By request . . .
Old 05-31-2005, 5:45 PM
abtech's Avatar
Bike(s): 2007 RC51
By request . . .
A few pics:
See this thread for more . . .
abtech is offline
Old 05-31-2005, 6:20 PM
Baketech's Avatar
Re: By request . . .
Originally Posted by abtech
A few pics:
Holy moley....I must have quit reading that thread before you posted those pics...
I know it makes "absolutely" no sense...but I have a hankering to build a V4 track bike....
I'd like to do a 94-7...but I like the FI on the 800, and I have a smoking deal lined up on a donor bike. The biggest hangup is the integrated rearsets...but I think I can whittle out a new set without too much trouble....
Sith Apprentice
Baketech is offline
Old 06-01-2005, 7:16 AM
abtech's Avatar
Bike(s): 2007 RC51
There were a lot of advantages with the earlier models, including the 5.5" rim designed to carry a 180 tire with adequate swingarm clearance to shorten the wheelbase by running a short chain. I ended up making extension arms for the rearsets, a rear subframe to fit the tail section and had a new shock link machined that was based on the late 90' RC30 ratio. Stig Pettersson (PPS) did the forks and Bob Favorite at Fox did the shock. Tom Kipp Sr. made up a couple of sets of 14 to 1 pistons that Rick Tomzcik hand cut to match the GSXR1100 valves we installed (and modified the head to match). The crank was balanced with the rods and pistons as a unit. Superbike Mike did the porting and redid the intakes to match a set of TTF1 magnesium 40mm carbs I found in England. The only thing I never got together was a custom ECU that would let the bike rev a couple thou higher, as the bike was making serious power right into the limiter and with the crank work etc., it could have handled 14K without much problem.
Almost forgot: I 86'd the stock oil cooler and replaced it with a 10 row Earl's unit that kept the motor down in the useable temp range. The stock radiator and oil cooler were definitely not up to the task.
abtech is offline
Old 06-01-2005, 7:25 AM
Baketech's Avatar
Did you shorten the wheelbase by flipping the eccentric, or did you have to do swingarm work?
Those engine mods sound tasty...
I'm thinking more along the lines of a standard 840 build...should be plenty of power for a track day fun machine...
What kind of dry weight were you able to hit?
I'm a bit concerned about being able to shed any significant weight using an 800...
Edit:
Glad you brought up cooling...I don't think I want to stick with the side mount rads....would rather have a setup like the RC45...thoughts?
Sith Apprentice
Baketech is offline
Old 06-01-2005, 7:51 AM
abtech's Avatar
Bike(s): 2007 RC51
Edit:
I didn't modify the swingarm, it had enough room to move the tire forward to get to 55.2" axle to axle. The machine weighed 390 with a full tank of gas when I finished with it. The first 80 pounds were cake (exhaust, front & rear subframes, bodywork etc.). The last 15 were a lot harder (magnesium carbs, turned down forks, smaller battery, 520 chain, TZ rad to replace the stocker, TI axle and various nuts and bolts etc.).
You may find the 800 motor easier to mod, as you can mill the heads with a chain driven cam setup. The RC30s can be milled if you shim the cams, but the 180 degree VFR has zero clearance tolerance which precludes shimming the cams to compensate for a lower deck height (thus the custom pistons).
abtech is offline
Old 06-01-2005, 7:56 AM
Cycle Trendz Racing
SilverBullet's Avatar
Bike(s): S/B 954..Drag Racing Specialist and 2006 Champion
Rep: SilverBullet has a spectacular aura aboutSilverBullet has a spectacular aura about (185)
Awesome pics Ab! Thanks for sharing with us!
SilverBullet is offline
View SilverBullet's Profile View SilverBullet's Gallery Visit SilverBullet's homepage! Find More Posts by SilverBullet
Old 06-01-2005, 7:58 AM
Baketech's Avatar
Damn...390 sounds nice...
The 800 has gears, so probably won't do any milling...if I do any motor work at all, I'll just send it to DynamoHumm for an 870 kit.....
Sith Apprentice
Baketech is offline
Old 06-01-2005, 8:07 AM
abtech's Avatar
Bike(s): 2007 RC51
ooops. I thought the 800 was based on the RC45 cyclinders but with chain driven cams. My bad . . .
abtech is offline
Old 06-01-2005, 9:44 AM
Baketech's Avatar
Love them gears...
Sith Apprentice
Baketech is offline
Old 06-01-2005, 9:48 AM
Pete's Avatar
Bike(s): '06 CBR1000RR, '06 CRF450X, '06 CRF100
Rep: Pete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to behold (815)
Build two and sell me one.
Pete is offline
View Pete's Profile View Pete's Gallery Find More Posts by Pete
Old 06-01-2005, 9:53 AM
Baketech's Avatar
I only got one donor bike...
Sith Apprentice
Baketech is offline
Mr. Brownstone
Bike(s): 05 600RR
I thought ALL murdercycles were donor bikes?
BDA116 is offline
Old 06-01-2005, 9:54 AM
Baketech's Avatar
That's it....I'm leaving....
Sith Apprentice
Baketech is offline
Old 06-01-2005, 10:00 AM
Pete's Avatar
No, you have two, go look in your garage.
Pete is offline
Old 06-01-2005, 10:01 AM
  #15
Pete's Avatar
You good friends with Pip, too?
Pete is offline
  #16
Mr. Brownstone
Bike(s): 05 600RR
By the way, your avatar is awesome. And by that I mean that I hope that bike went down on that banana (I can spell that thanks to Gwen) peel, because the rider is obviously a squid, and therefore should die.
BDA116 is offline
Old 06-01-2005, 10:07 AM
  #17
Baketech's Avatar
Actually there is another 800 in my gurge right now....but it belongs to another member, and he might get upset if we chopped it up...
Edit:
Lmao at BDA....
Sith Apprentice
Baketech is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:14 AM.
