Piston ring change
Old 05-13-2007, 3:12 PM
  #31
Bike(s): VF750F (engine)
Rep: scuba14c is on a distinguished road (10)
Re: Piston ring change
Alright, I've come upon another problem. I'm trying to get the clutch nut off and it just won't come loose. Something turns when I rotate it counterclockwise (the clutch gear and primary drive gears are locked), but it never advances on the threads. Does the engine have to be in gear to get the nut off? And if it does, how do I get it in gear after it's out of the frame?
scuba14c is offline
View scuba14c's Profile View scuba14c's Gallery Find More Posts by scuba14c
Old 05-13-2007, 4:11 PM
  #32
Bike(s): 2002 CBR600F4i
If you have a service manual it should tell you how to do this, if you don't have one they are only like $10 to download one online.
sinfuldragon is offline
Old 05-13-2007, 5:34 PM
  #33
Bike(s): CBR929
Rep: zfrilly2 is on a distinguished road (32)
Are you using in impact? You can put it in gear by grabbing hold this the shift shaft with vise grips (be very carefull not to damage the splines, use a rag bteween it and the vise grip). I'm with sinful consult a manual on what recommended procedure is.
zfrilly2 is offline
View zfrilly2's Profile View zfrilly2's Gallery Find More Posts by zfrilly2
Old 05-13-2007, 8:22 PM
  #34
I have the service manual, that is what has gotten me this far. I have been using an impact socket and a 20" breaker bar for all of the work I have been doing. The manual simply says to remove the clutch nut and lock washer. They don't explain how, so I assume it's simple.
scuba14c is offline
Old 05-13-2007, 8:26 PM
  #35
Bike(s): CBR929
Any engine I have worked on, once the clutch gear is locked it should just screw off. The outer clutch and gear is splined to the shaft the nut is on. It shouldn't just spin. Were you able to get it in gear, if so does the output shaft (where the sprocket goes) spin when you try and remove the nut?
zfrilly2 is offline
Old 05-13-2007, 8:37 PM
  #36
thats how helpful mine was with removing the front sprocket bolt... talk about a pain in the ass!!!!
Old 05-13-2007, 8:47 PM
  #37
Carolina Kracker
Quick 26's Avatar
Bike(s): 06 CBR1000rr, 05 CBR1000RR Repsol Edition(stolen)
Rep: Quick 26 has a spectacular aura aboutQuick 26 has a spectacular aura aboutQuick 26 has a spectacular aura about (211)
need pics
Quick 26 is offline
View Quick 26's Profile View Quick 26's Gallery Find More Posts by Quick 26 My Map Location
Old 05-14-2007, 9:57 AM
  #38
I haven't tried getting it into gear yet, I'll get to that a little later today. How much force dhouls I have to put on it to get it to turn? I'm using most of my body weight just to get it started.
Here are the pics
Disassembly pictures from motor sports photos on webshots
scuba14c is offline
Old 05-14-2007, 10:40 AM
  #39
Bike(s): CBR929
To get what to turn? If you are talking about the clutch nut it is quite a lot, it shouldn't take much to put it in gear.
zfrilly2 is offline
Old 05-14-2007, 11:01 AM
  #40
Yeah, I was referring to the clutch nut.
scuba14c is offline
Old 05-14-2007, 11:03 AM
  #41
Bike(s): CBR929
I don't know the exact torque but I think it should be around 75lbs. Use the impact on the clutch nut. How do you have the clutch gear locked?
zfrilly2 is offline
Old 05-14-2007, 11:06 AM
  #42
Carolina Kracker
Quick 26's Avatar
looks like he is using the penny, it should come right off with an impact
Quick 26 is offline
Old 05-14-2007, 11:09 AM
  #43
Bike(s): CBR929
Am I missing something, where are you seeing this? The penny trick works great.
zfrilly2 is offline
Old 05-14-2007, 11:11 AM
  #44
Carolina Kracker
Quick 26's Avatar
look closely where the counter ballencer and clutch gear meet, you can see all wadded up
Quick 26 is offline
Old 05-14-2007, 11:13 AM
  #45
Bike(s): CBR929
I can't find any pictures.
