Honda Motorcycle Forum
Honda Motorcycles
Navigation » Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda FireBlade » HELP: Buzzing sound blow fuel tank when ignition is on! Could it be the FPR?
Old 09-01-2009, 1:29 PM   #1
Mick Doohan Worshiper
Reputation Power: 9
TheJackal has a spectacular aura aboutTheJackal has a spectacular aura about
Hey Guys,
I've just come back to my 929 after a 2 week holiday, charged up the battery with my usual battery charger but found something a bit odd...
When I switch the ignition on (via the kill switch) and the injection has primed up, I can hear a sort of loud buzzing noise beneath the fuel tank...kind of like the sound an electrical transformer makes.
The bike starts up and seems to run fine but if I repeat the process again, the buzzing sound is still there. I haven't dared go out on a ride yet because I'm kind of afraid it will die half way back home!
Could it be the fuel pressure regulator or the fuel pump dying on me?
TheJackal is offline   Reply With Quote
Remove Ads
Old 09-01-2009, 2:04 PM   #2
TonyB has a spectacular aura aboutTonyB has a spectacular aura about
Re: HELP: Buzzing sound blow fuel tank when ignition is on! Could it be the FPR?
Sounds like the servo motor for the exhaust valve. I would remove the exhaust valve and check it is free to move before it chews up the teeth in the servo motor. Hopefully it will not have done so already.
TonyB is offline   Reply With Quote
Old 09-01-2009, 2:08 PM   #3
Reputation Power: 178
bladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond repute
Originally Posted by TheJackal View Post
Hey Guys,
Sounds like the servo motor is stripped. Any error codes?
bladeracer is online now   Reply With Quote
Old 09-01-2009, 2:12 PM   #4
Reputation Power: 9
Thanks for the fast replies
Thing is I've got a full Akro on the bike and also the flapper valve has been removed!
I had the exhaust fitted about three weeks ago by the Honda dealer and they didn't keep it in the correct position so I've had the annoying FI light on ever since.
Can I disconnect the servo motor and run the bike like that? I'm not fussed with the FI light....as things are going I might just keep the bike for the track and not even run it on the road.
Old 09-01-2009, 3:33 PM   #5
Unplug the servo motor and remove it.
If you still hear the noise then check the fuel pressure regulator as the pump may be pumping fuel straight into the engine via the vacuum hose.
Old 09-01-2009, 4:08 PM   #6
Reputation Power: 9
Will do, thanks.
I rotated the servo round a bit and repeated the whole process, buzzing sound went away so it definitely points to the servo being the source.
One less thing on my bike then!
Search tags for this page
2003 cavalier humming/buzzing noise from gas tank
2003 r1 fuel pump making buzzing noise
2008 honda ignition buzzing
buzzing noise from my gsxr gas tank
buzzing sound near fuel tank
cbr buzzing noise ignition
harley fuel tank rattle
humming noise from gas tank
i hearing noise from my gas tank
if fuel pump makes noise can it kill the batrery
motorcycle makes buzzing sound on ignition
sounds like our gas tank is humming?
You may not post new threads
You may not post replies
Fuel pump just stopped buzzing,wont cut on?? help! kagmyster00 Honda FireBlade 45 01-25-2009 10:20 PM
Fuel Tank / Fuel pump seal ugt33 Honda RC51 0 10-24-2008 2:13 AM
Ignition Noise in GL Sound System kn_dnwy Honda Tourers 1 08-13-2007 6:52 PM
rattling/buzzing sound on my 954 12 O Clock Honda FireBlade 6 02-26-2007 7:29 PM
Break buzzing sound? MarkN929RR Honda FireBlade 5 12-07-2003 3:55 PM
