I'm got the carbs back from the shop and I'm trying to install them but I'm finding it almost impossible on this horrid V4 system.
The VFR has these rubber collars that hold the carbs to the head. I've figured out which way is up and how they need to be aligned to the cutouts match up where they need to.
The problem is that while I can attach the collars to the carbs or to the heads I can't do both. I should have figured that this would be a nighmare since they were next to impossible to get off in the first place
I imagine that I need to partially place the collars on the head with the holes facing up and not fully seated. Then I should set the carb on top and press down to fully seat the collars on the head while seating them on the carbs too. Unfortunately this isn't working as smoothly as I imagined it would. I can't seat them by hand or by sitting on it. I've tried to hammer them on and also ratching them on but to no avail. I MAY need to replace the collars but I don't think so since they are still pliable and have no signs of cracking.
I can't reference my service manual since it's currently buried somewhere in a storage locker but I think it would probably say "Attach the carb and tighten collars" or something equally unhelpful. Is there some sort of trick to installing these things or should I just try and gorilla the damn things in??
