Bike Temp Of A 2007 CBR1000RR - Honda Motorcycles - FireBlades.org
post #1 of 20 Old 05-18-2008, 12:47 PM Thread Starter
First post on the board...
Had a few bike temperature questions today in regards to my 2007 CBR1000RR.
Granted... it was HOT today (95 degrees) but my bike was hitting temps that I feel are way too hot for the weather.
At one point I glanced down and was seeing 240 degrees. Fan was just cranking away and I could feel it blowing heat. This was while sitting in traffic...
Once I hit the highway it quickly went back down to 180 degrees.
I'm afraid that it would have continued to keep going up if I had been at the light for awhile.
Anything I should be worried about?
I'll admit I haven't checked the coolant levels but I do know that the coolant overflow tank/bottle is half full.
I'm planning on changing out collant this week at some time to get rid of it as a possibility.
Anything else I should check?
Hoard is offline
post #2 of 20 Old 05-18-2008, 2:23 PM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: Bike Temp Of A 2007 CBR1000RR
Thermostat could be stuck closed which will prevent the coolant from circulating.
It's also possible the system has air caught in it I guess. The water pump can't pump air.
It might even be that it overheated at one point and spat out a bunch of coolant so it might just be running low.
Water Wetter or Engine Ice might be helpful as well.
post #3 of 20 Old 05-18-2008, 6:35 PM
Reputation Power: 10
My 07 1000RR behaves the same. It heats way up when sitting traffic on a hot day. I saw mine once almost reach 250F sitting still. Once I started moving, the temperature came down. Eventually settling at 180F down the road. If the thermostat was sticking, the temperature would never settle back to 180F.
segiano is offline
post #4 of 20 Old 05-18-2008, 8:23 PM
Images: 2
Quoted: 2 Post(s)
I don't know anything about farenheits so I was assuming the poster is indicating that his bike is actually overheating.
If it isn't overheating then I wouldn't worry about it.
I've seen 121C on the 929 on the track before it spat all the coolant out.
post #5 of 20 Old 05-18-2008, 8:27 PM
Quoted: 55 Post(s)
If it was stuck closed, then it would not have cooled down to 180 degrees once they started moving again.
Air is a possibilty though. If they are going to flush the system, it doesn't make much sense for them to try and diagnose if it has air or not.
lanbrown is offline
post #6 of 20 Old 05-18-2008, 10:41 PM
Images: 5
Reputation Power: 34
I see my temp hit 235-240 on hot days... To me its pretty common..
Maholli is offline
post #7 of 20 Old 05-18-2008, 11:34 PM Thread Starter
Thanks so far for the replies. I won't freak out or anything then. I'm just used to my old F4i that would never go above 220.
Like I said; for the summer I do plan on going to water/water wetter and changing out later in the year back to the traditional antifreeze.
Hoard is offline
post #8 of 20 Old 01-14-2009, 8:27 AM
Send a message via MSN to babz
Mine when riding in traffic never goes under 220F and climbs up to 228F when idle,isnt it a bit too hot?
babz is offline
post #9 of 20 Old 01-14-2009, 11:05 AM
Reputation Power: 15
My bike ususally reads around 180* riding and can climb way up there. Your bike sounds normal. The fan kicks on about 220 or so on mine and will stay there until I start moving.
I BLEED RED
Bigtoe is offline
post #10 of 20 Old 01-14-2009, 7:30 PM
Reputation Power: 9
Personally, I would shut my bike off once it hits 240F. Don't wanna crack the engine.
partyhardryan16 is offline
post #11 of 20 Old 01-14-2009, 9:02 PM
Reputation Power: 11
hrm, i've never had a bike keep climbing for more than 3 or 5 F when the fan kicks on... if the fan kicks on at 220 and it's reaching 240, personally i would be concerned.
cbrsmurf is offline
post #12 of 20 Old 09-16-2011, 12:08 PM
Images: 1
my 2006 CBR1000RR is having the same problem. temperature is getting up from 250 to 260F when waiting at an intersection.
The thermostat valve could be sticky. I think item number 2 in this drawing is the only thing that I need? anyone have suggestions?
Honda Motorcycle Parts 2006 CBR1000RR AC THERMOSTAT Diagram
makthepharack is offline
post #13 of 20 Old 09-16-2011, 12:11 PM
Images: 2
Quoted: 2 Post(s)
At that sort of temperature I'd expect the relief valve to blow dumping coolant to the reservoir. Is this happening?
If you suspect the thermostat then remove it and see if it helps.
post #14 of 20 Old 07-09-2015, 2:17 PM
my 2006 cbr 1000rr on a 90 degree Fahrenheit day idled in the shade to 247 degrees Fahrenheit before i shut it off on the high way at 70 mph it runs at about 178-183 degrees Fahrenheit when i shut it off i can hear it blowing coolant back into the reservoir any ideas on how to fix this ? im going to try and burp the system when it cools off but any insight would be very helpful
vancev is offline
post #15 of 20 Old 07-09-2015, 3:55 PM
Images: 1
I had the exact same problem. be careful not to let the temperature go above 240F. If it does then try to turn of your engine right away.
I was stuck in traffic in the middle of summer and my engine heated up above 255F+ rapidly and this eventually warped my headers and the engine almost cracked.
The repair cost was about three grand.
The repaid shop repaired my engine and installed an additional metallic fans.
Get rid of the cheap stock plastic fans. They will warp in high temperatures and you will get lower airflow.
Have your coolant replaced by professionals to engine ice. dont do it yourself unless you're an expert because if there are air bubbles inside the coolant will not flow properly.
After getting this aftermarket fans installed, I was getting about 185F idle and 215F at intersections.
Muzzy Aluminum Fans
Human Verification
Search tags for this page
2005 cbr1000rr 230 degrees is that bad for the engine
2006 cbr 1000 idle temp
2007 cbr 1000rr how to bleed water system
2007 cbr fireblade operating temp
2007 cbr rr overheating
2007 cbr1000 bubbles in coolant
how to check antifreeze in a 2007 cbr 1000rr
my 07 cbr 1000 rr fireblade runs 223 at idol is this normal
operating temperature for 07 honda 1000rr
the shade 02 2011 cbr 1000rr
2006-2007 CBR1000RR Same? cb900f2 Honda FireBlade 16 04-09-2010 10:31 PM
2007 CBR1000RR JJN3 For Sale 11 03-08-2008 5:38 PM
Pipe recommedations for 2007 CBR1000RR dazm Honda FireBlade 11 11-25-2007 4:42 PM
2007 CBR1000rr michalis1313 General Discussion 3 05-17-2007 4:40 PM
04 cbr1000rr fully loaded. Lots of extras... Great Track bike! stealthbomber For Sale 2 08-07-2005 8:12 AM
