Oil Confusion, how to read the dipstick correctly?
08-29-2008, 8:25 AM
Bike(s): Repsol Fireblade 07, Fireblade 08 Age: 31 Posts: 144
Rep:  (10) Rep Power: 1
| Oil Confusion, how to read the dipstick correctly? Guys,
I am soo confused and scared about the oil level in a lot of our 08 Bikes.
Checked it again today after having done +500k, after the oil change (3500km). How do I read the dipstick correctly?
Lost my user manual. On which mark should the oil level be for the correct oil level?
Can anyone post a pic for me retard to illustrate it?
Thanks |
08-29-2008, 9:01 AM
Bike(s): '08 Fireblade and gsxr 600 Posts: 1,199
Rep:   (122) Rep Power: 4
| Re: Oil Confusion, how to read the dipstick correctly? Above min Line and below Max line, sorry no pic
__________________ If you are patient in one moment of anger you will save a hundred days of regret |
08-29-2008, 9:05 AM
Bike(s): 2008 Pearl Sunbeam White Honda CBR1000RR Age: 38 Posts: 239
| Re: Oil Confusion, how to read the dipstick correctly? Yep...............upper and lower lines are min and max.
MFL...........who knows ?
Probably Japanese for seized engine  |
08-29-2008, 9:43 AM
| Re: Oil Confusion, how to read the dipstick correctly? Shouldnt have any oil worries anyway he lives in Dubai
(sorry couldnt help myself))
08-29-2008, 11:10 AM
| Re: Oil Confusion, how to read the dipstick correctly? Quote:
Originally Posted by setanta Shouldnt have any oil worries anyway he lives in Dubai
(sorry couldnt help myself)) |
LoooL. Guud one.
Upper and lower does make sense for me, but what is this MFL for?
Got my oil refill & change FOC, guess bc its Dubai  |
08-29-2008, 12:06 PM
Bike(s): HONDA FIREBLADE CBR1000RR 2008 BLACK AND WHITE Posts: 99
Rep:  (11) Rep Power: 1
| Re: Oil Confusion, how to read the dipstick correctly? duke also when checking the oil do not screw the dipstick back in some people are doing this and its in correct
mfl stands for maximum fill level |
08-29-2008, 12:09 PM
Originally Posted by dev435 duke also when checking the oil do not screw the dipstick back in some people are doing this and its in correct
mfl stands for maximum fill level | have it in straight position and do not screw the dipstick in, as you mentioned.
My oil level is rite above the MFL level, is that sufficient? |
08-30-2008, 1:54 AM
| Re: Oil Confusion, how to read the dipstick correctly? yes mate to check the oil properly run engine for a couple of minutes then turn it off wait a couple of mins then do what i said with the dipstick this is what honda recommend in the manual and you will be fine  |
08-30-2008, 5:42 AM
Originally Posted by dev435 yes mate to check the oil properly run engine for a couple of minutes then turn it off wait a couple of mins then do what i said with the dipstick this is what honda recommend in the manual and you will be fine  | Manual mmmmm wots tat
09-02-2008, 2:01 PM
Bike(s): CBR1000 RR8 Posts: 39
Originally Posted by dev435 yes mate to check the oil properly run engine for a couple of minutes then turn it off wait a couple of mins then do what i said with the dipstick this is what honda recommend in the manual and you will be fine  | I did that and ended up slightly overfilling ... despite being anal about following the manual process.
It was drained at the dealers and found to be slightly over.
Once the dealer had set my oil level (for checking consumption over 500 miles) I checked the oil with the bike totally cold and the max level was showing on the line on the bottom side of the dipstick as opposed to the line on the top side where the oil was very slightly under the line.
Here on in manual out the window and I measure it cold.
What a fanny on  |
