CBR1KRR08 Losing power - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 04-22-2010, 11:45 PM Thread Starter
Reputation Power: 8
Hi guys,
My bike is doing something a little strange and I don't know how to put it in words so please bear with me.
Typically my commute is about 45 to 55 minutes long with some stop & go sections and humid mornings. While cruising at any speeds the bike randomly loses power for a second the engine light comes on and the bike starts to slow down. Then it starts right up again like nothing happened and the light goes away after two seconds. During the commute this happens about 2 times and it seems like its happening with more frequency.
I don't know if this mater but the bike rides through very bumpy and lousy roads.
Any insight is helpful. What should I do?
Thanks
orien87 is offline
post #2 of 13 Old 04-22-2010, 11:59 PM
Reputation Power: 75
Re: CBR1KRR08 Losing power
lose battery terminal for sure.
BurtonF166 is offline
post #3 of 13 Old 04-23-2010, 2:50 AM
Images: 6
Reputation Power: 12
could be or dirty fuel filter or fuel pump
zero937 is offline
post #4 of 13 Old 04-23-2010, 3:01 AM
Images: 5
i dont think its fueling...i think your having ive an electrical problem...check the terminals like ^^^said...check the master fuses..check for loose wires...and if worst comes to worst bring it to the dealer...if its still under warranty bring it to the dealer FIRST...computer might stop the problem right away if its a sensor problem which it sounds like it might be...these problems are either really easy or a pain in the a$$ without the right equipment...good luck!
#1 CBR is offline
post #5 of 13 Old 04-23-2010, 11:13 AM
Reputation Power: 8
I don't believe the 08 CBR1000RR has a fuel filter.
RoadiJeff is offline
post #6 of 13 Old 04-23-2010, 4:19 PM
Images: 5
ive heard that there is a safe mode that the ECU can go into if there are engine problems and it cuts power drastically...this might be whats happening...did u change exhausts and not set the servo motor in the right spot?? Did you mess with anything electrical? I really dont think its fueling...MAYBE ignition or slight chance it has something to do with the injectors electrical signal...the bike only looses power when the engine light comes on?? If thats the case then its def the ECU that is cutting power somehow because its getting a bad or false reading from one of the sensors or electrical inputs...get it to a dealer if your not comfortable messing with the electrical components because one bad move could make things much worse for you...hope this helps
#1 CBR is offline
post #7 of 13 Old 04-23-2010, 4:32 PM
Images: 6
ok then like some dirt in the fuel pump could be it
zero937 is offline
post #8 of 13 Old 04-23-2010, 4:42 PM
Images: 5
with it being an 08 i doubt thats it unless someone dumped dirt into the gas tank...and even then i dont think it would go from perfectly fine to serious power loss...the dirt would be clogging the injectors and it would be running shi*y constantly...it is something electrical...
#1 CBR is offline
post #9 of 13 Old 04-23-2010, 7:21 PM Thread Starter
Reputation Power: 8
As for the battery terminals I'll check them out.
The bike was on cold storage during this past winter, I added some of that fuel stabilizer because I didn't know how long it was going to take for spring to arrive. Since the beginning of the riding season I rode well over 1,500 miles, but the problem began about 800 miles ago. I can only imagine that the stabilizer ran through the engine a while ago, so I don't believe it has anything to do with that, but what do I know.
No, I didn't change the exhaust. It still has the Prius sound systems, lol.
Its my opinion that the chain is a little loose, do you think that it could be causing any problems?
Thanks for all the replies.
orien87 is offline
post #10 of 13 Old 04-24-2010, 8:17 PM
Images: 6
true that then he should try to check the connection to the fuel pump
zero937 is offline
post #11 of 13 Old 04-26-2010, 11:38 AM
Images: 5
no the chain wouldnt cause that type of problem...a loose chain could cause some jerking when going from decell to accell and vice vera...but it wouldnt affect the engine in the way your describing...have you checked the servo motor for the exhaust valve? because i have heard of similar problems coming from that when guys chasnge their exhaust..i know you didnt but maybe it got whacked or something came loose or something?? otherwise...i am 99% sure it is something electrical and the ECU is causing the loss in power
#1 CBR is offline
post #12 of 13 Old 04-29-2010, 7:53 PM Thread Starter
Reputation Power: 8
Guys I read in another post that the bike misfires because of a faulty cam position sensor, attached below the link with all the info.
08 blade skips a beat
orien87 is offline
post #13 of 13 Old 06-21-2010, 10:49 PM Thread Starter
Reputation Power: 8
Update, remembered now...
It ended up being the battery terminal after all. The bolts where plenty tight which bothers me, it was swapped for the same/different ones.
Hope this thread doesn't miss guide anyone and closed some how.
orien87 is offline
Human Verification
Search tags for this page
cbr 900rr looses power
cbr power lose while bumpy
motorcycle acceleration lag loose chain
motorcycle looses power at 55
motorcycle loses electrical power
motorcycle loses power
motorcycle loses power on acceleration
motorcycle losing acceleration
motorcycle losing power
motorcycle randomly loses power
vstar motorcycle loses power and cuts off on acceleration
why would my motorcycle randomly lose power
Im losing Power......HELP A_D_T General Discussion 2 06-03-2008 3:26 PM
Losing power? reset ECU? fireblade46 General Discussion 3 10-23-2007 5:00 AM
Krammer's losing it. cyclones66046 Off-Topic 25 11-23-2006 7:03 PM
as if losing an election isn't bad enough Serial Thriller Politics 1 11-08-2006 3:07 PM
Just want to make sure I'm not losing it... Dookie Honda FireBlade 5 05-14-2004 10:39 PM
