Fuel System Cleaners/Additives - worth using? - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 04-11-2011, 5:06 AM Thread Starter
Reputation Power: 7
My bike was stored away over Winter, 5 months unused, but now back on the road. The bike was started monthly whilst stored in the garden.
The other day I went out for a ride, and at higher speeds and higher revs I noticed a slight lack in performance. I.e as you give throttle whilst the revs are high - there was a slight lack and mild jerky feeling.
I'm guessing at the moment it's a carb/petrol issue. The bike probably needs a good clear out. I didn't want to strip the carbs and clean them, but is there anything I can maybe supplement the fuel with to help clean it out? Like a petrol additive?
Is it worth it - and if so, are there any recommendations or will anything do, i.e Redline fuel system cleaner.
Many thanks,
blade of steel is offline
post #2 of 3 Old 04-11-2011, 8:57 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: Fuel System Cleaners/Additives - worth using?
Many thanks,
I'm not a fan of putting any additives through an engine on top of all those already in the fuels and oils we use.
You can certainly try it but if the carbs need cleaning there's only one way to clean them properly :-)
post #3 of 3 Old 04-11-2011, 11:57 AM
Images: 1
Reputation Power: 52
I run two tanks per year with Lucas oil injector cleaner. Once in the spring first tank, and one mid summer.
Rendell is offline
Human Verification
I need help with my CBR F4 fuel system. 3digitspeed Honda CBR 600 8 10-11-2010 12:54 PM
RC51- BMC aftermarket air cleaners ponemahjohn For Sale 6 05-18-2009 9:56 AM
Keep the stock air cleaners for the map? blackdog76 Honda RC51 1 09-21-2007 12:21 AM
Fuel Map for 929 w/M4 system HueyRacer Honda FireBlade 2 11-05-2004 11:55 AM
PLEASE, NOT AN OTHER OIL THREAD! So you like putting additives in your oil? nedro General Discussion 4 02-29-2004 3:21 AM
