how will changing my gearing effect my milage - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 04-02-2011, 1:49 PM Thread Starter
00 929 has 15 front 46 rear
comokiller is offline
post #2 of 13 Old 04-02-2011, 2:29 PM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: how will changing my gearing effect my milage
Lowering the gearing just allows the engine to rev higher at the same road speeds.
Those extra revs mean you burn more fuel.
post #3 of 13 Old 04-02-2011, 2:34 PM Thread Starter
how does the bike read mileage ?? is it mechanical ?? like in the gear box or something?
post #4 of 13 Old 04-02-2011, 2:37 PM
Images: 2
Quoted: 2 Post(s)
Do you mean the odometer?
It uses a speed sensor to count the revolutions of the output shaft.
Lowering the gearing will make your speedo and odo read higher.
post #5 of 13 Old 04-02-2011, 4:35 PM
Reputation Power: 7
you will see poorer gas mileage...
cbr guy is offline
post #6 of 13 Old 04-02-2011, 6:04 PM
Reputation Power: 53
With a -1 front sprocket on my 954 when I ride 1 mile it shows 1.1-1.2 on the speedo. I checked it using mile posts on the interstate. So with lower gearing changes it could be off much more. This can add up fast and make your bike look as though it has more miles on it than it actually does. It also makes it hard to determine gas mileage because your trip mileage is higher than it should be inflating your mpg.
03 CBR954 - Hindle High Mount & Ceramic Evo Muffler, PCIII w/Hub&Quickshifter, Custom Tune 146.5HP/71, 40 Shot NOS, BMC Race Filter, Factory Pro Evo Shift Kit, Undercut Trans, Air Shifter, EK ZZZ 520 Chain -1/+5 Superlite Sprockets, Swingarm Extensions, Racetech G2R Gold Valves, GPR V4 Damper, OE Solo Cowl, Adj Lowering Link, Shinko Hook-up Tire
backdoc is offline
post #7 of 13 Old 04-03-2011, 1:09 AM
Images: 2
Quoted: 2 Post(s)
Gearing changes are simple percentages so it's not at all difficult to work out how much difference it makes to the speedo and odo.
If your final ratio is 16/48 or 3.0:1 for example, and you drop one front tooth to 15/48 or 3.2:1 then you have lowered your gearing by 7%. Your speedo and odo will thus read 7% higher.
post #8 of 13 Old 04-03-2011, 2:46 AM
Greenie
jondog9's Avatar
Images: 1
Quoted: 31 Post(s)
Reputation Power: 181
you're so right! It is pretty simple. I'm speaking strictly from my experience with my RC51 tho. I'm not familiar with factory gearing on the Blades and if it even makes sense to change it. But it does on the RC. Stock is a 530-16/40. The most common swap is 15/42. That makes the rc more spirited in lower gears and lower rpms. Here's a good link that goes in depth.
ROGUE RC51 Common Gearing
I apoligize if this has been posted a hundred times before, kinda brand new to this forum
jondog9 is offline
post #9 of 13 Old 04-04-2011, 4:51 PM
You won't necessarily see poorer economy, it will depend on your riding style and type of riding. Whilst I haven't changed the gearing on my 929 I have on my previous bike (-1 on the front) and it made no difference to the economy that I could tell and I measured economy on every tank fill.
KeenGolfer is offline
post #10 of 13 Old 04-04-2011, 7:18 PM
Images: 4
Reputation Power: 8
Send a message via Yahoo to letsride
you should only see about a 10 mi difference per tank with the gearing change.
letsride is offline
post #11 of 13 Old 04-04-2011, 10:36 PM
Images: 2
Quoted: 2 Post(s)
Did you remember to deduct the extra miles from the trip meter?
post #12 of 13 Old 04-05-2011, 8:14 AM
Yeah. Checked speedo before/after with GPS. Can't remember how much speedo was out now, but from what I could tell it made 2/5 of SFA difference to economy.
post #13 of 13 Old 04-05-2011, 8:23 AM
Images: 2
Quoted: 2 Post(s)
It depends on how accurately you're measuring your fuel economy.
But -1 off the front is a pretty minor drop in gearing.
Human Verification
Search tags for this page
change gear ratio affect speedometer
changing gears on bike impact on mileage
gearing a sportbike for gas mileage
gearing motorcycles for mpg
how does changing gear ratios affect your speedo on your motorcycle
how does gearing a motorcycle affect mileage
how much does sprocket change speedo
how much will sprocket affect mpg
motorcycle gearing and mpg
will a sprocket change affect mileage on a motorcycke
changing the gearing hfb Honda FireBlade 23 09-10-2010 8:09 PM
Changing gearing: questions and concerns autoxr37 Honda FireBlade 14 02-05-2010 8:48 AM
Lower gearing--Changing sprocket up front musikkant Honda RC51 29 08-23-2007 11:45 PM
So milage doesnt effect the value of a WRX MrX954 Off-Topic 41 03-09-2006 2:16 PM
