HELP, US ecu and wiring harness on HISS bike - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 05-21-2012, 4:39 AM Thread Starter
HElloz,
for some absurd reason the hiss chip vanished from my key so i purchased an American ecu and wiring harness to get away with hiss completely, i am still using the old ignition with hiss sensors ( disconnected)
now the bike turns but the fuel pump doesnt prime and there is no current at the plugs.
there are 4 wires in the connector which connects to the ignition switch...and only three wires comming from the ignition switch.
the pink wire on the connector doesnt have a corresponding wire that comes from the ignition switch.....i am hoping that is my problem.
could someone please point me in the right direction.....
I am in India and getting parts is a time consuming process, it would take me a few weeks to get a new ignition switch from china, i was initially hoping that there would be a way to use the ignition switch that i already had on my hiss bike.
I remember reading up on some diode trick when i was searching about changing the non hiss ecu and harness.
guys please help me i havent ridden in 8 months now
thanks in advance!
badmatahfingha is offline
post #2 of 8 Old 05-21-2012, 6:01 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: HELP, US ecu and wiring harness on HISS bike
Originally Posted by badmatahfingha View Post
HElloz,
thanks in advance!
What sort of bike is it?
I think the pink wire is the diode circuit.
post #3 of 8 Old 05-21-2012, 9:39 AM Thread Starter
Hi Blade,
its a 2000 929rr, I found the wiring diagrams that you posted elsewhere on this board and was comparing the Europe and American version.
i see the pink wire in hiss( European) version goes to the immobiliser whereas in the US version it goes to the ignition switch. i only have 3 wires coming from the ignition switch like the European version but since now i have a American wiring harness there is that extra pink wire which has no place to connect in the ignition.
even the enginestop/starter switch wiring is different.
I will go to my mech and get some pics tomorrow, and hopefully the wiringdiagrams that you had posted will help him figure out where the other connectors go, i think there was one connector which still has no place to go.
Thanks!
post #4 of 8 Old 05-21-2012, 1:48 PM Thread Starter
more comparing of Eu and US wiring diagram, there seem to be oxygen sensor and purge control valve on the US that is missing from the European , since i have changed to a US harness i wouldnt know where to connect those as i dont think i will have oxygen sensor and purgecontrol valve......i dont even know if i am making sense :~
sorry for my bad english
post #5 of 8 Old 05-21-2012, 1:52 PM
Images: 2
Quoted: 2 Post(s)
Those are only on the Californian harness.
post #6 of 8 Old 05-21-2012, 10:40 PM Thread Starter
That is good news because i have the non cali ecu and harness.
so what do i do with the pink wire now? i am confused how to put a diode on it....diode one end on the pink wire and then ground it?
thanks for the help Blade, i will be at my mechs and get pictures
post #7 of 8 Old 05-23-2012, 5:20 AM Thread Starter
went to the mechanic the camera had no battries
so i was trying to get the pink back in the hiss system and give it power...didnt seem to work.
was reading up about chinese ignition switches , apparently they also come with 3 wires without the diode, from what i have read online so far one has to attach a diode between the pink wire from the harness to the black/red from the ignition.
so i am off to search for a 3.9v zener diode.
will report back
post #8 of 8 Old 02-28-2014, 5:45 AM
Quoted: 2 Post(s)
Reputation Power: 75
old thread but this is what you need to know:
http://youtu.be/2ISgxtQXs9o
My 900RR Winter Project
http://www.fireblades.org/forums/hon...er-revamp.html
Lambchops is offline
Human Verification
Search tags for this page
2001 honda goldwing european hiss wiring diagram
2001 honda hiss wiring diagram
2006 cbr1000rr wiring loom
2012 cbr1000rr wiring harness and ecu
bike wiring model
cbr 929 ecu pinout pdf
cbr 929rr modify us wiring
changing wiring cbr1000 honda
hiss on us cbr954 ecu
honda cbr1000rr 05 computer diagram
954 track bike wiring harness w/ race fairing mgolden Honda FireBlade 4 05-11-2012 1:55 PM
2001 fireblade (929) hiss harness connections kungfupete Honda FireBlade 3 09-25-2011 2:39 PM
wiring harness tlstreak Streetfighter 16 07-24-2011 6:42 PM
WTB Wiring Harness 01 CBR 929 dbleck Wanted 1 04-24-2006 10:24 AM
