Piston ring change
Old 05-16-2007, 8:52 PM
  #61
Bike(s): CBR929
Rep: zfrilly2 is on a distinguished road (32)
Re: Piston ring change
As long as the cylinders aren't too scored it may be ok. Carefully examine everything, you no how much trouble it was to get it apart do you want to do it again. It may be best to hone it and get new slightly oversized rings and gap the rings to the hone. The old rings were somewhat "mated" to the cylinder. You can probably get in honed at a small engine shop very cheap, or if there is a regular machine shop in the area they can do it as well. The dealer will probably send it to someone as not many do it themselves. While you are in the engine check over the gears. Make sure they are not broken or worn, check the shift dogs as well. Are you putting this back into the bike,I see it says enigine under your bikes?
zfrilly2 is offline
View zfrilly2's Profile View zfrilly2's Gallery Find More Posts by zfrilly2
Old 05-17-2007, 7:24 AM
  #62
Carolina Kracker
Quick 26's Avatar
Bike(s): 06 CBR1000rr, 05 CBR1000RR Repsol Edition(stolen)
Rep: Quick 26 has a spectacular aura aboutQuick 26 has a spectacular aura aboutQuick 26 has a spectacular aura about (211)
wait before you go throwing a hone through that engine, make sure you call the dealership and find out if the cylinder has a coating inside them. if they are coated you dont hone it, just wipe it out INSTALL NEW RINGS and go. as far as the lube on the bolts, some companies us an anti siese type fluid on the bolts due to the heat and alumnium. your ring gaps should be evenly staggered. as for them lining up, the are most likely worn out. you can take your old rings and insert them in the cylinder and check the gap in them with a feeler guage.
Quick 26 is offline
View Quick 26's Profile View Quick 26's Gallery Find More Posts by Quick 26 My Map Location
Old 05-17-2007, 10:16 AM
  #63
Bike(s): VF750F (engine)
Rep: scuba14c is on a distinguished road (10)
The gears look like they haven't even been touched. I can't see any damage at all to the shift forks either. This engine is actually gonig to be used in an offroad buggy project.
I was thinking it might be anti sieze of some sort, I was just surprised that it was pressurized. Would a feeler gauge be available locally?
scuba14c is offline
View scuba14c's Profile View scuba14c's Gallery Find More Posts by scuba14c
Old 05-17-2007, 10:37 AM
  #64
Carolina Kracker
Quick 26's Avatar
yeah any auto store should sell them or wal mart might have them. i would not reuse the rings anyway, it is just a was to see how much they are worn. for the new ones if you get them from honda should be replace and go
Quick 26 is offline
Old 05-17-2007, 1:27 PM
  #65
I was looking at bikebandit.com for replacement parts. Are they reputable and a good deal, or should I find someplace else?
scuba14c is offline
Old 05-17-2007, 1:28 PM
  #66
Carolina Kracker
Quick 26's Avatar
from what i hear they are
Quick 26 is offline
Old 05-19-2007, 12:36 PM
  #67
I've got another small problem. I'm trying to take off the head gaskets, and the gasket scraper I've got is scratching the head. Is there a way to remove these without using a tool (like chemicals)?
scuba14c is offline
Old 05-19-2007, 12:48 PM
  #68
Bike(s): CBR929
A die grinder with a 3m scotchbrite pad, but that is a tool. Also try just a razor blade, be carefull it will nick but is still easy.
zfrilly2 is offline
Old 05-19-2007, 3:09 PM
  #69
Bike(s): 2002 CBR600F4i
I have used them, they were good to deal with.
You just need to take it easy with the scraper.
sinfuldragon is offline
Old 05-21-2007, 8:00 AM
  #70
Carolina Kracker
Quick 26's Avatar
i usually use a razorblade and a bit of lube to sorten up the gasket
Quick 26 is offline
Old 05-21-2007, 8:41 AM
  #71
Now that I've got the pistons out, which ring set do I want?
bikebandit.com
ronniesmailorder.com
scuba14c is offline
Old 05-21-2007, 9:41 AM
  #72
Bike(s): CBR929
Measure the cyclinder, se what ring sets are availale, if you hone the cylinders you will probably need to get a ring set a few thousandths larger and file fit the rings.
zfrilly2 is offline
Old 05-21-2007, 9:56 AM
  #73
Carolina Kracker
Quick 26's Avatar
whatever you get make sure they fit in the grooves on the pistons. if you are able to get over sized rings and file fit like z said
Quick 26 is offline
Old 05-21-2007, 1:43 PM
  #74
I think the cylinders look ok. They shouldn't need to be honed. Would I just get the standard ring size, or the os .25? How do I find out if they fit on the cylinders?
scuba14c is offline
Old 05-21-2007, 1:46 PM
  #75
Carolina Kracker
Quick 26's Avatar
you would have to insert them and use a feeler guage to make sure the end gap is in spec. it sounds to me like you should just go for the std replacements if you dont have feeler guages or somone who can show you how to file fit the rings
Quick 26 is offline
Old 05-22-2007, 11:37 AM
  #76
Ok, sounds good. Should be ordered today or tomorrow.
scuba14c is offline
Old 05-22-2007, 10:03 PM
  #77
Bike(s): 95, CBR 900RR
.25mm oversize is .010" inch ( ten-thousandths). That is more than a few (.003") oversize. I'm curious to know how it works out.
