pdf file ? - Honda Motorcycles - FireBlades.org
Honda Interceptor / VFR Discussion of the Honda Interceptor and Honda VFR Motorcycles.
post #1 of 6 Old 06-17-2011, 8:03 PM Thread Starter
Images: 1
pdf file ?
would anyone have a pdf file .....or just a pic of how the vaccum hose hook up on the petcock on a 1986 vf 500 interceptor
Thanks
OLD DUDE
characah is offline
post #2 of 6 Old 06-17-2011, 9:54 PM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: pdf file ?
Thanks
OLD DUDE
The vacuum hose goes to the vacuum chamber on the back of the tap.
The fuel hose goes to the fuel outlet.
OEM Parts Honda 500 INTERCEPTOR (VF500F) 1986 FUEL TANK - Cheap Cycle Parts
VF500_Fuel_Tank.png‎
post #3 of 6 Old 06-17-2011, 10:43 PM Thread Starter
Images: 1
Re: pdf file ?
thank you bladeracer....you always come thru....i got a new petcock ...an wanted to make sure i hookrd the vaccum up right....the petcock has a 90' that i think goes to the cyclinder vaccum an then another one that comes out straight which goes back to the carb should have been small pipe ....but its gone so i just used hose ....now seems like i'm not grtting much gas....throttle up just stalls....or acting like its starving for gas....
characah is offline
post #4 of 6 Old 06-17-2011, 10:44 PM
Images: 2
Quoted: 2 Post(s)
Re: pdf file ?
Make sure the hose is not kinked or collapsing from the vacuum.
post #5 of 6 Old 06-18-2011, 3:41 PM Thread Starter
Images: 1
Re: pdf file ?
bladeracer would you have a pdf on how to advance or retard the timing on this engine
Thanks
OLD DUDE
charles
characah is offline
post #6 of 6 Old 06-19-2011, 1:25 AM
Images: 2
Quoted: 2 Post(s)
Re: pdf file ?
Thanks
OLD DUDE
charles
If you mean the ignition timing, it shouldn't be adjustable.
If you really need to for some reason you would have to slot the holes in the pulse generator pickups. Or if you're only playing with it for diagnostics you can pull the rotor off and remove the woodruf key. Then install the rotor where you want it to trigger the pickups. I wouldn't ride it with any hard acceleration or deceleration without the key in it though. If it spins on the crank you will probably be chasing a new crank.
Actually, I just had a look at the fiche and the VF500 starter clutch rotor is splined onto the crank rather than on a taper so you can't adjust the rotor.
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Interceptor / VFR
Human Verification
Search tags for this page
1986 suzuki intruder vs 700 vacuum hose routing diagram
86 honda vf 500 f gas line diagram
fuel and vacuum line oruting 1985 vf500f
fuel line routing on a 84 interceptor500
honda interceptor 500 vacuum diagram
honha interceptor 500 gas tank vacuuming. daigram
vacum lines 500 interceptor
vacume lines honda shadow 700vt
vf500 fuel line routing
vf500 fuel tank hook up
View an .asp file? Red Rider Off-Topic 29 08-23-2006 6:17 PM
EPS FILE ERUS37 Honda FireBlade 23 10-28-2005 8:20 PM
PC to PC File Transfer bwhip Off-Topic 11 01-11-2005 8:26 PM
File Format - .IDX??? nomad Off-Topic 14 04-22-2004 4:22 PM
