Honda Motorcycle Forum
Honda Motorcycles
Old 07-14-2008, 7:27 PM   #1
Reputation Power: 7
Type Gendy is on a distinguished road
Send a message via AIM to Type Gendy
bike wont start
I've been having this intermitent starting issue with my bike lately. Sometimes the fuel pump primes but it wont have enough juice to turn the motor over. A few times in front of my friends it started right up fine. The batter is between a year or two old. I looked at it once and cleaned up the battery terminals an connections with a wire brush adn thought that would do it. Lately it hasnt been starting at all.
Is there something else to check on it? I'm gonna go follow the ground now and see if i can find where it goes. Make sure that is clean. Also gonna test the battery with bike running to make sure its getting a charge.
Anything i'm missing?
edit: A couple times early in the season when i turned the key on the fuel pump wouldnt prime. Come back it later or keep trying and it would start up fine. So it seems like a funky wire perhaps? or maybe an unrelated issue idk..
Type Gendy is offline   Reply With Quote
Remove Ads
Old 07-14-2008, 7:36 PM   #2
Reputation Power: 7
Re: bike wont start
battery is about 12.5, at idle i'm getting about 13.3 and if i rev it up it will go up past 14
Old 07-15-2008, 12:27 PM   #3
Reputation Power: 7
jawz0414 is on a distinguished road
Re: bike wont start
Can you clarify that statement? Do you mean it's not getting enough fuel, or the motor is not cranking properly (slow cranking speed, etc.)? Does it just sit and crank, but not start?
I would also suggest monitoring the voltage while starting the bike. That number could be helpful in figuring out the problem.
jawz0414 is offline   Reply With Quote
Old 07-15-2008, 6:02 PM   #4
Reputation Power: 7
Re: bike wont start
Well it only did it twice, the first day i pulled it out of the garage and then a week later. Basically i went to start the bike and everything powered up except the fuel pump, and it would not turn over, like when u have the kill switch on. But it has not done that in months.
Then randomly in the last month it turns over slow and wont have enough juice to fire the bike. Then it was fine for a couple weeks. Now it never has enough juice anymore. Seems like if the battery was toast it would have quit a month ago instead of getting back to normal startups for a while? This whole time the bike was being ridden frequently.
What should the battery voltage be when i hit the starter?
Old 07-15-2008, 6:14 PM   #5
stormi is on a distinguished road
Re: bike wont start
Technical Article: Fault Finding Guide - ElectroSport Industries
This should help.
stormi is offline   Reply With Quote
Old 07-16-2008, 6:41 PM   #6
ktulu07 is on a distinguished road
Re: bike wont start
Something stupid to check. On my Suzuki the battery terminal connections will get loose from vibration after riding for a while. When it happens it seems like the battery is dead or dying.
It may be worth a check.
ktulu07 is offline   Reply With Quote
Old 07-16-2008, 7:56 PM   #7
Not Normal....
Reputation Power: 8
Desert Blade has a spectacular aura aboutDesert Blade has a spectacular aura aboutDesert Blade has a spectacular aura about
Re: bike wont start
My blade did this all the time when the battery went. It would fire just fine. Nice rapid crank. I would ride to the corner store and shut it off. Come out tem minuts later, and it would BARELY have enough power to turn over. Sometimes I would have to push start it, ride hard for about ten minuts, and then it would be back to good cranking power. The lights and display always lit up like nothing was wrong power wise. Sometimes they would dim a little and the pump would not be heard priming. It would turn over a few times, slow its rate down quikly, and then go to the rapid click of a failed turn over. New battery fixed this all for me. The stock battery in mine only lasted 8 months of fairly consistant riding.
Fox
Desert Blade is offline   Reply With Quote
Old 07-17-2008, 3:33 AM   #8
96tangcobra is on a distinguished road
Re: bike wont start
have your rectifier checked,Mine did that when it was going out.Sometimes I could ride for a week,other times it would go dead in an hour.these things are notorious for having crappy rectifiers.
96tangcobra is offline   Reply With Quote
Old 07-18-2008, 2:12 AM   #9
Images: 1
Reputation Power: 6
chukky is on a distinguished road
Re: bike wont start
Hi,
Just some tech info.Its got nothing to do with your voltage on the battery.This could be 13v and you think everything is fine.Thats not it at all,its got to do with the AMPS of your battery.
From experiance I would say your battery is shot.Typical symptoms
Cheers
Chukky
chukky is offline   Reply With Quote
Old 07-18-2008, 10:01 PM   #10
Reputation Power: 7
Re: bike wont start
Thanks for all the info guys. I hope to look at it again this weekend.
how can you check the rectifier?
also can i check the amps of the battery with a standard voltimeter?
Old 07-18-2008, 10:43 PM   #11
Re: bike wont start
I have the instructions on how to check the rectifier somewhere,I'll dig em up 4 ya.But yes,your batt. could be shot too.Borrow a buddies batt. and see if that fixes it.
Old 07-20-2008, 2:04 AM   #12
Re: bike wont start
Originally Posted by stormi View Post
This will test the rectifier, and the rest of the charging system, including connections between parts, which can often be the problem.
Search tags for this page
03 cbr 954rr will crank hard but will not start
bike turns over but wont start
bike turns over slow
bike wont start
cbr cranks over slowly
honda 954 cranking slow
motorcycle turns over hard
my bike turns over hard
my bike will start but wont go
started my bike last month just fine and now wont start
will a voltage rectifier cause the motorcycle to turn over slow and hard to start
You may not post new threads
You may not post replies
MY bike wont start. Hondarider4life Electronics 3 08-17-2008 12:41 AM
Bike wont start AVIONLS Honda CBR 600 25 07-21-2007 9:23 PM
Bike wont start that929 Honda FireBlade 14 04-07-2007 6:16 PM
Bike wont start GonZilla Honda FireBlade 30 11-09-2004 5:52 AM
Bike Wont Start djice929 Honda FireBlade 12 11-18-2003 5:15 PM
