| clutch will not move at all okay here is my first post to this site. My bike is a 85 VF5OOF. hydraulic clutch. for whatever reason one day the clutch lever would not pull in. And when I pull on the lever real hard while the motor is running with trans in Neutral, the motor gradually dies. First, I pulled the slave cylinder off and checked for piston movement-yes it moves by actuating the lever and the lever feels fine. I bled the clutch too; did not make any difference. put the slave cylinder back on, then next I pull the clutch side cover and inspect the basket. all the plates are in good condition and not stuck together. I loosen the 4 bolts and remove the pressure plate, inspect the basket, gears and bearing, looks fine and i put it all back. By the way, while I had both the slave off or the clutch backet, the long clutch lifter rod moves freely back and forth--no problem there. Hmmmm. what is it? With the motor off, I am able to shift through all the gears, sometime i need to roll the bike forwards to back to allow the shift up or down. I give up. |
