New clutch slipping - Honda Motorcycles - FireBlades.org
Honda Naked Sportbikes Discussion of the Honda 599, Honda 919, and Honda CB1300 Motorcycles.
post #1 of 8 Old 10-19-2016, 10:34 PM Thread Starter
New clutch slipping
I just put a new EBC clutch in my 2007 honda 919 but now I can't seem to get any adjustments to work where it is not slipping could it be my cable is stretched out
charles187 is offline
post #2 of 8 Old 10-20-2016, 2:29 AM
President Team Full Chat
Images: 4
Quoted: 187 Post(s)
Reputation Power: 74
Re: New clutch slipping
Was it slipping prior to the new clutch install?
Are you absolutely sure the same number of plates went in, that came out?
IanDoohan is offline
post #3 of 8 Old 10-20-2016, 5:04 AM
Quoted: 14 Post(s)
Did you chuck the verniers over the plate stack and springs? I put an EBC kit in my 893 recently to replace a slipping clutch, both the plate stack and springs were shorter than what came out. I think i ended up reusing the standard springs - or was it the standard metal plates? - Cant remember - i wish i didn't smoke so much pot when i was young, lol.
I'd have to check, got it all sitting in oil in a tupperware on the shelf. But it doesnt slip.
With your cable adjustment - have you got some slack when you release the lever? You dont want tension on that when you're not on the lever.
Squid is offline
post #4 of 8 Old 10-20-2016, 8:46 AM Thread Starter
My old clutch was slipping but with 24,000 miles on the bike is thought it's time for a new clutch the old steels where glazed and blue I'm going to open her up aging just to triple check my work
post #5 of 8 Old 10-20-2016, 8:46 AM Thread Starter
post #6 of 8 Old 10-20-2016, 8:47 AM Thread Starter
post #7 of 8 Old 10-20-2016, 10:09 AM
Images: 4
Quoted: 187 Post(s)
So initially it could have been the cable. Might want to get one just because.
post #8 of 8 Old 10-20-2016, 12:49 PM
Quoted: 113 Post(s)
Reputation Power: 2
Typically the cable will be overstretched and the clutch will fail to disengage and will drag the bike, causing the engine to stall at full stops and die. Thanks for diagnosing my F4i - it will likely need a new cable soon as it's draggy.
In the case of a new clutch slipping my first thoughts are:
  1. Were the plates installed in the correct order?
  2. Were the plates soaked in oil prior to installation?
-2006 CBR1000RR- Jardine RT-1 CF, GP Shift rearsets, GP Suspensions 20mm revalve, Penske 8987 triple clicker
-2002 CBR600F4i (was mine and now hers)
Ohlins, Racetech, Showa custom Suspension
Jaybird180 is offline
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Naked Sportbikes
Human Verification
Search tags for this page
2003 f4i clutch steels reusing
Clutch slipping American General Discussion 11 04-01-2014 1:02 PM
Clutch Slipping??? Hicksi Honda CBR400RR 12 04-21-2011 1:50 PM
08 clutch slipping NWBackwoods Honda FireBlade 31 07-22-2010 2:55 AM
Clutch Slipping dcb2231 Honda FireBlade 3 07-14-2009 5:34 PM
Clutch Slipping 2001 929rr Honda FireBlade 5 07-29-2003 8:25 AM
