help with VF1100c
Old 09-16-2009, 9:59 PM
LIV
Bike(s): vf1100c
Rep: LIV is on a distinguished road (10)
help with VF1100c
Hi,
I picked up a VF1100c today.
I noticed the forks are leaking and upon closer inspection, found that the new seals are not the issue, the fork itself are pitted. It looks like grains of sand might have been stuck inside the boot for years and eventually made the gashes on the tube.
Now what to do ? rebuild the forks with new inner tubes ? change for another used one ? or get entirely new forks ?
And what about aftermarket forks ? Would it be easier to try and find a new forks, even change for inverted fork ?
Let me know your thoughts on this.
Cheers,
LIV
LIV is offline
View LIV's Profile View LIV's Gallery Find More Posts by LIV
Old 09-16-2009, 10:07 PM
Out Of Many, We Are One
Twincam's Avatar
Re: help with VF1100c
Back in the oldern days we used to remove the pits by using wire wool and wd40. Depending how bad they have pitted, you might be able to salvage them.
I would be inclined to re-build them, replacing parts if and when needed.
Twincam is offline
Old 09-16-2009, 10:55 PM
LIV
Bike(s): vf1100c
Hmm thanks, I'll give that a try.. if not, my local honda dealer can get me the tubes for ~200$ a piece.. seems alot!
Cheers !
LIV is offline
Old 09-16-2009, 11:00 PM
LIV
Bike(s): vf1100c
One more question, whats the best way to clean up the chrome somewhat.. without re-chroming it.. i'd like to clean it up, remove some of the rust gently.
LIV is offline
Old 09-17-2009, 6:56 PM
Twincam's Avatar
Autosol? Beware, too much polishing could actually lift the chrome off.
Twincam is offline
Old 09-18-2009, 10:24 AM
LIV
Bike(s): vf1100c
Hi,
thanks for the reply.. will do
Another question,
Anybody knows if I can replace these forks for another model of forks or which years / models are compatible ?
Like can i use the vf1100s ( saber ) forks ? or the vf750c ? of the same years ? or anyone know of an aftermarket one ?
Cheers!
LIV
LIV is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:58 AM.
