02 VFR oil filter will not come off?
02-14-2009, 8:26 PM
| 02 VFR oil filter will not come off? Any ideas? I tried strap wrenches then just bought one of the end cap variants and I cranked on it and eventually it started turning but not the filter. I need to get this friggin thing off so I can finish this oil change????? |
02-14-2009, 8:31 PM
Bike(s): XX, RC51, '08 1000RR LE Posts: 4,540
| Re: 02 VFR oil filter will not come off? Large screwdriver and a hammer. Put the screwdriver though the filter and use it to turn it. |
02-14-2009, 8:33 PM
#3 | | choices we make define who we are
Join Date: 01-08-2009 Location: Haughton, Louisiana currently in Iraq.
Bike(s): 2007 CBR1000RR Age: 35 Posts: 1,576
| Re: 02 VFR oil filter will not come off? ok, if the canister is spinning but not the thin metal base, what you need to do is get a small metal chisel and hammer and tap on the metal ring where it seats up to the emgine, but becarefull not to hit the engine.
sounds like what happened is it stuck to the block and you spun the filter cover. |
02-14-2009, 8:39 PM
| Re: 02 VFR oil filter will not come off? I've had where the filter was put on so tight from the factory that I busted a oil filter wrench. It rounded the end off. So I used the screwdriver method. |
02-14-2009, 8:40 PM
#5 | | choices we make define who we are
| Re: 02 VFR oil filter will not come off? yep, workes great everytime too. just real messy... |
02-14-2009, 8:40 PM
Bike(s): 2007 Honda CBR1000RR & 1992 Honda CBR600F2 Posts: 349
Rep:  (25) Rep Power: 3
| Re: 02 VFR oil filter will not come off? Quote:
Originally Posted by Jetpilot07 ok, if the canister is spinning but not the thin metal base, what you need to do is get a small metal chisel and hammer and tap on the metal ring where it seats up to the engine, but be careful not to hit the engine. |  I used this same technique to get an oil filter off my Toyota truck. I would guess that the filter was put on without lubricating the o-ring. |
02-14-2009, 9:16 PM
| Re: 02 VFR oil filter will not come off? guys thanks for the replys I was hoping it wouldnt come to that, i think the case isnt spinning so there is hope, I thought about drilling a hole in the filter wrench and running a screw through it and filter, maybe less of a mess. |
02-14-2009, 9:17 PM
#8 | | choices we make define who we are
| Re: 02 VFR oil filter will not come off? sounds good |
02-14-2009, 9:57 PM
Bike(s): 2001 RC51 Age: 30 Posts: 457
Rep:   (196) Rep Power: 3
Originally Posted by 5 speed guys thanks for the replys I was hoping it wouldnt come to that, i think the case isnt spinning so there is hope, I thought about drilling a hole in the filter wrench and running a screw through it and filter, maybe less of a mess. | When you drill it be careful not to hit the threads. Drill at the end of the filter. I've done the screw driver bit before. Drilling just sounds scary.
__________________ If everything seems under control, you're just not going fast enough.
— Mario Andretti |
02-14-2009, 10:15 PM
Bike(s): '01 CBR 929 black & red, K7 GSX-R600 Age: 49 Posts: 6,660
Originally Posted by lanbrown Large screwdriver and a hammer. Put the screwdriver though the filter and use it to turn it. | Yeah, I had to do that once as a last resort. Another reason I like to do my own oil changes....then I have no one to curse out by myself if the filter is on too tight... |
02-14-2009, 10:18 PM
Bike(s): '03 CBR954, '98 VFR, '92 750ZR, '78 KZ650 Age: 51 Posts: 285
Rep:  (74) Rep Power: 1
| Re: 02 VFR oil filter will not come off? Or, use large water-pump pliers (also known as "slip-joint" pliers). They open wide enough where you can grab the thing, crunch down and get it started. It's usually just that first turn that's difficult.. |
02-14-2009, 10:23 PM
Originally Posted by muddysteel Or, use large water-pump pliers (also known as "slip-joint" pliers). They open wide enough where you can grab the thing, crunch down and get it started. It's usually just that first turn that's difficult.. | True, I've crushed filters and managed to get them off without resorting the to the puncture/screw driver method. |
02-14-2009, 10:46 PM
#13 |
| Re: 02 VFR oil filter will not come off? Yes, I was able to drill at the end a small self tapping screw, worked like a charm!! Thanks guys |
02-15-2009, 6:59 AM
#14 | | Out Of Many, We Are One
Bike(s): CBR954RR, Hornet CB900F-5, VFR800FI + More Posts: 6,906
Originally Posted by 5 speed Yes, I was able to drill at the end a small self tapping screw, worked like a charm!! Thanks guys | That seems like a more neater way of doing it, but I would have opted for the hammer and screwdriver.
My Mini's engine is so compact that was the only way to take it off.
