattan
Tornado bait's Avatar
Bike(s): 2005 600RR
Rep: Tornado bait is a glorious beacon of lightTornado bait is a glorious beacon of lightTornado bait is a glorious beacon of lightTornado bait is a glorious beacon of lightTornado bait is a glorious beacon of lightTornado bait is a glorious beacon of light (500)
I've taken several off. If you work it back and forth a little you can break any glue or adhesive that might be holding it. Then bit-by-bit twist, push, and pull it off. Its a tedious process, but it works. You can also get it partially off by rolling it down like a sock.
If you have compressed air that works best. First twist it back and forth to get any adhesive broken lose. Then on what would be the open end of the grip or the "mouth" (the end that goes on first) pull it up a little and blow some compressed air inside it. This will expand it just enough to slide it off while blowing air into it.
Tornado bait is offline
View Tornado bait's Profile View Tornado bait's Gallery Find More Posts by Tornado bait
Old 04-18-2007, 12:17 PM
Thanks for this tip i'll give it a go. I have a compressor at home too :-)
Cheers
Simon
r15suk is offline
Old 04-18-2007, 12:21 PM
Cheers,
Sime
I'll try the tip of the compressed air first, as i quite like the standard Honda grips. If that goes tits up then i'll get some Renthal ones.
Of subject, are your Targa mirrors plain black or carbon. It's just their web site only appears to have pictures of carbon look ones?
Cheers
Simon
r15suk is offline
Old 04-18-2007, 12:40 PM
gone green
jhonda41's Avatar
Bike(s): 95 VFR
Rep: jhonda41 will become famous soon enoughjhonda41 will become famous soon enough (100)
on the compressed air (and that may have been me that mentioned it in a recent thread)
I've also used a screwdriver to slowly work the grip off as I spin it on the inside of the grip/outside of the bar. This doesnt work as well on newer bikes though.
Oh and when you're ready to slip the grips back on.... spray some hairspray on the inside of the grip and on the bar.... it will go on like butter and dry quick.
-jh
- Track whores get paid for it, track sluts do it for free...
- Cars lean the wrong way in turns.
jhonda41 is offline
View jhonda41's Profile View jhonda41's Gallery Find More Posts by jhonda41 My Map Location
Old 04-18-2007, 12:43 PM
-jh
Thanks for mentioning the hairspray. I did that in the 1970's and wondered if it still worked
Cheers
Simon
r15suk is offline
Old 04-18-2007, 1:06 PM
gone green
jhonda41's Avatar
Bike(s): 95 VFR
My only problem is explaining to my wife why she keeps finding hairspray in my toolbox....
"but honey.... its to install my heated grips... Honest!"
-jh
jhonda41 is offline
Old 04-18-2007, 3:32 PM
-jh
Like the spare condom is used to carry gas in in an emergency
r15suk is offline
Old 04-18-2007, 3:48 PM
Bike(s): Erion Honda 929, CR125R
Rep: twojays280 is on a distinguished road (10)
If your in a pinch and don't have compressed air. Contact cleaner (PJ1 or similar) works like a charm. Just stick the hose in between the grip and the bar and give it a little squirt. The grip will slide right off, and when the cleaner dries you can install the grip on the new bar with no problems.
twojays280 is offline
View twojays280's Profile View twojays280's Gallery Find More Posts by twojays280
Old 04-19-2007, 4:03 AM
Cheers
Simon
Oh, I do like the standard Honda ones too. That's what I replaced mine with. They don't cost much at all.
The mirrors are the plain black ones. I don't like that chintzy 'faux' carbon fibre look at all (I'm stuck with it on my turn signals though but that's all I could get a hold of. I will be painting them black when I get some time!)
Cheers,
Sime
Sime is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:40 AM.
