| Re: Valve adjustment on current VFR Some VTEC owners indicated they never plan to adjust them. If history holds, the valves typically don't need adjustment at their first interval, and have a fairly long interval. Definitely check out the discussions and decide for yourself.
I haven't seen how the rear cylinders sit on the current VFR, but on my '94, the rears are the easy ones to get to because they are wide open when the tank is off. The fronts get a little tight in the frame because it is higher there.
Welcome to the site. Always liked the Transalp. |
