Rough Idle at low rpm lacks power - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 06-09-2009, 4:24 PM Thread Starter
Reputation Power: 11
So at idle my 929 makes a knocking noise then the rpms drop down and sometimes it will shut off. When riding it doesn't have the power it should in the low rpms. the knock doesn't happen all the time its when its been running for a few min. then it starts and it doesn't do it if I rev it up. In the video you can hear it near the end and the bike shuts off. Also when the knock happens the exhaust pops almost like its not firing right. Just want to hear your idea's before I take it all apart.
YouTube - Untitled
malleybike is offline
post #2 of 7 Old 06-09-2009, 9:04 PM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: Rough Idle at low rpm lacks power
YouTube - Untitled
Anything been done to the bike or did this start out of the blue?
Have you dropped the oil to see if there's any metal in it?
You said it lacks power at low revs - how low?
But it's fine above that point?
post #3 of 7 Old 06-09-2009, 10:04 PM
Reputation Power: 34
Sounds cam chain and/or tensioner related. How many miles on the bike?
denzee is offline
post #4 of 7 Old 06-09-2009, 10:44 PM Thread Starter
Just put the bike together had to get the engine case welded. It sat for a year couldn't stop the stator from leaking, SO not sure if it did it before because I never ran it that long.
Around 5000rpms it feels better but the engine also seems to vibrate the bike alot if I go up to 7-8000. I'm starting to think it is the cam chain, when I was just running it i put the idle up to 2000(so it would make the knock) and it does sound like the chain is makeing a noise. If you have any other ideas let me know Do what to really do anything that isn't going to work.
post #5 of 7 Old 06-09-2009, 11:38 PM
Images: 2
Quoted: 2 Post(s)
Was the engine removed and/or diassembled for welding?
post #6 of 7 Old 06-10-2009, 12:23 AM Thread Starter
it was just removed it wasn't taken apart
post #7 of 7 Old 06-22-2009, 1:40 PM Thread Starter
So found out that I had #2 - #3 coils switched....I hope that was the big problem
Human Verification
Search tags for this page
2006 honda shadow spirit 750rough idle
how many rpms should my motorcycle idle at
how to fix a rough idle in a honda shadow motorcycle
motorcycle lacks power
motorcycle runs rough at low rpm
my 125cc motorcycle lacking power
my honda motorcyle idle revs vary
my honda valkyrie runs rough at low rpms
rpm drop bike shuts off
why is my motorcycle idle low
Rough Idle BurtonF166 Honda FireBlade 4 04-20-2009 3:32 PM
rough idle after riding? joshw Honda FireBlade 2 02-15-2009 11:48 PM
Rough idle on F3!? blkpitbull Honda CBR 600 2 10-26-2008 9:09 AM
Engine noise/very rough idle at startup Mavic Honda FireBlade 15 05-23-2004 7:22 AM
