Honda Motorcycle Forum
Honda Motorcycles
Navigation » Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Interceptor / VFR » Occasional backfire off-throttle
Honda Interceptor / VFR Discussion of the Honda Interceptor and Honda VFR Motorcycles.
Old 05-21-2004, 11:11 AM   #1
Reputation Power: 10
brian48130 is on a distinguished road
Send a message via AIM to brian48130
Any idea what would cause backfiring off-throttle? It's not too bad but seems to happen regularly. It also pop'ed real loud when I started it this morning. This is a 94 VFR750 w/20k miles.
brian48130 is offline   Reply With Quote
Remove Ads
Old 05-21-2004, 11:54 AM   #2
abtech's Avatar
Images: 4
Reputation Power: 32
abtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud ofabtech has much to be proud of
Re: Occasional backfire off-throttle
Could be the pair system. If the valve is stuck, it may be running out of sync causing air into the exhaust at the wrong time.
and your girlfriend too.
abtech is offline   Reply With Quote
Old 05-21-2004, 12:17 PM   #3
luvtolean's Avatar
Images: 1
Reputation Power: 38
luvtolean has much to be proud ofluvtolean has much to be proud ofluvtolean has much to be proud ofluvtolean has much to be proud ofluvtolean has much to be proud ofluvtolean has much to be proud ofluvtolean has much to be proud ofluvtolean has much to be proud ofluvtolean has much to be proud of
An exhaust leak can cause it as well.
...in bed.
...you are trying to insult me, and I agree it is very easy to do, if you haven't sufficient respect for yourself. - Tolstoy
luvtolean is offline   Reply With Quote
Old 05-24-2004, 2:48 PM   #4
Hmm, I'm gonna take it apart to check the air filter anyway, so I'll check out the pair valve.
The muffler was about to fall off it was so loose (I didn't install it?), but I thought I sealed it up real good. I'll have to check that too...
Thanks
Old 05-24-2004, 10:29 PM   #5
Reputation Power: 12
G-Man is on a distinguished road
Send a message via MSN to G-Man
LOL.
Backfires? Trying to get rid of them?
Why?
Hell, I love the fact I can backfire my RC30. Nothing funnier than driving past a bus stop, rolling the kill switch off and back on and seeing people duck for cover. I've been told that the Kerker slip-on on the RC30 produces a very convincing BANG if you aren't expecting it.
G-Man is offline   Reply With Quote
Old 05-24-2004, 11:46 PM   #6
RPinOZ's Avatar
Images: 5
RPinOZ is on a distinguished road
Thanks
There's your answer. A loose muffler can suck in air on decel and make a combustible mix in the pipe. Also if your headers are slightly loose that'll do it too. What pipe are you running by the way. I had a Staintune on my 96 VFR and when I took the restrictor out it would pop a bit on decel. Sounded pretty highly tuned on the track
I don't think a 94-97 VFR has a pair valve. I never saw it mentioned in the shop manual.
Cheers
RPinOZ
my bike
I'd like to die peacefully in my sleep like my grandpa
not screaming in terror like the passengers in his car.
RPinOZ is offline   Reply With Quote
Old 05-25-2004, 4:39 PM   #7
I bought my vfr 20k mi used with the Two Brothers slip-on already on. I haven't taken it apart yet, but I'll check the headers. The muffler seems tight now but it was pretty loose before I re-attached it. I may need to do it once more and use a ton of sealant.
Might be right about the pair valve, I never looked into it.
Doesn't backfiring damage the engine? If not then I certainly don't care. What about exhaust leaks, do they cause extra wear, less power, etc? I haven't been riding my blade because it seems to have a leak around the headers.
Old 05-25-2004, 4:50 PM   #8
Pete's Avatar
Reputation Power: 25
Pete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to behold
It *can*. You should find the problem and get it fixed...end of story.
Pete is offline   Reply With Quote
Old 05-25-2004, 5:34 PM   #9
That depends on "how" it's backfiring. Significant damage from backfires from the exhaust (caused by air being introduced into the exhaust stream igniting unspent fuel) is extremely unlikely and limited to higher exhaust header temps and possibly exhaust packing being dislodged.
Now "front-firing", ignition in the intake tract (detonation prior to the intake valves fully closing) is alot more serious and needs to be addressed as carbs/EFI/airbox sensors were not designed to handle little booms.
Old 05-25-2004, 5:54 PM   #10
Pete's Avatar
The amount of damage caused by an exhaust backfire is dependent on how far "downstream" the explosion occurs. I have seen exhaust valves bent by backfires caused by air leaking in at the exhaust ports. And since we don't know where his problem is, the safe thing to do is to find the culprit and fix it.
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Interceptor / VFR
Search tags for this page
backfire release throttle motorcycle
cause of backfiring motorcycle
honda trx450fe backfiring on decel any fixes
honda valkyrie backfire
motorcycle backfire causes
motorcycle backfire with flames cause
motorcycle backfiring causes
what can cause a motorcycle to backfire
what causes a motorcycle to backfire
what causes a motorcycle to backfire when throttle is incresed
what causes backfiring on a motorcycle
what would cause a motorcycle to backfire
You may not post new threads
You may not post replies
Is 96% of WOT (wide open throttle) good enough? bloodso Honda FireBlade 10 11-29-2003 11:52 PM
on/off throttle is driving me up a wall. risc32 Honda FireBlade 23 08-07-2003 12:31 PM
SPOOGE in my throttle bodies! Warchild Honda FireBlade 34 07-20-2003 9:13 AM
