CBR900 RR Oil Change - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 08-08-2009, 11:44 AM Thread Starter
Hello Everyone,
I am new to this. I am trying to change the oil on my bike and would like to ask a few questions.
1) I am not able to find where the oil drain bolt is, there are two spots that look like they might be the bolts however one has a really weird bolt that has a hole inside of it and I couldn't get a socket to fit on it and the other which is at the very bottom of the oil pan has a big hose going under it and I can not get to the bolt because of it. If anyone can post a picture for a 95 900RR it would be great I saw many videos on other bikes but I can not find it on mine.
2)What type of oil should I use, I was going for the 10W40, however someone told me that I need to use a different one. Do I need to use a different one?
Thank you,
tkh1989 is offline
post #2 of 6 Old 08-08-2009, 11:49 AM
Images: 9
Reputation Power: 17
Re: CBR900 RR Oil Change
OEM motorcycle and ATV parts from Honda, Yamaha & Polaris – Cycle Parts Warehouse
check out part number 16 in the far right hand corner.. thats your drain plug..good luck, and yes 10w40 is fine as long as its motorcycle oil or approved for wet clutches
1 more thing, part number 17 above it is your crush ring(gasket) if it is getting worn you need to replace it as it will leak..
cbr1kfireblade is offline
post #3 of 6 Old 08-08-2009, 5:55 PM Thread Starter
Thank for the reply.. I changed the oil and it was a breeze. To take the oil filter I didn't need a strap wrench.. I just took off the right side fairing and you got at the filter easily.
tkh1989 is offline
post #4 of 6 Old 08-09-2009, 1:52 PM
Images: 9
good job.. you just saved yourself alot of money and time.. just always make sure yoy got the right amount of oil. not over and not under
post #5 of 6 Old 08-09-2009, 4:19 PM
Images: 1
I have a ? does anyone know the exact amount of oil a 99 900 should hold qts or cc Thanks
DerrickCowger is offline
post #6 of 6 Old 08-09-2009, 5:03 PM
Images: 9
i would say 3.3- 3.5 oil and filter change..start with 3.25 start and let idle to warm up, turn it off and check/add as needed. do not overfill, best level to keep it at is BETWEEN the max and min so it will allow room to expand
Human Verification
93 cbr900 rr front end SteeleFalcon Honda FireBlade 28 05-09-2010 9:01 PM
97-98 VFR 750 SSA on a 96 CBR900 CBRHEMI Honda FireBlade 0 03-30-2009 7:47 PM
Will 95 CBR900 wheels fit my 96 CBR900? fastkatanaboy Honda FireBlade 1 10-31-2007 6:08 AM
my 1997 cbr900 pegleg pete Honda FireBlade 17 03-03-2007 6:53 AM
