Do honda interceptor 500's run hot?
07-19-2008, 9:30 AM
Bike(s): 1984 Honda Interceptor 500 Posts: 1
| Do honda interceptor 500's run hot? I went on a long ride and the bike kept stalling and the temperature guage was reading H for most of the ride. Did not smell coolant, but fan was slow to come on. Does this always happen? Should I add coolant and how do I add it to the bike?
Thanks Mike |
07-25-2008, 9:15 PM
Bike(s): 95 900RR, 99 996, 99 955i, 05 Busa, 96 KX250 Posts: 19
| Re: Do honda interceptor 500's run hot? All Hondas I've ever seen run hot, but if it was stalling and the gauge was in the red, I'd change your coolant (it degrades every two years or so) and verify that your fan start switch is coming on at the right temp. Service manual will help with finding everything, I've never hada VFR so I can't help ya there. |
07-25-2008, 9:19 PM
Bike(s): 06 883c, 03 cbr954, 86 gsxr1100, 83 cb650sc Posts: 124
Rep:  (19) Rep Power: 2
| Re: Do honda interceptor 500's run hot? Quote:
Originally Posted by mikehayes39 I went on a long ride and the bike kept stalling and the temperature guage was reading H for most of the ride. Did not smell coolant, but fan was slow to come on. Does this always happen? Should I add coolant and how do I add it to the bike?
Thanks Mike | oh man post up a pic of that jewel. im diggin the old intercepters. |
08-01-2008, 11:13 PM
Bike(s): 1984 VF500F, 2001 VFR800FI Posts: 4
| Re: Do honda interceptor 500's run hot? They do run a bit on the hot side if it is 100F+ outside and you're in start-and-stop traffic.
It shouldn't run hot enough to stall, though. |
09-15-2008, 4:29 PM
Join Date: 06-05-2008 Location: Sunnyvale, California, United States
Bike(s): 2003 Honda CBR954RR Posts: 110
Rep:  (25) Rep Power: 2
| Re: Do honda interceptor 500's run hot? mine always kinda ran a little warm. oil changes and coolant flushes are defintely on the top of the list, water wetter really helps out quite a bit. there were a few small things i did to my 85 that really help out tons
. IE i removed the block plate in front of the carbs removed cowling for radiator cut small slits in side plastics water wetter |
09-15-2008, 7:11 PM
| Re: Do honda interceptor 500's run hot? I found that Water Wetter didn't help.
(both with antifreeze mix and pure water) |
10-11-2008, 1:32 PM
Bike(s): 2006 triumph sprint ST Posts: 3
| Re: Do honda interceptor 500's run hot? they tend to run hot..coolent flush never hurts! I overheated mine.Its now for sale as a parts bike! |
10-21-2008, 10:15 PM
Bike(s): 84' Honda VF500F Interceptor Posts: 2
| Re: Do honda interceptor 500's run hot? I just recently purchased an 84' "Miniceptor" and had the exact same problem. I found that my carbs were set out of balance on the mixture. I retuned to about 2 full turns and she smoothed right out.  |
10-22-2008, 5:59 PM
| Re: Do honda interceptor 500's run hot? i used the water wetter with the OEM honda coolant |
