best place to mount my Ram-ball mounts for my V1 Detector and GPS on a 95 VFR
03-13-2007, 12:26 AM
Bike(s): 95 VFR Posts: 19
| best place to mount my Ram-ball mounts for my V1 Detector and GPS on a 95 VFR I have a couple of long and short arm Ram ball mounts for mounting my Valentine 1 detector and my Garmin Emap GPS.
Any suggestions on where to mount the mounting balls (eyelet style) on a 95 VFR?
Brian in Austin
Reason: typos
04-12-2007, 5:59 AM
Join Date: 02-28-2007 Location: Horsham, West Sussex, England
Bike(s): 1996 Honda VFR 750, 1978 Honda CB750F2 Posts: 357
Rep:  (12) Rep Power: 2
| Re: best place to mount my Ram-ball mounts for my V1 Detector and GPS on a 95 VFR Sorry I can't help I wish I knew, but if you do get any joy please let me know as I am thinking of doing the same.  |
04-12-2007, 9:35 AM
| Re: best place to mount my Ram-ball mounts for my V1 Detector and GPS on a 95 VFR Quote:
Originally Posted by Gaunty42 Sorry I can't help I wish I knew, but if you do get any joy please let me know as I am thinking of doing the same.  | I used the clip on pinch bolts......bought longer bolts at the local hardware that were long enough to entend through the back side of the clip on.....then finished with a washer style nut snugged down to ensure that my pinch bolt stayed tight. Stacked about 5 or 6 washers under each ram mount to move the mounts away from the clip ons. |
04-12-2007, 9:47 AM
| Re: best place to mount my Ram-ball mounts for my V1 Detector and GPS on a 95 VFR Aha. There always more than one way to skin a cat. Thanks for the advise.  |
04-12-2007, 10:06 AM
Originally Posted by Gaunty42 Aha. There always more than one way to skin a cat. Thanks for the advise.  | PS.....washers are stacked along the bolt between the Ram mount and the clip ons.
and also used another washer between the ram mount and the bolt head.
Typo: "Entend" should read "Extend" |
04-12-2007, 10:08 AM
Originally Posted by Gaunty42 Aha. There always more than one way to skin a cat. Thanks for the advise.  | Also,....please use a "Hardened" bolt. I found a hardened washer head bolt that matched the original perfectly. |
04-12-2007, 11:48 AM
| Re: best place to mount my Ram-ball mounts for my V1 Detector and GPS on a 95 VFR Excellent, thanks a million.  |
04-12-2007, 12:32 PM
Bike(s): '01 CBR929 Age: 49 Posts: 7,695
| Re: best place to mount my Ram-ball mounts for my V1 Detector and GPS on a 95 VFR RAM makes an expanding insert with mounting ball that fits into the hollow steering stem on the VFR (at least on my VFR800). It worked great for mounting a GPS, bullet cam, or radar detector.
