954 929 rectifier swap - wiring? - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 12-30-2008, 3:19 AM Thread Starter
I've searched and it seems like some people says it works and others couldn't get it to work.
I have a 2000 929RR. Did all the electrical checks and I'm pretty sure I narrowed it down to the R/R. I called up the local Honda stealership and they want to rape me for a new R/R. So a friend of mine is parting out his 954RR and gave me his rectifier.
At first glance, they look similar except for one plug. My 929RR plug is a 4-pin square plug while the 954RR is a 6-pin square plug.
The 929 plug has 2 reds and 2 greens. 954 also has 2 reds and 2 greens, but also a single black wire.
Is it safe to assume that the reds/greens match each other? And just need to splice the 4-pin connector to the 954 rectifier? What is the black wire for? A ground wire?
Anyone have a 954RR wiring diagram? I already have one for my 929RR.
Thanks. This is my 1st post!
- Kevin
jaiyurai is offline
post #2 of 4 Old 12-30-2008, 6:39 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: 954 929 rectifier swap - wiring?
I never noticed it before but it does appear the 954 has a direct earth on the regulator in the wiring diagram.
Hard to be sure but it looks like a black or brown wire with a white or yellow trace.
post #3 of 4 Old 12-30-2008, 7:45 PM
Images: 2
Reputation Power: 9
The RED wires (two) are power (from ignition switch); the GREEN wires (two) are ground; the BLACK/WHITE wire heads to a common lead that goes into the ECU (lot of other pieces onto this same wire).
muddysteel is offline
post #4 of 4 Old 04-04-2017, 10:10 AM
blade9002
Guest
Posts: n/a
Hello dear brothers.I have some problem with my fireblade 929 01.My rectifier is with 8 wires (3 yellow from the stator, 2 green, and 2 red, and one thin litle wire black white i thing.I bought a new relay rectifier with 7 wires, without black white wire.My bike doesn't run good.I supposed to be the problem in this black white wire.Can anybody give me advice, what to do because my old rectifier goes up to 18+ volts, the new one is 13-14.Thanks for the advice
Human Verification
Search tags for this page
4 pin to 6 pin regulator swap for atv
4-pin voltage regulator rectifier atv wiring diagram
5 pin rectifier on a yamaha same as a honda?
7 pin voltage regulator swap
929 rectifier two wires
954rr rectifier connector
cbr 929 rectifier swap
cbr 954 rectifier remove pins
cbr954 rectifier wiring diagram
connections for 6 pin rectifier regulator schematic
reg/rectifier do i need one and what does it do bencbr Honda CBR400RR 8 12-09-2008 8:17 AM
rectifier 929 kid General Discussion 4 07-16-2008 7:19 AM
04/05 ECM/06 RECTIFIER kain929 For Sale 0 04-11-2008 11:40 PM
929 rectifier oconnor For Sale 0 08-30-2006 6:07 PM
929 vs 954 Rectifier swap dh2oman Honda FireBlade 2 11-06-2005 2:59 PM
