Gasket or sparkplug drain holes leaking? - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 01-28-2009, 10:27 PM Thread Starter
Images: 1
Reputation Power: 10
Alright so last week I was concerned with the spark plug holes leaking oil.... The deal is that I noticed burnt on oil or fuel where the spark plug drains are. My question is where is the spark plug drain draining from? From where the chamber drops down and the actual plug screws into the head? Or from internal? Internal doesn't make any sense to me cause I would think compression would leak . Im new to bike motors but not automotive. Anyways a few months ago the bike's MAP was disconnected and the bike ran extremely rich and fowled the plugs. Could the stains be fuel from when the bike was running rich? Why would these plug drains have oil stains? Headgasket? I will note that the stains are only where the plug drains are, nowhere else. Anyone have these oil stains? They only come down about 1 inch from the plug drains. If it were a headgasket issue why would all four of them leak? Also wouldnt I have a coolant overheating issue if it were a headgasket? The exhaust smoke has zero coolant in it, I can tell. Ive only had the bike a few months so Im not sure how old these stains are but there pretty caked on, doesnt seem to be susbstaintial leak. I havnt noticed any performance loss although Im new to the 929 it could lose 50 horse and Id still say it screamed.
Headsasket issue or stains from rich running engine? Or as in the past am I just being paranoid again?
temperedtim929 is offline
post #2 of 6 Old 01-28-2009, 11:12 PM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: Gasket or sparkplug drain holes leaking?
It's just a hole drilled through into the base next to the sparkplug. It's not internal at all.
The staining is most likely simply due to rainwater and other debris that's splashed up onto the engine. It's also not uncommon to spill a litle oil when checking valve clearances.
Unless it's actually running out I'd ignore it.
post #3 of 6 Old 01-29-2009, 9:56 AM
Images: 5
Reputation Power: 9
hey bladeracer,
what are these drain holes used for?
firebladeking is offline
post #4 of 6 Old 01-29-2009, 10:50 AM
my guess would be to stop water collecting around the base of the plugs. if water collected there, the plugs would stop sparking at the tip and arch across the water at the base of the plug (i had this problem on one of my cars)
adam_castell is offline
post #5 of 6 Old 01-29-2009, 11:26 AM
Images: 2
Quoted: 2 Post(s)
Yep :-)
Without them any water or oil splashed onto the engine would fill the spark plug holes up and the entire coil would be immersed.
post #6 of 6 Old 01-29-2009, 11:30 AM
Images: 5
Reputation Power: 9
Oh now im with you, it's a drain from the plug cavity to the outside of the block...
cant say i ever noticed them on my 929!
Human Verification
Search tags for this page
coolant in spark plug hole motorcycle
coolant leak from spark plug drainhole
gaskets for oil plug leaks on motorcycles
is there a spark plug drain motorcycle
motorcycle spark plug leak
motorcycle spark plug leaking
oil leak at spark of honda motor bike
oil leak from spark plug hole in bike
oil leak in spark plug area motorcycles
spark plug drain holes on a 94 cbr900rr
A$$holes.... LoopyLee General Discussion 15 09-12-2008 10:35 PM
Anyone Try This SparkPlug Instead? MustGoFast Honda FireBlade 45 07-31-2007 8:14 PM
Sparkplug Fouling maniac121 Honda FireBlade 5 03-07-2007 10:51 PM
A**Holes. Quick 26 General Discussion 4 12-20-2006 4:03 PM
More holes Critz Off-Topic 9 09-25-2003 11:41 AM
