Bike Turns Over But No Fire!
Old 06-01-2006, 8:26 PM
Bike(s): '05 YZF 600R, '04 VTX 1300C, and '02 CB919
Rep: 919er is on a distinguished road (10)
I have an '02 Honda CB919 that was running great until a few weeks ago. Let me explain the situation: I rode the bike for approximately 2 hours to friends house and let the bike sit for about 3 hours. When I left, I let the bike warm up and then I rode to the gas station about 10 miles and filled up (92 octane). After filling up I turned the key on and pushed the start button, the bike turned over but did not fire. I checked the fuses (ok), I opened the gas tank lid thinking it may have been a vapor lock (no change). I had the bike towed to my friends house and let it sit overnight. The bike started and ran fine the next morning. I repeated the process of starting and turning off at least 5 times with no problems, but I didn't let the bike warm up. I trailered the bike back home that day. Two weeks later (yesterday) I went to ride the bike. I started the bike and let it warm up before the ride, after warming up I turned the bike off and tried to start it again just to make sure it would start. Unfortunately it did the same thing, the bike turns over but does not fire. I hear the fuel pump running all the lights work correctly, but I still can't figure out what it could be. Any help would be great. Thanks.
919er is offline
View 919er's Profile View 919er's Gallery Find More Posts by 919er
Old 06-01-2006, 8:29 PM
ConqSoft's Avatar
Bike(s): 2007 Honda ST1300
Re: Bike Turns Over But No Fire!
(Moved to Honda Naked Sportbikes forum.)
My Blog
GPS Discussion Forum
ConqSoft is offline
Old 11-08-2006, 10:44 PM
Bike(s): Ducati 1098, 02 919, 92 CBR900RR
Rep: coteesh is on a distinguished road (10)
Send a message via MSN to coteesh
I'm no expert but fuel injectors? Spark plugs?
coteesh is offline
View coteesh's Profile View coteesh's Gallery Find More Posts by coteesh
Old 11-30-2006, 7:31 AM
Bike(s): 02 Hornet900, 01 F4i
Rep: touring919 is on a distinguished road (10)
How many miles are on your bike? Mine did the same thing until I got 1000 miles on it. It happened several times. After I passed 1000 it never happened again. Can't explain it. I thought it was some kind of safety net for overheating. Mine at 46000 on it now.
touring919 is offline
View touring919's Profile View touring919's Gallery Find More Posts by touring919
Old 12-01-2006, 10:36 PM
Bike(s): CBR1100XX and 919
Rep: Wockman is on a distinguished road (10)
My '02 919 has done something very similar to that twice in the past year and a half that I've owned it. Try switching the engine stop switch (red switch on the right handlebar) on and off (back to the run position) then try it.
It took forever for me to figure it out since I normally use the ignition switch. Anyway give the engine stop switch a try next time it does it and let us know if it works.
Wockman is offline
View Wockman's Profile View Wockman's Gallery Find More Posts by Wockman
Old 12-02-2006, 9:55 AM
Das Ende ist hier
seamus's Avatar
Bike(s): One
Rep: seamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud of (1425)
If that is your fix, you should open up the switch and check the connections inside.
If you can fix it by "pulling the circuit breakers", you're only prolonging the real problem.
seamus is offline
View seamus's Profile View seamus's Gallery Find More Posts by seamus
Old 12-02-2006, 10:09 AM
Bike(s): 2005 cbr600rr street, 2004 Yamaha R6 track
Rep: Nicky66 will become famous soon enough (83)
I had the same thing happen on my 929. It was the CDI box. I bought a new one on ebay for $100. Problem solved.
Nicky66 is offline
View Nicky66's Profile View Nicky66's Gallery Find More Posts by Nicky66
Old 12-07-2006, 2:31 PM
Bike(s): 01'RC51, 00'CBR600F4, 89CB-1, 99SV650, DRZ400SM
Rep: HRC NICK 11 will become famous soon enough (76)
Did you work on the bike at all when you were at your friends house before you went to the gas station?
It could be a weak battery. Sometimes a battery with a bad cell will turn the bike over but not fast enough to start it.
Have you tried the choke, I had a friend that tried for a week to start his bike and did not know motorcycles had chokes. He never needed it in the summer but once fall came around the bike would not start with out it.
HRC NICK 11 is offline
View HRC NICK 11's Profile View HRC NICK 11's Gallery Find More Posts by HRC NICK 11 My Map Location
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:05 AM.