The white stuff in the bolt holes could be a mixture of engine oil and coolant.. it turns white-light brown when mixed in a blender like atmosphere of an engine. This is what happens when a head gasket "blows", leaks. Oil and water meet and yes they do mix reguardless of what we've been told. I've rebuilt about 7 automobile engines and changed heads on a few others.
Read your manual about cylinder head reassembly. You may need to apply a thread sealant on some or all of the head bolts. many times engine head bolts pertrude into the water jacket ( wet cooling part of the engine). I'm not certain if your VFR is this way or not. If it is and you just screw the head bolts back in without sealant on them.... you will mess up your engine.
Also if you obviously need a new head gasket. Make sure you don't install it upside down. seriously.
Do you have a torque wrench for reassembly of the engine?
Did you end up buying this Motion Pro clutch tool?
Next time you need to buy Honda parts try Service Honda Home of the CR500AF 500AF 500AFX Junior-X - Honda Motorcycle Parts they are less than bikebandit. I have ordered from ServiceHonda a few times. Also RonAyers.com has oem Honda parts but if you live on the western part of the US don't use them.. they ship slow to the west, because they are in North Carolina.
Fastrr is offline
Old 05-22-2007, 10:09 PM
  #78
I'd love to build a formula style race car using a 1000cc sportbike engine Some day!
Fastrr is offline
Old 05-23-2007, 9:38 AM
  #79
This is the puller I got
Motion Pro Products - FLYWHEEL PULLER, M22X1.5 R.H. External Thread
It was just for the alternator cover. I do have a torque wrench as well. And you may be right about the white stuff. It smelled like bad oil, but I don't see how it could have gotten into the bolt holes and become pressurized.
I used Babbitts Online for the rings. They were $7 a piece under everyone else, though their shipping was a little high.
Arctic Cat, Polaris,Suzuki,Kawasaki,Sea-doo,Can-Am dealer west Michigan Muskegon lowest prices
This isn't quite a formula car. It's a scaled down sand rail that I'm goiong to use up in Houghton MI (where the college is) to fly down the logging trails and over the stamp sands.
scuba14c is offline
Old 05-23-2007, 4:44 PM
  #80
How clean does the head gasket surface need to be? Should it have a lot of garbage on it but be smooth, or should I only see aluminum?
scuba14c is offline
Old 05-23-2007, 4:48 PM
  #81
aluminum only.
Old 05-23-2007, 5:21 PM
  #82
So I should be using a polishing wheel and taking all the garbage off? I don't actually want to start taking the metal off the head.
scuba14c is offline
Old 05-23-2007, 5:22 PM
  #83
Bike(s): CBR929
Use a scotchbrite pad to remove anything a razor wouldn't get off.
zfrilly2 is offline
Old 05-23-2007, 8:30 PM
  #84
Don't get carried away with cleaning the head and cylinder surface. If it's a brownish color that is ok, just remove anything you can feel with your fingers, even if it is very slight. Remove too much material and you're going to run into an issue with the head gasket not sealing.
You would be amazed at how water and oil can work their way around bolt threads.
Fastrr is offline
Old 05-24-2007, 7:26 AM
  #85
Carolina Kracker
Quick 26's Avatar
disscoloration is fine, but actuall material is not. like they said use scotch brite to remove the remainder
Quick 26 is offline
Old 05-24-2007, 8:31 PM
  #86
I agree he does need to remove all the gasket and oil debri from the surfaces. I kind of disagree with using scotchbrite however. Only because i use it almost every day at the machine shop to deburr parts, it breaks down into fine particles that can harm the inner workings of an engine.
I use a lint free rag, acetone, and a scraper. acetone will soften anything stuck on the surface so it is much easier to wipe or scrape off the gasket stuff.
Not "dissin' " on you Quick26
Fastrr is offline
Old 05-24-2007, 8:34 PM
  #87
Bike(s): CBR929
Thats why you wash the engine block with a mild solution of soap and water before assembly, to remove any gasket material, or debris left behind.
zfrilly2 is offline
Old 05-25-2007, 6:43 AM
  #88
Carolina Kracker
Quick 26's Avatar
you calling me an idiot
i understand, no offinse taken
usually if i have to resort to scotch brite i am using a pnumatic one and i have the cyl and head where i can thoroughly clean them to remove loose particles. sometimes i will aquire lint free cloths to use at home
Quick 26 is offline
Old 05-25-2007, 10:48 AM
  #89
I used scothbrite and it cleaned up pretty well. I hosed it down after cleaning, so it should have gotten everything off. I don't have a lot of spare cash, and gaskets aren't exactly cheap. Could I use a gasket sealer to replace the gaskets in the engine (with the exception of the head gaskets)? I would mainly be the left and right side covers, along with the countershaft cover.
scuba14c is offline
Old 05-25-2007, 11:34 AM
  #90
Carolina Kracker