zfrilly2 is offline
Old 05-14-2007, 12:46 PM
  #46
The pictures are linked several posts up. Is it necessary to use an impact? I don't have easy access to one.
scuba14c is offline
Old 05-14-2007, 12:50 PM
  #47
Bike(s): CBR929
That is the easiest thing to do . If you use a breaker bar put pressure on the nut and hit the breaker bar with a hammer it generaly works better this way. Soak it down with pb blaster and try a little heat if no impact is available. I recommend the impact. it'll get it right off there.
zfrilly2 is offline
Old 05-14-2007, 1:30 PM
  #48
Carolina Kracker
Quick 26's Avatar
you will catch hell with a breaker bar
Quick 26 is offline
Old 05-14-2007, 3:39 PM
  #49
Why would I catch hell with the breaker bar?
I'm just going to go buy an impact wrench tonight. We'll see if that loosens it.
scuba14c is offline
Old 05-14-2007, 3:47 PM
  #50
Carolina Kracker
Quick 26's Avatar
the shock of the impact will usually spin them off, if you use an impact you have to make sure your air hose and compressor have enough volume to feed the gun. you can shock it with a breaker bar a friend and a big hammer
Quick 26 is offline
Old 05-14-2007, 3:49 PM
  #51
I was just going to get an electric impact wrench. It imparts 240 lb.ft. Will that be enough?
scuba14c is offline
Old 05-14-2007, 4:09 PM
  #52
Bike(s): CBR929
should be.
zfrilly2 is offline
Old 05-14-2007, 9:09 PM
  #53
I bought the wrench. I spent an hour and a half with the breaker bar, the wrench only needed 4 impacts to loosen it! Now that the clutch and alternator are off, this should be apart by the end of the week.
scuba14c is offline
Old 05-14-2007, 9:25 PM
  #54
Bike(s): CBR929
Nice having the right tools for the job!
zfrilly2 is offline
Old 05-15-2007, 7:02 AM
  #55
Carolina Kracker
Quick 26's Avatar
told you the breaker bar would be a biach glad you got it off
Quick 26 is offline
Old 05-16-2007, 12:17 PM
  #56
Hey, when I'm loosening these crankcase bolts, every once in a while there's some white liquid shooting out. Is this just a grease that honda used, or do I have something to worry about?
scuba14c is offline
Old 05-16-2007, 12:18 PM
  #57
Carolina Kracker
Quick 26's Avatar
you did drain the oil right?
Quick 26 is offline
Old 05-16-2007, 6:32 PM
  #58
Yeah everything is drained. It looks like lithium grease, but I don't know why it would be in the screw holes.
The engine has been disassembled, and I think the leaking problem was caused by the piston rings not being aligned correctly. On the worst cylinder, the gaps were almost in line with each other. Is it normal for rings to rotate when the engine is in use? And if the rings are like that, does it mean I just have to spin them the other way to get the compression back up?
Here are pictures of the engine now-
scuba14c is offline
Old 05-16-2007, 8:00 PM
  #59
Bike(s): CBR929
I always put rings 120 degrees apart. Make sure to gap the new rings. As for the fluid in the case bolts, I have no idea. Are you using andything like wd40 or pd blaster? If so, then it could be that. Grease is not normally used on case bolts. Does the flywhee have to come of for you to get the crank out, it doesn't appear to? Did you use the puller or some other method, fast shipping on puller.
zfrilly2 is offline
Old 05-16-2007, 8:45 PM
  #60
Would it be possible to reuse these rings, or would I be better off going with new rings. It looks like the only problem is that they rotated during use.
The alternator was the only part that needed the puller, and the impact wrench too and the motion pro puller took care of that. The crank just lifted out after I took the clamps for the pistons off. And I haven't needed to use any penetrating oil. I don't know what this stuff is.
scuba14c is offline
B
