Can't remove bar end... - Honda Motorcycles - FireBlades.org
post #1 of 21 Old 05-22-2009, 8:07 AM Thread Starter
Seem to have some trouble removing the one remaining bar end on my bike. When I bought it, the right one appears to have broken off when it was dropped. I can turn the bar end, but the screw and the bar end spin together. It seems that the weight inside is spinning with the bar end and not loosening. Any ideas on how to remove this thing (besides dropping the bike on the left side )?
alottaboost is offline
post #2 of 21 Old 05-22-2009, 9:23 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: Can't remove bar end...
Have you tried (while pulling on the bar end) a drill or rattle gun?
post #3 of 21 Old 05-22-2009, 9:26 AM Thread Starter
Nope. That screw looks too easy to strip if I used anything other than a screwdriver...
post #4 of 21 Old 05-22-2009, 9:41 AM
Images: 2
Quoted: 2 Post(s)
You mean you want to be able to reuse it afterwards?
When I eventually manage to get out a stubborn fastener it goes in the bin - I don't put it back in where I just got it out of :-)
You could try removing the clip-on, stand it vertically and spray WD40 or a light oil like INOX in and hope it lubricates the rubber enough to be able to pull the complete weight out in one piece but I'd be surprised if it'll work.
Otherwise you could grip the bar end in a vice and saw right through it until you cut the screw. then you just have to deal with getting the inner weight out which can be tough as well. One of mine came out easily but the other was a nightmare. I think I ended up going in with something sharp and chewing the rubber to pieces before eventually getting it out.
post #5 of 21 Old 05-22-2009, 10:33 AM
Reputation Power: 10
I had a similar problem on my 08 CBR 1000RR when I wanted o put R&G Racing bar ends on it. Basically the left side would not come off, and then it started spinning in the clip on.
So what I did was, take a medium sized set of vice grips and clamp it to the bar end, I'm only assuming your bike has enough bar end to grip onto. Once you have it clamped on there take a screw driver that fits the screw perfectly, and by perfectly I mean doesnt have any play at all, I had access to a full mechanics set of tools so I really didnt pay attention to what size it really was.
Once I did all this I had a friend hold the vice grip while I took a rubber mallet and tapped the end of the screw driver while turning it. The screw came out and there was much rejoicing.
The only problems I see with this is that the screw head looked like crap, and the bar end itself was scarred from the vice grip. I didnt care since I was replacing them with the R&G ones. So I would suggest going out and getting some after market ends and just doing it this way.
The Gerd is offline
post #6 of 21 Old 05-22-2009, 11:29 AM Thread Starter
Sounds like a plan. I'll just ride into the auto parts store (I know I don't have one that fits exactly) and pick one that fits perfect. I don't plan you reusing them, just replacing as I don't have a match and this one's a little scratched up anyways. Thanks guys!
post #7 of 21 Old 05-22-2009, 3:09 PM
Instead of the hammer and the Mallet you can try an impact driver, ( available at most auto parts stores) and it might do the job without using vise grips.
cerberusnm is offline
post #8 of 21 Old 06-02-2009, 6:20 AM
Images: 5
Reputation Power: 12
Send a message via MSN to sb1000rr
i used an impact driver and vice grips to get the stubborn bastid out of mine
sb1000rr is offline
post #9 of 21 Old 06-02-2009, 11:11 AM
Reputation Power: 9
That's what I did, worked like a champ. I borrowed one, so not sure how much $$ they cost but they are nice to have around the house anyways.
JSquier is offline
post #10 of 21 Old 06-15-2009, 12:37 PM
Reputation Power: 9
Send a message via Yahoo to robertseber
i agree impact driver works like a charm a tool needed in every box imho
robertseber is offline
post #11 of 21 Old 06-15-2009, 12:42 PM
Reputation Power: 9
I just went to Harbor Freight yesterday and bought one for $2.99. It was marked 5.99 tho. Don't know how it works, but for $3, who cares lol
JSquier is offline
post #12 of 21 Old 06-15-2009, 12:50 PM
Images: 3
I had one that I actually had to split the clip-on in two to get it out. Luckily the clip-on was bent and was trash anyways. The rubber on the bar-end seems to vulcanize(stick) itself to the inside of the clip-on after a long period of time.
BigBassTurd is offline
post #13 of 21 Old 06-15-2009, 12:53 PM
Images: 8
Reputation Power: 56
An Impact Driver?
Twincam is offline
post #14 of 21 Old 06-15-2009, 1:02 PM
Reputation Power: 9
Impact driver - Wikipedia, the free encyclopedia
you hit the back with a hammer and it goes down and turns at same time
or was you saying damn thats cheap if so i agree 6$ wth
post #15 of 21 Old 06-15-2009, 1:25 PM
Reputation Power: 9
JSquier is offline
Human Verification
Search tags for this page
bar end screw wont come out 600rr
bar end wont come out crf450r
how to get siezed bar ends off
how to remove bar ends
how to remove bar ends from motorcycle
how to remove bar ends motorcycle
how to remove motorcycle bar ends
how to take off stuck end bars handlebars motorcycle
motorcycle bar end removal
taking off cb500x barends
how do i remove seat hollowman2285 Honda CBR 600 4 12-11-2014 9:16 AM
how to remove tailsection mihomie Honda FireBlade 5 06-30-2007 10:43 PM
What is the fastest way to remove... Picotte Honda FireBlade 18 04-19-2006 10:52 PM
Did you remove your peg feelers? cyan Honda FireBlade 33 06-10-2003 4:59 PM
