| Remove the CAT from a Vtec VFR I got this from VFRD and though some of you would like to try it:
For all V-Tech owners who are looking for a full catless exhaust system I'm letting the cat out of the bag !
Stock 98-99 VFR 800 headers are a direct bolt-up to our V-Tech's and only lack a center stand bumper mount. These tubes are slightly larger in dia than the 02 up bikes and the up pipe connector comes out at the same angle as the 02-up, so the stock undertail riser slips right on.
This stock unit offer's better flow than removing the guts of your Cat and the larger tubes should provide a little better top end HP.
All you need is 4 new exhaust gaskets and a set of used headers. Finding a used set isn't easy and will only get harder as this gets out, so get on the ball ! |
