954 Handling problem
Old 09-19-2008, 6:40 PM
Bike(s): 2003 954 Red/Black
Rep: kartaphilos is on a distinguished road (10)
Hi All,
I've had my 03 954 about a week now and for the most part it's a lovely bike. I have 2 issues with it. The one that bothers me most is it doesn't want to let me trail brake into corners, it really wants to stand the bike up and it's very hard to scrub speed while tipping in. Yes, I know bikes standup under brakes in corners but this is really pronounced, really fights the bike. All my previous bikes have been fine in thios respect (the worst was a '95 ZX-6R I got new).
A) My tyres are worn and the front rear profile changes is causing this.
B) It's a characteristic of the tyres (Michelon Pilots). They are the correct size and pressures.
C) A characteristic of the bike
If I were to change the tyres what is the current suggestion for a good road tyre. I'm on a bike trip up the the Isle of Man next weekend so would much prefer to get this sorted.
Cheers,
Matt
kartaphilos is offline
View kartaphilos's Profile View kartaphilos's Gallery Find More Posts by kartaphilos
Old 09-19-2008, 6:45 PM
lanbrown's Avatar
Rep: lanbrown is a jewel in the roughlanbrown is a jewel in the roughlanbrown is a jewel in the rough (268)
Re: 054 Handling problem
What's an "054"
lanbrown is offline
Old 09-19-2008, 6:53 PM
WYSIWYG
macca9540's Avatar
Bike(s): 2003 954 fireblade
Rep: macca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond repute (2822)
Hi Matt, I had a similar problem with my 3rd 954 when I bought it. I checked the suspension settings and they were all over the shop. I put them back to standard and it helped a lot. I then put on new tyres front and rear and all was good from then on. I also noticed the forks had been moved down through the clamps as well, why i dont know so they were adjusted back also. Just a few things that might help you out. Oh, I also lifted the rear a little by fitting a 190/55 rear tyre.
macca9540 is offline
View macca9540's Profile View macca9540's Gallery Find More Posts by macca9540 My Map Location
Old 09-20-2008, 2:58 AM
Bike(s): CBR929, 3xGSXR750, GSXR1000, ZX6R, XS250, KZ750
Rep: bladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud of (1182)
Re: 954 Handling problem
What sort of mileage have you got on the front tyre?
What do you weigh?
At a wild guess I'd be looking at front suspension.
Have you got a tell tale on a fork leg to see how much suspension you're using?
Are the front and rear ride heights in the ballpark?
Race sag okay?
bladeracer is online now
View bladeracer's Profile View bladeracer's Gallery Visit bladeracer's homepage! Find More Posts by bladeracer My Map Location
Old 09-20-2008, 6:40 AM
In the process of checking all that usual stuff today.
I weigh a spritely 85kg in the birthday suit. Front tyre is 3/4 worn on tread depth (rear is similar).
The road grime tell tale says I must be close to full compression on the fork. The preload is kinda low and when the wife gets back I'll look at sag. Rear preload is 3 from top.
Matt
Old 09-20-2008, 9:00 AM
3/4 worn on the front is worn out in my experience.
If you're planning a long trip put a new front on beforehand.
If the front is fully compressed then you're no longer using the suspension to absorb road bumps - you're using the tyre.
Old 09-20-2008, 10:07 AM
sscottab's Avatar
Bike(s): 2002 CBR 954 RR, 85 cb700sc
Rep: sscottab will become famous soon enoughsscottab will become famous soon enough (118)
set up your suspension and that will help, as for tires i have never owned the pilots but the metzler m3 are great tires. the 954 front suspension is known to be a a little weak and alot of people upgrade them.
2002 CBR954RR
scott
www.itriderz.com
sscottab is offline
View sscottab's Profile View sscottab's Gallery Find More Posts by sscottab My Map Location
Old 09-22-2008, 1:47 AM
Bike(s): 03' blk/tit CBR954rr, 99' GSXR750
Rep: vertical954rr will become famous soon enough (54)
i havent upgraded the suspension on my 954 yet but it is definitely much needed as the front is way undersprung (stock .70kg) and the rear shock is just dead.. anyway, i weigh ~200 lbs with full gear and set my suspension to the following settings which puts me at the following sag numbers:
front:
free sag 19mm / rider sag 35mm
stiction 10mm
rear:
Free sag 9mm / rider sag 30mm
stiction 3mm
Settings:
Front forks
comp- 1 turn out
rbd - 2.5 turns out
preload - 9.5
Rear shock:
preload - 4
comp - .5 turn out
rbd - 3.5 turns out
i also now run Pirelli DC3's with a 190/55 on the rear.
