| Re: Can I put Powercommander 3 USB for cbr954 into my 929rr yes you can. It's been talked about many times on here. Use the search function.
You will need to load 929 maps into the 954 pcIII. To do so you just need to open 954 map to use as a blank. Then open the 929 map you want to use. Highlight all of the boxes from the 929 map and right click and copy. Then highlight all of the boxes in the 954 map and right click and hit paste.
You must use the 954 map as a base, but paste in all the numbers from the 929 map you want to use.
I have a 954 pc III in my 929 and it works great. The connectors are the same. |
