no power to fuel or spark plugs - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 02-28-2010, 3:59 PM Thread Starter
I have been going threw this wiring harness for an 03 954. its not in the bike so im tring to figure out what to do to make it work. so far i have the bas bypassed, kill switch wired to a toggle and a starter button wired to that, ignition wired to a starter button, but not sure bout that little pink wire thats part of the ignition wires. read that it should be wired with a diode, is that to the other two wires or grounded to the engine? i have tried both but no luck, engine turns over but no fire to the plugs and no voltage at the fuel pump, also no voltage at the fan wires. i have studied the wiring diagram till it makes me sick and dnt know what to do.
linedog is offline
post #2 of 4 Old 02-28-2010, 9:36 PM Thread Starter
Re: no power to fuel or spark plugs
no one has an idea bout what might be the problem here. i just order a new ecm, i have ohmd bout every wire in the wiring harness and didnt find anything wrong.
linedog is offline
post #3 of 4 Old 02-28-2010, 11:10 PM
Images: 1
Reputation Power: 28
Sounds lame.... But have you checked the fuses? Hopefully it could be something simple like that.
Had a similar issue with my blade, and persistance pays off. You will find the problem eventually!
Good luck.
Milzy is offline
post #4 of 4 Old 03-01-2010, 1:50 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
You will need the ignition diode for a start.
Borrow a 954 ignition switch and try it.
If it works then you know that's the problem.
Human Verification
Search tags for this page
93 gsxr 750 no power in the start button?
bombardier 650 no fire to the sparkplugs
cbr 954 no fuel or fire
cbr 954 wiring harness
cbr954 no spark no fuel
honda no gas to the spark plug
honda%20no%20voltage%20to%20fuel%20pump
motorcycle problem no power on spark plugs
no gas to spark plugs? motorcycle
no power to spark plugs
no power to spark plugs motorcycle
problem when motorcycle has no electricity
1999 CBR900RR Fuel / Spark problem? bryckhaus Honda FireBlade 24 07-24-2014 7:06 PM
01 cbr 929 no spark no fuel t.hudson Introductions 7 12-05-2009 11:03 AM
No spark, fuel pump quiet, but lights work... gsteel32 Honda CBR400RR 4 06-17-2009 9:49 AM
Fuel in the oil could a power Commander 3 cause it DeathTrap Honda FireBlade 11 05-28-2008 7:31 AM
929 No start, no fuel, no spark, help please Jackelauto Honda FireBlade 11 10-26-2006 12:47 AM