vertical954rr is offline
View vertical954rr's Profile View vertical954rr's Gallery Find More Posts by vertical954rr
Old 09-25-2008, 8:53 AM
Bike(s): 2003 CBR954RR 2007 SV650S
Rep: nukinfuts is on a distinguished road (10)
front:
stiction 10mm
rear:
stiction 3mm
Settings:
Front forks
comp- 1 turn out
rbd - 2.5 turns out
preload - 9.5
Rear shock:
preload - 4
comp - .5 turn out
rbd - 3.5 turns out
where was your preload adjustments on the front forks??
nukinfuts is offline
View nukinfuts's Profile View nukinfuts's Gallery Find More Posts by nukinfuts
Old 09-25-2008, 11:18 AM
I would assume he meant 9.5mm above the top bolt?
If it is it seems way too high. I run my front fully screwed down.
Old 09-25-2008, 1:41 PM
Bike(s): CBR954RR & Track R6
Rep: King Kenny is on a distinguished road (18)
Originally Posted by kartaphilos View Post
Hi All,
Cheers,
Matt
Something I put up on antoher website - I would say that there's alot of info to be gleaned here if you need it. I have about 70k miles down on this bike with maybe a dozen tyre changes
If you never go to the track you dont need track tires
I highly recommend the Pilot Road 2CT as a road only tire. They have as much grip on the road as the Pilot Power IMHO & only show that they are a road tyre when on the track. I can get my knee down no problem on the road & flat stick it out of all but the tightest of bends. Plus you get AMAZING mileage out of them.
My mate & I tried them for a 6k mile trip around Europe last March. He ennded up getting 12k miles out of the rear & the front still has a few left. He rides a 04 ZX10R hard. I has a PR2 rear & PP2CT fron & the fron is now toast with the rear only showing a little wear. Truely amazing tyres. Also they grip like you wouldnt believe in the wet & cold (see pic)
http://img.photobucket.com/albums/v3...8/IMG_0088.jpg
Seriously dont dismiss them because they are 'only' road tyres. If you can admit that you are not Rossi & dont ride at track pace on the road then these tyres are a great choice & will save you money hand over fist.
1 set of PR's = 2 fronts & 3 rears of PP2CT's wear wise
BTW: I had PP 2CT's on my 954 Blade & I would NEVER use them again on that bike. The PP 2CT is a very agressively profiled tyre & the 954 has very radical (compared to newer bikes) steering geometry. End result is a VERY nervous & twitchy ride especially from the front. It robbed me of all confidence to go into a bend hard. I had these tyres for 2 years after a big accident on this bike & I thought that it was the bike that was ****ed cos it was so nervous - WRONG. It was the tyres. Now I have a mismatch of a Pilot Road rear & Dunlop Qualifer front (very round profile) & the thing handles like a dream. I can ride it again the way I like it. Even with the stable Pilot Road fitted to the rear it was nervous as hell & when I had the agressive PP 2CT on the front so the bike stablility is all from the front tyre
[red]WARNING - Anyone with a 954 should make sure that they use a front tyre with a stable/round profile if they dont want a slap machine[/red]
King Kenny is offline
View King Kenny's Profile View King Kenny's Gallery Find More Posts by King Kenny
Old 09-25-2008, 8:24 PM
9.5 turns out from full soft on the preload, stock is 7 from soft..
comp & damp are turns out from full hard..
Old 09-25-2008, 8:28 PM
blue nut on top of each fork that almost sits flush with top triple
Old 09-25-2008, 8:30 PM
9.5 turns _out_ would be out from fully down or hard though.
Stock is seven turns _in_ from fully out or fully soft according to my manual.
Old 09-25-2008, 8:34 PM
  #15
its in from fully soft.. if its fully soft as the starting point there is only one way to go when turning 9.5 turns chief....in/out is semantics but technically you are correct..
Old 09-25-2008, 8:39 PM
  #16
It's not semantics as it sounded like you had soft and hard at the wrong ends of the scale which would be very significant :-)
In and out are better terms as the preload doesn't actually make the forks any harder or softer just longer or shorter.
Old 09-25-2008, 8:54 PM
  #17
true, but in this case since stock is 7 from full soft and said i go 9 from full soft it should be a given what direction we're talkin about especially since i've already said the spring rate is too soft/underspring and you cant go past full soft as a starting point unless youre taking the forks apart..
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 9:58 PM.
