| Re: 1987 VFR 750 ??? Make Model Honda VFR750FII-H Year 1987 Engine Liquid cooled, four stroke, 90°V-four cylinder, DOHC, 4 valve per cylinder. Capacity 748 Bore x Stroke 70 x 48.6 mm Compression Ratio 10.5:1 4 x 34mm Keihin VD carbs Max Power 106 hp 77.4 KW @ 10500 rpm 6 Speed / chain Front Suspension 41mm air assisted telescopic fork Rear Suspension Pro-link adjustable preload, 105mm wheal travel. Front Brakes 2x 296mm discs 2 piston calipers Rear Brakes Single 256mm disc 2 piston caliper Front Tyre 110/90 V16 Rear Tyre 130/80 V18 Dry-Weight / Wet-weight 198 kg Fuel Capacity 20 Litres
This years model came in solid blue, silver or white. The white is the most valuable and the most rare. The V4 motors in these bikes were very torky, but smooth. The engines are very reliable and, if properly maintained, will run 100,000 miles with no problems.
They are kind of Honda cult bikes these days and are highly prised if in good condition. An 87 VFR 750 in white with low to medium miles, with the original plastics in good condition will go for $3000-$3500.
Things to look for:
The rear solo cowl that covers the passenger seat with the original bolts.
Mostly stock, possibly with an aftermarket pipe.
The original seat.
A center stand. It was an option on these bikes and impossible to find today.
Original mirrors.
Things to watch for:
The tail on these bikes are fragile, especially the light. Look for cracks in the side of the tail light and the one piece plastic tail at the rear.
The rear plugs on these are a bitch to change.
Rust in the tank.
Tire choices are limited for these bikes these days. They are bias-ply tires so the options are limited. Only two manufacturers are still around last time I checked. There are plenty available, just one style or tire to choose. The Dunlop 501s are the ticket as I recall.
I owned an 86 VFR 700 and a 87 VFR 750. Both were great bikes. Good power and wonderful to ride. I commuted on mine every day. I wish I still had it. |
