Rear tire limit... - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 12-06-2007, 12:52 PM Thread Starter
Images: 1
Rear tire limit...
I'm buying tires for my 2006 CBR 600. This might be a stupid question but, what is widest tire that will fit on my bike. Should I stick with the stock tire size? what are the pros and cons?
ChubNelson69 is offline
post #2 of 10 Old 12-06-2007, 1:59 PM
Images: 8
Re: Rear tire limit...
Hell, the widest tire is whatever you want and what you're willing to go through to put it on (new swingarm). what are you tryin to do with the bike (drag, roadcourse, or commute). I would stick with the stock size tire. You could go with a 190 easily i believe. But ur lookin at a bit more cash, and really nothin else. Alot of people say u get more traction, but can u use it is the question. Bigger footprint in the rain maybe, but not by much at all.
rokitt51 is offline
post #3 of 10 Old 12-06-2007, 3:55 PM
Images: 24
Reputation Power: 15
Basically what rokitt said but by putting a 190 on a 5.5 inch rim you change the profile of the tire. The front and rear tires have profiles that are meant to work together. If you change the profile of the rear tire things can get a little wonky. Some have done it and claim they like it. Independent tests have never been favorable. Putting a 190 on a 5.5 in rim isn't going to make it look much wider anyway because it just kind of balloons it out.
slickwill is offline
post #4 of 10 Old 12-06-2007, 4:27 PM
Images: 8
rokitt51 is offline
post #5 of 10 Old 12-06-2007, 6:13 PM
Images: 4
Reputation Power: 11
I believe you can fit a 200 if the swingarm will allow it. However realize even a 190 rear is going to make the bike turn slower unless you get someone that knows what they are doing to set it up right. Its purely a looks mod, and actually hurts the handling.
x[corwyn] is offline
post #6 of 10 Old 12-06-2007, 6:24 PM
Reputation Power: 10
A few years ago there was a competition over here of who could fit the biggest size tyre on the rear it went from mild to plain stupid. You asked for pros and cons , the main pro would be it would look cool to your mates . The biggest con is when it pops of the rim while your riding and you crash,then your insurance company tell you that you can't claim because its your fault as you made the bike dangerous to ride in the first place by fitting over size tyres.
THE JESTER is offline
post #7 of 10 Old 12-09-2007, 5:04 AM
I had a 190 on my 03 600RR and it sucked. When I changed back to a 180 I had much more flickability. Basically it isn't designed at all for a 190 and you are going against all the principles by going larger.
blacknight1 is offline
post #8 of 10 Old 12-10-2007, 10:41 AM Thread Starter
Images: 1
Thanks a lot for the info! I'm going to stick with the stock size especially if it's going to screw with the handling. Thats one thing I like about my 600.
post #9 of 10 Old 12-10-2007, 11:55 PM
Images: 3
wouldn't a larger rear make the stearing quicker in terms of suspension set-up?
Ol' Gravy Leg is offline
post #10 of 10 Old 12-11-2007, 12:00 AM
jhonda41's Avatar
Images: 9
Negativo
jhonda41 is offline
Human Verification
Search tags for this page
biggest tire i can put on 97 magna750
can you put a 180-70 15 rear tire on a honda shadow 600
how can i put a 210 rear tire on my honda shadow
pros and cons of going to a 190 55 xr17 tire on 600 honda cbr motorcycle
put bigger tire on honda shadow
what is the biggest rear tire i can use on a cb750 2.5 wide rim
what size tire can you put on a stock honda shadow spirit
what's the biggest tire you can put on a 2001 honda cbr929rr
whats the biggest tire i can put on 2006 honda shadow spirit
whats the widest tire for 750 honda shadow
Rear tire evo_prez General Discussion 6 11-26-2007 11:56 AM
Plugs in the rear front or rear tire. #414 General Discussion 11 08-11-2007 11:48 AM
Rear tire width? NWOleman Honda Interceptor / VFR 2 04-04-2007 10:58 AM
929 rear tire Abuddha20 Honda FireBlade 3 04-12-2005 9:57 PM
BT020 rear tire with high perf front tire JWHT Honda FireBlade 4 09-05-2004 6:37 AM
